LG 43UF640V backlight good but black screen and no sound
  • totof
    • Feb 2017
    • 157
    • france
    Good morning.
    I have a problem with my LG Smart 43UF640V TV. It starts, the backlight comes on but nothing is displayed on the screen and there is no sound.
    I thought it was a TCon problem and ran various tests. If I disconnect one or the other of the cables from the tcon to the panel then the screen is white on the side where the cable is disconnected and black on the other side. If the two cables are disconnected the screen is completely black.
    In the 4 configurations I measure exactly the same voltages on the tcon card (model V15 43UHD TM120 Ver0.4) :
    HVDD : 7,28 V
    VGL1 : -4,99 V
    VGL2 : -9,96V
    VCOM1 : 5,71V
    VCOM2 : 5,69V
    VGH_ODD and VGH_EVEN : switch between 27,96V and -9,94V
    VDD : 14,45V
    VCORE : 1,21V
    VCC18 : 1,8V
    These voltages seem correct to me and so I don't know if the problem could be the panel, the tcon or the motherboard. Do you have any advice to help me with my research ?
  • Bholu
    • 48
    • Saudi Arabia
    hello friend this fault comes with y line shorting u need to locate ckv ckv1 ckvb ckvb2 stvp points they are always go through right and left source pcb to the glass.first cut right side if picture ok then good or picture is not good you need to jumper them and cut other side lines.try this
    • totof
      • Feb 2017
      • 157
      • france
      Thank you Bholu for your help.
      I don't found ckv ckv1 ckvb ckvb2 stvp points but I found service manual for my TV and signal name are different (see the attached document).
      • Bholu
        • 48
        • Saudi Arabia
        These are the ckv lins first of all block right side then try left side check it one by one with the help of cello tape.
        • totof
          • Feb 2017
          • 157
          • france
          I blocked all CLK signals, one by one, on each left and right side, and screen remains always with no video.
          Just to notice that for CLK4 signal half of the screen is black deep.
          • totof
            • Feb 2017
            • 157
            • france
            Is somebody has another idea to help me to determine the origine of the problem ?
            • Diah
              • Feb 2013
              • 6360
              try replace t-con incase only you have sound
              if no sound then the issue at maunboards
              • totof
                • Feb 2017
                • 157
                • france
                Thank you Diah.
                There is no sound and when I disconnect only one nappe between tcon board and lcd panel I have no video, even on the side still connected to the lcd panel.
                I don't know how to check the mainboard. Maybe it can existe a debug port.
                • Diah
                  • Feb 2013
                  • 6360
                  Originally posted by totof
                  Thank you Diah.
                  in general what you did to disconnect half screen and it show for you half white mean communication and panel with t-con are fine..... NO sound mean the fucking mainboards didn't work at all. so no signal to damn T-CON.
                  so why you go to involve with VG and CK... hope you are just testing didn't damage parts.
                  • Diah
                    • Feb 2013
                    • 6360
                    welcome in this forum... but please DON'T JUDGE WITH OUT EXPLANATION;: SERVICE MANUAL AND SCHISMATIC COVERED THE NET OVER ALL::: HERE NEEDED ADVICE WITH EXPLANATION SO OTHER WILL LEARN AND FOLLOW:
                    • totof
                      • Feb 2017
                      • 157
                      • france
                      Finally I was wrong and there is sound on the TV.
                      I checked all the resistances and capacitances on the panel PCB and nothing abnormal (no short circuit, 3 resistance values noted: 0 ohm, 30 ohms and 100 ohms).​
                      • Mgiffune
                        by Mgiffune
                        06-09-2024, 10:28 AM
                      • maxim2511
                        LG 55EC930V OLED - swich on swich of no screen
                        by maxim2511
                        My Oled Tv is 55inch tv, 3 days ago I notice that middle of the screen is getting warmer and on picture I have ghosting, missing red color. Color red was still displaying, but it was not so strong as corners of the screen and watching some movies makes me angry.
                        Then I get an idea to take it apart and clean boards from dust.
                        In side of Tv was not so bad, I take compressed air in can, and gently blow up.
                        Also I was thinking to styrofoam sponge to isolate power board from screen that the middle of the screen will not worm so much. Because Led on screen when gets higher...
                        05-14-2021, 02:21 AM
                      • Rozp
                        70LE660U dark cloud or black screen with sound.
                        by Rozp
                        Hello Everyone,
                        This is my first post so I will try to be as precise as possible without making this post too long winded. Unfortunately I don't have pictures of the original problem but I included images of the TV internals.
                        I have a Sharp 70LE660U. The problem started a few months ago with the bottom row looking out of sync and was dark on the left side and then fading to transparent on the right side. Shortly after, a dark cloud appeared in the center of the screen. The dark cloud started small and shaded but the image was visible. It also affected the menu area....
                        08-29-2023, 05:25 PM
                      • Audeze
                        Sony XBR-75X950G seems dead with a black screen but backlight and sound is working and no blinking red lights
                        by Audeze
                        I have a 2019 75" x950g, and while playing a movie, the screen suddenly went dark in a weird way, where it faded towards one corner into being fully black. Now the TV turns on, and the backlight comes on, but there is nothing displayed except black. Sound still comes through the TV speakers, and i have tried doing a hard reset using the volume - and power buttons while plugging the display back in, but it did not fix it. I can confirm that pressing buttons on my remote is still doing "something" because I'm hearing sound still, even though the screen is black.
                        Does...
                        10-06-2024, 08:54 PM
                      • mrtek
                        Samsung UN65js8500F, no sound, blank screen and T-Con board with one LED on
                        by mrtek
                        Hi I am new to this kind of repairs but I want to learn..I have a Samsung UN65JS8500F. the TV used to work and I tried to fix darker areas in the middle only ( img 1,2,3). I thought the led strip were bad..not the case. I did not research in advance what kind and where the LED were located. In this model they are located vertically on right and left side. Took the TV apart and put it back together. Now the tv shows no welcome screen and no sound is available thru the speakers. ..just a black screen..Backlight LED do turn on...also noticed a 5 blink code , not sure if that was there before. I can...
                        11-26-2024, 09:58 AM
