Trying to source 2SJ655
    Anyone got any good sources?
    2SJ655 - P-channel 0.1 ohm Logic Level 100V
    For a Sharp LC-52XL2E
    This part is surprisingly difficult to substitute. I found a close match - IRF9540N - but it has more than double the gate charge.
    Logic level isn't particularly critical.
  • R_J
    • Jun 2012
    • 9625
    Re: Trying to source 2SJ655
    http://www.utsource.net/ic-datasheet...5-1869776.html
    http://www.digikey.co.uk/product-det...052-ND/2165237
    I order from UTsource.
    It does'nt seem that hard to locate, or am I missing something?
    • selldoor
      Slow Learner
      • Dec 2010
      • 7870
      Depends on what you mean by good sources - they have them here
      http://www.chsinteractive.co.uk/elec...fet-to-220.htm
      Reliable source but post is expensive - dont know how the start price compares.
      • R_J
        • Jun 2012
        • 9625
        utsource is just under $2.00 each and shipping $2.00 $4.00 usd
        • tw2005
          • Oct 2011
          • 6458
          not sure if this helps,
          http://alltransistors.com/mosfet/crs...136&caps=to220
          • ecking767
            • Oct 2009
            • 492
            http://www.ernestos-electronics.com/...cement-mosfet/
            2 for $6.00 shipping is $2.50
              Thanks for all the links. I think I'll order the part from that US site. I did not think to check there.
              • tw2005
                • Oct 2011
                • 6458
                Wow. Is postage that rich at CHS?
                That always frustrates me when you have to go O/S because it's either unavailable or uncompetitive locally.
                  It's about £8 postage so in total more than double the US cost, ridiculous.
                  CHS have always been a laugh on prices; you can buy power boards etc for 32 inch TVs for over £300 there, for example.
                    Originally posted by ecking767
                    Didn't know you sold parts. Ordered.
                    • Lvsitano
                      Asus X532FL 3.2V at source and gate
                      by Lvsitano
                      I am having some trouble with troubleshooting a Asus X532FL rev 2.0 motherboard, which does not power on. So at the first MOSFET, I am getting 19V at the drain, and then 3.2V on both gate and source (compared with ground). Of course, the 2nd MOSFET's source will have 3.2v at source.
                      First MOSFET is a QM3056M6 and 2nd MOSFET is a QM0930M3
                      I already checked first MOSFET and source and gate are not shorted (drain with source not shorted either). Also I have 1.7V at the LDO rail (measured at the keyboard connector, as the power button is on the keyboard).
                      First...
                      06-26-2024, 02:13 PM
                    • ohren
                      Upgrading a Samsung ue55nu7096u with logic board from an ue55ru7105k -- good idea?
                      by ohren
                      I hope this is the right forum to post in despite not technically being a repair, but still a question of swapping boards.
                      I thought I'd explore the possibility to upgrade an existing working Samsung ue55nu7096u with the logic board (and power board if needed) of a newer model (ue55ru7105k) of the same size and appearance (and resolution). The reason being I'd like the extra inputs of that board including component in, an extra HDMI port and bluetooth. Its panel is broken so I have no use for the board otherwise.
                      The models launched in 2018 and 2019 respectively....
                      09-08-2023, 05:24 PM
                    • korben_dallas
                      Will I have a bricked logic board after reflow of the GPU v-core U8900 chip on my Mid-2012 15" Retina Macbook pro?
                      by korben_dallas
                      Hi everyone! I'm trying to fix my black screen / failed U8900 GPU v-core on my Mid-2012 Macbook Pro 15" Retinaby doing a rework/reflow of the chip (once I determine that's the real issue; but it likely is).
                      I've been disabling the GPU in NVRAM for a few years... but it's just time for a better solution.
                      I'm new to soldering but the only feasible way to fix this issue is to do something myself.
                      MY QUESTION:
                      I've been seeing some people (on this forum mostly) run into issues with the logic board needing a serial number or it being deactivated (?)...
                      02-14-2024, 12:23 AM
                    • Yanleb
                      LG 60PK550 Logic Control Board EBR63450301
                      by Yanleb
                      Hi all, I just want to share the repair of my 60PK550-UA TV set.
                      The TV set was powering on, just no image. After verification, nothing wrong on the YSus or ZSus boards. Nothing wrong on the main board either.
                      But I noticed that the LED was not flashing on the Logic Control Board. This is an EBR63450301. The LED is supposed to flash even with all the flat cables disconnected, with only the power cable attached.
                      All the voltages measured at the electrolytic capacitors on the board were good. From top left to bottom right:
                      C57: 3.30V
                      C61:...
                      07-20-2023, 12:38 AM
                    • mferna14
                      Logic Board 820-00840-A Missing EDP_BKLT_EN
                      by mferna14
                      Hi dear friends., I am working on a Apple MacBook Pro A1708 , Logic Board 820-00840-A that has no backlight. The logic board powers on fine, but no display. After Checking on the backlight driver chip, I found that the EDP_BKL_EN is missing. And this Power Enable comes from the PCH. So does this means this Logic board cannot be repaired & brought back to life again? The resistance from GRD to the test point of EDP_BKL_EN is around is 0.66M ohms. R8442 (0ohms) is ok. Any suggestion/Tip if any would really appreciate. ​
                      07-10-2024, 05:18 PM
