Philips 37pfl7662d
  • soukehal
    • Dec 2012
    • 45
    • Algerie
    Philips 37pfl7662d
    Good morning.
    My TV is showing a white screen, but the sound works. What should I do?
    Re: Philips 37pfl7662d
    Check t-con fuse. Post a picture of the inside of the TV with the back cover removed if you can't locate the t-con board.
    • soukehal
      • Dec 2012
      • 45
      • Algerie
      fast response thank you, enclose a check photo.je clothe F.
        See here. Under the metal shield, the blue board.
        • soukehal
          • Dec 2012
          • 45
          • Algerie
          thank you
          tom66, good idea I removed the T-com thank you card.
          • philliesfan30m
            • Aug 2013
            • 542
            did you check the fuse on the t-con?
            • soukehal
              • Dec 2012
              • 45
              • Algerie
              yes "philliesfan30m" yes the fuse and good = F1
              • vinceroger69
                • Mar 2012
                • 6714
                so what voltage do you get to each side of the fuse?
                • soukehal
                  • Dec 2012
                  • 45
                  • Algerie
                  hi "vinceroger69" puije begin measuring a voltage with tv dismantled join merci.ci Photo.
                  • philliesfan30m
                    • Aug 2013
                    • 542
                    wow i guess you really have it dismantled. you are not gonna check any voltages on the t-con that way. put the t-con back on but don't put the cover over the top of it. and hook the screen back up. all we wanted you to do was remove the cover over the t-con board not do a complete tear down.
                    • soukehal
                      • Dec 2012
                      • 45
                      • Algerie
                      ok, "philliesfan30m" I vai back and measured and I thank you ren answer.
                      • soukehal
                        • Dec 2012
                        • 45
                        • Algerie
                        hi, trying measured between F1 12v output 12v ..
                          between F1 and chassis ground is what we want, chassis ground being the metal frame of the LCD panel or where the boards are mounted to.
                          • soukehal
                            • Dec 2012
                            • 45
                            • Algerie
                            hello , yes it is done there 12v F1 before and after correct fuse.
                            there are two regulator 1) U804 ref: NTK0S L1117DJ-1V5 1.8 12V OUTPUT
                            2) U802 ref: APR138 3V1 2V5 OUTPUT, someone has this schema map to an external power supply industry.
                            • soukehal
                              • Dec 2012
                              • 45
                              • Algerie
                              hello, this is resolved after changing the module T-con gets a case.
                              • Sharpa
                                Repair attempt Philips 55OLED804/12
                                by Sharpa
                                I bought a SH Philips 55OLED804/12 TV with known defect in an attempt to repair it for personal use.
                                The symptoms when bought: Philips logo appears then tv turns off
                                Things tried so far:
                                1. Powering it on: Philips logo shows on the screen, sometimes with some minor artefacts then shuts down. Red status led flickers rapidly into two batches then repeats
                                2. Put it in recovery mode by pressing joystick down then plugging it to mains: The tv shows the logo then shows the android animation along with some minor artefacts on the screen...
                                Today, 08:30 AM
                              • alro7779
                                Philips 32PFL4901/F8 BA4GF0F0102 2 Not getting standby led
                                by alro7779
                                Hello, guys!
                                The same 32" Philips TV I was having video issues, but now I don't have standby led at all. Someone here shared with me the schematic of the power supply, and checking the voltages, I see right after the resistor R604 I'm getting 1.6 v which is too low for enabling the Gate of the Q601 mosfet (the diagram says 4.2). On the R614 resistor I'm getting 181 V in and 117 V out, then through R603 I'm getting the same 117 V in and 59.9 V out, finally getting the latter voltage in the R604 BUT getting just 1.6 V out, which is the voltage that goes on to the Gate of the Q601...
                                09-14-2025, 12:25 AM
                              • G33RT
                                Philips 8200 series 65PUS8204/12 stuck at Philips Logo
                                by G33RT
                                Philips 8200 series 65PUS8204/12 stuck at Philips Logo, it does not reboot it just stays on the logo.
                                It does power up when pressing the power button.
                                I already try the power button while plugin the plug with no result.
                                Also put the latest firmware autorun-TPM191E_R.001.004.100.000.upg on a MBR/FAT32 USB stick at USB port2 with no result either.
                                Could this be an PSU or eMMC issue ?
                                07-19-2025, 03:43 AM
                              • Track4207
                                Hisense H50N5300UK reboots when showing full red images
                                by Track4207
                                Hi all! A bit of an interesting and unusual problem: as the the title suggests I have a Hisense H50N5300UK that reboots when showing fullscreen solid red images (and some other solid colours, but red generally causes the issue the fastest). I first came across the problem assuming it was an intermittent issue, but later lucked into finding out that a title sequence of a show I watch happened to trigger the reboot.
                                What happens:
                                • TV appears to operate normally, for an indefinite amount of time until a problem image appears
                                • The problem image is displayed very briefly, then the
                                08-30-2023, 11:58 AM
                              • double_DD
                                Philips curling iron - is this a common AC cable?
                                by double_DD
                                Wife has 2 Philips hair curling irons half defective - after learning how they're supposed to work and testing them, it turned out that both have defective power cables, and both on the same place; broken wires due to wire bending.
                                As they were both relatively easy to disassemble, and cables are plugged not soldered (as they can rotate in the handle), I was sure it would be easy to find replacements. But - NO! I'm unable to find anything similar on ebay or Aliexpress.
                                Not sure if this is something Philips proprietary, or a standard, but the cable plug...
                                08-18-2025, 10:04 AM
