HITACHI 58HK6100UA
  • Runlinc
    • Apr 2021
    • 28
    • England
    HITACHI 58HK6100UA
    When changing channels the top quarter of the screen is dark for 3 seconds before lighting up as normal.
    This happens every time I change channels and is consistent. After the top backlights come on the picture is good.
    I think there are only 4 sets of backlights in this tv, do you think it’s the top row failing or a panel issue or panel driver
    problem? Or am I totally wrong?
    Many thanks for any help.
  • Davi.p
    Hobbist Tech
    • Sep 2009
    • 4542
    • Italy - Milan
    The fault is 80% the top led bar, the rest is the bar connector, and the led driver if each bar has its own driver (bad diode contact, bad final electrolytic)
    • Runlinc
      • Apr 2021
      • 28
      • England
      Many thanks for your reply, I will investigate further.
      • osrex
        LED DRIVER KEEPS DYING
        by osrex
        Hello, this is my first post and im just a beginner, so be easy on me guy. thanks
        i have a LED chandeilier that switches colors from white to cool white to warm when toggling the switch, it has 24 LED arms, each arm is 30 CM length.
        i have no datasheet at all for the LED lights, all i have is its length.
        long story short, testing the chandelier on the ground, and it works fine for 1 - 2 - 6 hours, no problem.
        as soon as i fix the chandelier to the ceiling and bury the driver inside the hub,...
        05-05-2025, 03:36 PM
      • Spongebob89
        LCD Backlights Driver - Unknown Component
        by Spongebob89
        I have an "LCD Backlights Driver" and it is not working. After measurments and checking the routes of the PCB I beleive that this component on the red circle is a choke for filtering the supply voltage and block noise from the inverter to go back to the main board. When I measured in ohm and in diode mode with multemeter shows always OL. I shortcircuit this component and it worked. The current that I measured with multemeter is 550mA, so I want rated current 1,5x550mA=825mA~1Α. Am I right that this is a choke and if yes what value do you beleive is (maybe 15uH or the...
        07-22-2023, 02:59 AM
      • howardc64
        Vizio E55-F1 dark backlight zones. LED failure or Dimming Zone Driver?
        by howardc64
        Problem
        Fixing a dimming zone TV with LEDs not lighting up. Dimming zone circuit introduces added variable to diagnose LED and/or Dimming Zone Driver board? Some 1/2 rows of LEDs appears to be out in active dimming zone off AND some brightness flickering with active dimming zone high while playing changing video
        Model & Board Pics
        Conflicting Spec
        Vizio indicate this TV has 10 dimming zones. However, LED strips and Zoned light driver connector suggest 12
        https://www.shopjimmy.com/vizio-gj-2k1...
        10-10-2024, 01:16 PM
      • charif
        Audio Driver for Thomson P14C4BK128
        by charif
        Need Audio Driver for Thomson P14C4BK128 (Windows 10/11)
        I'm looking for help finding the correct audio driver for my Thomson P14C4BK128 laptop.
        The sound is not working properly, and I believe the audio driver is missing or not installed correctly.
        Here are the details:
        • Model: Thomson P14C4BK128
        • Operating System: Windows 10 64-bit
        If anyone has a working link to the driver or knows where I can download it, I'd really appreciate it.
        Thanks in advance for your help!
        04-30-2025, 05:41 PM
      • Chrissygizmo
        Hitachi 50hyt62u-k tcon or driver boards ?
        by Chrissygizmo
        Hi everyone.
        This is my latest problem, I have a Hitachi 50HYT62U-K tv. I was informed off the previous owner that it had been squirted with water.
        I originally thought it was going to be a right off and I would be stripping it, but I've messaged around with it and I've had a good picture on it earlier.
        I have got the problem down to either the tcon board, ribbon cable or driver/buffer board (Not sure what they are called) . I have messed around with it with hammer hands & I've managed to snap 3 of the clips that keep the ribbon cables in place...
        03-24-2021, 10:34 PM
