Emerson LC320EM9B on then off
  • CraigR
    • Dec 2013
    • 959
    I have a Emerson LC320EM9B the standby light is red then I hit the power button the power light flashes 11 times then stays on green and I see the words "Digital Television" come on the screen for a second then goes out and the green power light goes out and the red standby light comes back on. I took the back off and no obvious bad caps I can see no burning or hot places I see so not sure where to check next. Ideas?? I uploaded what the boards look like.
  • philliesfan30m
    • Aug 2013
    • 542
    Re: Emerson LC320EM9B on then off
    i don't know if it is the same problem but this was a thread i created for a sylvania 37" but you might be having the same problem because it is pretty much the same setup except mine has 7 inverters not 5 check it out and post if that was it. if not someone here could help troubleshoot it. but it is always good of you to take pics of the back of your tv with the cover off and single pics of all the boards so we can maybe see something you may have missed.
    https://www.badcaps.net/forum/showth...light=sylvania
    • CraigR
      • Dec 2013
      • 959
      No such luck. here are pictures of my actual boards.
      • philliesfan30m
        • Aug 2013
        • 542
        in the second pic what is the label on the 2 components above the 3 resistors in a row? wow that board got hot just like someone else that posted but never said what the fix was.
        • CraigR
          • Dec 2013
          • 959
          No lables but if you mean the place on the board is BC1931 and BC1932 that's also just a shadow from where the light was the board is not actually burnt.
          • philliesfan30m
            • Aug 2013
            • 542
            oh ok it looks burnt. did you check anything at all? did you check that diode between the heatsink and the transformer?
            • CraigR
              • Dec 2013
              • 959
              Yes that is I guess a common leaky one but it checked ok, may replace it anyway.
              • philliesfan30m
                • Aug 2013
                • 542
                what did it read?
                • CraigR
                  • Dec 2013
                  • 959
                  540 one way and nothing the other.
                  • philliesfan30m
                    • Aug 2013
                    • 542
                    i don't think that is the problem. for some reason it is telling it to go into protect mode i think.
                    • philliesfan30m
                      • Aug 2013
                      • 542
                      did you test that mosfet on the heatsink by those 2 caps i asked about earlier?
                      • CraigR
                        • Dec 2013
                        • 959
                        not real sure on testing those does it need to be out of circuit?
                        • philliesfan30m
                          • Aug 2013
                          • 542
                          it might also have a bad inverter. causing it to go into protect mode now that i think about it. take the board off and measure the resistance of the inverters. take a pic of the bottom of the board. maybe i bad inverter is causing it to go into protect mode. you should be able to tell by testing them and seeing if they are all the same then they are probably good but if 1 varies a lot then thats probably your problem.
                          • philliesfan30m
                            • Aug 2013
                            • 542
                            scratch the part about the mosfet for now. you might even be able to test them without taking the board off if you can get your probes on the legs. but it would be better to see the bottom of the board to see how many pins it has etc.
                            • CraigR
                              • Dec 2013
                              • 959
                              took mosfet out of circuit and meter on diode black on middle leg and red on right leg gets 517 and nothing else in any other combination.
                              • CraigR
                                • Dec 2013
                                • 959
                                pic of bottom.
                                • philliesfan30m
                                  • Aug 2013
                                  • 542
                                  set meter to 2000ohms and test where the arrows are pointing 1 probe on 1 pin and red on other for all 5 of the inverter transformers and also check the 2 pins above that the same way for all 5.
                                  • CraigR
                                    • Dec 2013
                                    • 959
                                    just went through them all and read all the same then put board back it and used test bulb on each one and still shut off. I did hear a little squeal from the transformer for a few seconds.
                                    • philliesfan30m
                                      • Aug 2013
                                      • 542
                                      see if you have any resistance between the primary and secondary sides of the inverters i was gonna have you do that next but you put the board back in.
                                      • philliesfan30m
                                        • Aug 2013
                                        • 542
                                        did you happen to check the other transformer?
                                        • MOSSEP
                                          Monitor Audio RSW12 - Green light, but no sound
                                          by MOSSEP
                                          Hi
                                          Im hoping someone might be able to give me some idea of what may be wrong with my Monitor Audio RSW12 Sub.
                                          Ive owned it since new in around 2002, so would really like to keep it running if I can, it was the first ‘decent' bit of audio equipment I ever purchased and is a little sentimental.
                                          The issue I had was that it would power up with the red light, but sometimes the green light would not come on and I would get no bass from it. If the green light did come on though, I would get sound out of it.
                                          I have already tried replacing all of the...
                                          01-26-2025, 08:33 AM
                                        • MOSSEP
                                          Monitor Audio RSW12 - Green light but no audio
                                          by MOSSEP
                                          Hi
                                          01-26-2025, 08:18 AM
                                        • lcdcaps1
                                          820-2610-A Sys onewire help, no green light. Please help from the gurus
                                          by lcdcaps1
                                          Hi
                                          I have an 820-2610-A motherboard that has no green light.
                                          I have noticed is when I do a SMC reset the light on the Magsafe blinks.
                                          From My understanding, the sys onewire circuit is responsible for the green light on the magsafe
                                          The sys onewire circuit on this model and others is more involved
                                          I was hoping if anyone knows about this and how it works, can reply and let me know
                                          I know this is an old model but I am sure there are people who still works on these or knows about them
                                          I get 1.1v on the C7771 capacitor and will replace...
                                          11-06-2023, 01:28 PM
                                        • AleMonti
                                          LG 55EG910V - no power and no standby light
                                          by AleMonti
                                          I'm trying to troubleshoot and repair this old LG OLED curved TV, model 55EG910V.
                                          I did some basic troubleshooting and reviewed most related posts here, but I wasn't able to isolate the issue.
                                          The TV shut itself off during playback and never came back to life - the standby light remains off. My dad claims that it has happened a few times in the past but the issue resolved itself after some time. Not this one.
                                          After checking the basics I did the following:
                                          • I measured all voltages and as expected the only active supply is the 3.5V standby. It
                                          11-04-2024, 05:02 PM
                                        • blazzelia
                                          MBP A1286 820-2915 green light only, no start
                                          by blazzelia
                                          Hi guys,
                                          I have this 2011 MBP - the company I was working for, bought it at the time for a project and gave it to me after that. Later on, I gave it to my daughter which used it for normal internet browsing and office apps. At some point the, now famous, AMD GPU issue hit this laptop as well. I disabled the use of the AMD GPU following some information I found at the time (the one that, at the end, one moved AMD kext drivers to a backup location). So the laptop was using the CPU graphics and it was ok for the said daily usage. I even replaced the drive with an SSD one and it was operating...
                                          09-30-2024, 07:20 AM
