Panasonic TH-42PZ77U 7-Blinks
  • canadaboy25
    What is normal?
    • May 2013
    • 509
    Hello I have a Panasonif TH-42PZ77U plasma TV and it is giving the 7-blinks of death.
    When I disconnect the SU and SD boards I still get the 7 blinks and the TV won't turn on. When I dissconnect the SC board I get the same thing.
    Would this mean that either one of my logic boards are bad? If so is there any way that I can fix it?
    Thanks for any help.
    canadaboy25
    -Sometimes the light at the end of a tunnel is an on-coming train
  • canadaboy25
    What is normal?
    • May 2013
    • 509
    Re: Panasonic TH-42PZ77U 7-Blinks
    I followed the attached troubleshooting guide and narrowed the problem down to my D-board.
    Is there any way I can fix this board?
    canadaboy25
    • Andre Gilbert
      by Andre Gilbert
      11-20-2024, 08:52 PM
    • AquaMan Ua
      Problem with PANASONIC CF53 laptop after changing BIOS settings
      by AquaMan Ua
      Hello. I am asking you for a hint on how to solve the problem with my touchbook Panasonic CF53-2 standart model. After setting up the BIOS, the laptop displays the wrong image until Windows loads. (More precisely, it displays, but distorted, instead of the Panasonic image immediately after turning it on, it displays what is in photo #1 in the attached file) Then the image appears when Windows starts loading and then there are no problems with the screen until the reboot. If you enter the BIOS, just a black screen. If you connect an external screen, the image on it is the same as on the built-in...
      05-17-2025, 09:40 AM
    • MikeSantos
      Panasonic TX-P42VT30E 7 blinks of death
      by MikeSantos
      Hi,...
      I am just triying to fix this Panasonic. I will tell what I have done until now.
      I have checked the SN BOARD and I found some Transistors shorted and I changed them all.
      At the same time I saw that the PSU is also broken as it blows the T4AH250V FUSE. So I will have to change the 2 R6015ANX MOSFETs, so I need to buy them on internet because here I could not find them
      I am confused about fixing this Panasonic. What I know is that the SN BOARD is not in Shorted if I check the main source connector. I also checked all the connectors...
      01-21-2021, 12:42 PM
    • stecos
      Panasonic Plasma main board repair (ST30 GT30 VT30 ST50 GT50 VT50),LED with 3 blincks
      by stecos
      Hi everyone!
      I happened several times, in the search for help from the web, to consult this very interesting forum.
      So I decided to sign up and I intend to participate actively by making available my knowledge and experience on the subject, I'm a new user but at the same time I'm old in the sense that I have 4 decades of experience in repairing and designing electronics but above all I'm a great passionate about the subject.
      Having said that I come to the gist of my post on the forum as the title suggests.
      For my passion for technology I'm now collecting several...
      11-28-2022, 11:39 AM
    • aa10aa10
      Panasonic Toughbook CF-33 mk1 BIOS repair
      by aa10aa10
      Good day,
      I have tried to remove BIOS supervisor password from Panasonic Toughbook CF-33 mk1. Model number CF-33AENABTG, unfortunately I don't have any other info.
      I read the BIOS using afuwin, edited it and tried to flash new edited BIOS using afuwin. Unsuccessfully. Afuwin showed "Error: Problem erasing flash." starting with 0x00040000 and stoped. Then I tried many other options to flash BIOS from Windows without any luck. Finally i rebooted the device - and no post. Afterwards I have read the corrupted bios chip (MX25L12873F) using EZP2010 programmer....
      01-21-2025, 06:13 AM
