JVC LT-43CA790A panel issue
  • sordids999
    • May 2013
    • 2161
    • uk
    Hi
    Tv turns on and shows these images if I remove the tcon ribbons each side I'm still getting this both sides
    Panel issue ?
  • EazyBone
    • Jun 2023
    • 1362
    • United states
    I've seen quite a few of these jvcs (haven't fixed any) and suspected they have TCON failure frequently but couldn't find any replacements. Curious also.
    • Kikerumbo
      Mi Curved Gaming Monitor 34" - Horizontal lines
      by Kikerumbo
      Thanks in advance for any help you can provide.
      I have a Mi Curved Gaming Monitor 34". A few weeks ago it started to show (or not showing) horizontal lines. Of course, it's outside of the warranty period.
      After some hours of reading and watching videos I disassembled the monitor and checked the ribbons that go from the TCON board to the panel PCB. If I disconnect the ribbon for the right side of the panel, the other half shows a perfect image. I ordered a "new" TCON, installed it and the issue persists so that tells me it must...
      03-14-2024, 02:48 PM
    • rimwall
      Sony KD-65x7500D - double image - Tcon or Panel?
      by rimwall
      This TV was showing a fine image and pulsing with a partial double image (offset vertically) every few seconds. I taped 8 clock pins on one ribbon cable from the Tcon to the panel. It stopped the double image, but some pulsing in intensity was still visible. I then taped another 8 clock pins on the same ribbon cable and the image is now ‘fixed’. Although I understand this results in some loss of resolution, presumably because the clock signal degrades as it passes horizontally across the screen.
      I am wondering - do these symptoms and ‘fix’ mean that it’s a Tcon fault or...
      11-18-2025, 02:09 AM
    • iglitare
      Sony KD-75XF9005 grey Picture but Sound. TCON or panel?
      by iglitare
      i want to repair a Sony KD-75XF9005 TV that initially only showed a grey picture.
      Backlight seems to work, Sound (Setup menu after reset) works.
      If i dissconnect the left FFC cable from TCON to panel i have half a screen on the right. If left cable is connected always only the grey screen.
      Interchanged the cables, its always only the right side that is working. Always grey if left side is connected.
      With my small knowledge i would think at least the cables are good.
      Can this happen because of a bad tcon board?
      Or is it always a bad/shorted...
      09-04-2025, 07:13 AM
    • NWArkGuy
      Samsung UN65TU8000 - Panel Issue [ hole in ribbon cable ]
      by NWArkGuy
      Well, I will be the first to admit that I screwed up...
      In attempting to replace the backlight in a UN65TU8000, I made a hole through one of the ribbon cables between the board that runs along the bottom of the back of the TV and the panel. This lead to a between a 1/4 to 1/2 inch vertical stripe running the full height of the image.
      I don't have the experience; personally, to solder a bridging wire for the paths that were cut. So, I have been on the hunt for other Samsung TV's of similar size.
      I have 2 that I have found and have in my possession. ...
      10-12-2023, 10:13 PM
    • mmartell
      General Questions on the Relationship Between Mainboard, TCON and Panel
      by mmartell
      My goal here is to be able to use boards on hand to swap into faulty sets when the faulty board is not obvious.
      I will start by asking what is the format of the output from the mainboard and is it generic in any way or does it vary by manufacturer and/or model ?
      And as far as I know a tcon and panel must be a matching pair because the timing of the signals and the voltages required to drive the panel are specific to the panel itself. (That may be a blanket statement that isn't true in some cases where the panel creates its own sub-voltages on its panel boards?)...
      01-06-2024, 01:32 PM
