TCL 75S421 New Backlight LED's Still No Backlight
  • ChattFix
    • Oct 2021
    • 79
    • US
    Originally posted by EazyBone
    You got new PSU and lights show up now? Cracked screen only sometimes shows picture, not always.
    Poor tv, been there done that. I personally take the TV down to the bones again and practice my disassemble when this happens. Take the new lights back off. save for next tv.
    $200? What did you buy it for.
    No, I repaired the PSU. Spent $150 on the TV and $50 for the backlights. I assume the original backlights might have been good.
    • EazyBone
      • Jun 2023
      • 1362
      • United states
      Ahh, didn't you test them with led tester? Step one, test them. But maybe PSU was bad.
      well you got some experience
      • ChattFix
        • Oct 2021
        • 79
        • US
        Haha to be honest I cant remember! I did the backlight swap and nothing worked so I threw it in the closet and got it out because my wife wanted it out haha. I remember when I slid the screen back in I slid the screen on one side to far and I cracked it. Sad day but as you said, lesson learned. I have done a few Vizio's since then and they were a piece of cake. Thanks everyone for the help and guidance!
        • pni
          Backlight panel diffuser melt by backlight leds broken
          by pni
          Hi guys, I changed my backlight to a 5g in Samsung but the broken leds burned the thick plastic panel . I give the photo. Do you think if I try to rotate the panel, with the botton on the top I have a good image? Becacause now how u can see, on the light color I sse the leds because of the burned on the plastic diffuser....
          10-12-2025, 12:08 AM
        • survivalbloke
          Macbook A2289 - backlight problems - have checked a lot already - out of ideas
          by survivalbloke
          This is A2289, board 820-01987-A. It came in with the screen not working. We could not see any image on the screen, so we ruled out a backlight issue and instead replaced the panel. The display now comes up, but no backlight.
          I didn't see any signs of liquid damage, but there was some odd looking spots around U8400. F8400 has voltage on either side of it, and I have 5v present on R8444 and R8445. I did not have 3.2v at R8442 so I figured U8400 was bad, and I replaced it. After replacement, a brief probe to R8442 showed 3.2v so I assumed I had fixed the device. After reassembly however,...
          09-12-2023, 11:44 AM
        • Anooc7
          Samsung UN75NU6950 no backlight but leds works when checked individually!
          by Anooc7
          Hi, This model has bottom mounted leds . Got it with right ride 1/3 of the display black. So I checked the 6 + and - wire that powers 6 different zones and found that the 5th zone was open, which opens 6th zone too makes the right 1/3 of the display dark. Opened it and found one blown led on the 5th zone and shorted that path using solder. So now all the zones works when I check it using the bl tester , but when I put everything back together there is no backlight! The voltage I am getting when neg to chassis is 387v. How does that happen? Still individual zones working with bl tester .
          09-16-2021, 06:16 PM
        • Superbee_dad
          Sharp 80” long short flash backlight error - Help
          by Superbee_dad
          Hello Sharp TV experts
          Our Sharp LC-80LE642U displays one short one long flash error code which is a backlight error. I went into service mode and there were 8 lamp error counts recorded. I reset the count to 0 and did a reset. The last monitor error cause was 16 B00014639:12. 16 is the code for backlight error. I tried to power the tv up but went back into error mode.
          > I checked voltages on the power supply board and they all check out .. including 3.28 volts at the error pin.
          > There is power to the cpu and T-CONN and no faults found there. The cpu has a flashing...
          01-24-2025, 11:51 PM
        • triplefour
          by triplefour
          09-13-2023, 10:43 PM
