Philips 42PF9631D/37 Plasma dead
  • CraigR
    • Dec 2013
    • 969
    Hello all! I have a Philips 42PF9631D/37 Plasma dead. I opened it up and found only 1 cap that looked visually bad and replaced it with a good low ESR cap (see pic) Now when I plug it in I hear the click and the light on front is green then I go to turn it on and it turns to red and flashed 7 times over and over again. I looked on the forum before posting this and found a similar problem however my power board does not look the same as what he had. I have a picture of the same board I have. Not sure if I need to start pulling caps and checking or what.
  • CraigR
    • Dec 2013
    • 969
    Re: Philips 42PF9631D/37 Plasma dead
    Well I have it running now, I replaced the capacitors around the big one I seen bad and it seems to be working now however it looks like a light "snow" in the picture could this be more bad caps?
    • CraigR
      • Dec 2013
      • 969
      I adjusted all the picture setting and got a little better but still there. I ran HDMI from my computer to it and put a blue screen on and as you can see from the picture on the right the little white dots. The wavy lines on the left are not actually there must be my camera making them.
        You need to locate the VSET voltage on the power supply and drop it by around 10 to 20V.
        • CraigR
          • Dec 2013
          • 969
          Ok Tom, I found Vset on a connector and it reads 197.3v and I found a POT marked Vset is this where to adjust? also seems wicked high if it's to only be 10-20
            Vset is different from Vs. Is there a pin marked Vset on the connections going off to the X- and Y-main boards (the right and left boards respectively.)
            • CraigR
              • Dec 2013
              • 969
              Just made an edit at same time as your post. please re read the above.
                Vset needs to be dropped by about 10 to 20V. Not around 10 to 20V. Sorry for the misunderstanding. Vset is normally around the 200V range, that is absolutely fine.
                • CraigR
                  • Dec 2013
                  • 969
                  Took it down to 173v (low as the POT goes) and same thing.
                    OK, may need to adjust Yrr and Yfr on Y-main board... can you supply a photo of that board?
                    • CraigR
                      • Dec 2013
                      • 969
                      Kind of new at plasma TV's so to save time can you point it out on this pic Tom?
                        Hard to tell with all the metal framework in place, but I think this is the y-main.
                        • CraigR
                          • Dec 2013
                          • 969
                          Looks like a major pain to get the supports out of the way.
                          • CraigR
                            • Dec 2013
                            • 969
                            Ok looks like half the tv needs to come apart so before I do that are you pretty sure this will fix it? with all the stuff coming off to get at it I don't think I will be able to power it on after I get down to it.
                              Never sure with sparklies, unfortunately. They cannot always be fixed.
                              It would need to be powered on while you adjust it to observe the image.
                              • CraigR
                                • Dec 2013
                                • 969
                                Ok, tore it down and here are 2 actual pictures and a better one I got off the web but it's the right board.
                                  You would need to try adjusting the points marked Y-RR and Y-FR on the board. First try Y-FR. If you go too far the sparklies will get worse so when you see this, reverse direction. If that fails, try Y-RR.
                                  • CraigR
                                    • Dec 2013
                                    • 969
                                    WTF??? Got a light and looked real good at board and seen 3 more caps bulged so thought great had to be the problem so took board out and replaced caps and put back in then went to fire up and back to the same problem in my first post. Clicks when plugged in green light then turn on and light goes to red and blinks 7 times over and over. I looked everything over and all wires back on and looks good.
                                    • CraigR
                                      • Dec 2013
                                      • 969
                                      UPDATE: ok, pulled pc and went through some caps again and found another bad one so replaced it and back up again however adjusting the Y-FR and the Y-RR only made it worse never any better. sparkles look green to me.
                                      • CraigR
                                        • Dec 2013
                                        • 969
                                        Well today I went to mess with it again and back to the 7 flashes so could that mean it's in something other that the power board?
                                        • kew1701
                                          Philips taw6205 ambilight speaker STM32 mcu dead
                                          by kew1701
                                          Resolved dead cap which burned mcu(stm32f091rct6) ,between vss and vdd on desoldered mcu is short 5.8oh,is there a way to obtain firmware from it.i have firmware,but i thing this is for wifi/bt board phorus 5 which is on top of amp board(here lies dead mcu)...my stm32 flasher is on the way....
                                          04-09-2025, 03:59 AM
                                        • celiabrown
                                          Issue with Plasma Philips 37inch chassis FTL2.1
                                          by celiabrown
                                          Hello guys,
                                          My Plasma Philips 37inch chassis FTL2.1 does no picture ,and goes into protection mode after 30 seconds (red led blinks at 3Hz).
                                          Can someone has any symptom like this ?
                                          Thanks​
                                          05-09-2024, 10:56 PM
                                        • badcappo
                                          Dead Panasonic Viera TX-P65STW50 Plasma TV
                                          by badcappo
                                          Hello, got a ST50 plasma TV for repair. No signs of life, not even blink codes. Opened it up to check the power supply, type MPF6914. Apparent issues from visual detection and measuring for shorts:
                                          Diode type G972s6 - D101 with a short
                                          Mosfet 06N90E - Q301 shorted
                                          Fuse T5AH 250V - F103 blown
                                          Diode D301 shorted
                                          Relay DG1U-17VDC II - RL001 blown
                                          I have not found a circuit diagram. Maybe someone here already dealt with a similar issue? Thanks for tips where else to check 😀...
                                          11-24-2024, 11:27 AM
                                        • Super360
                                          Samsung PLASMA PN50B530S2F DEAD
                                          by Super360
                                          Hi everyone I have this plasma here that has no standby light and is completely dead. I opened it up to see extremely dirty and dusty to which I cleaned but made no difference. So I checked all fuses good. I checked the standby voltage 5 volts good. Then I did that plasma control board test by shorting the pins(THANKS 2 TVTIMMY) and the tv actually turned on and made a sound. Does this mean I need a new motherboard?...
                                          12-16-2021, 09:25 PM
                                        • Rubenlily
                                          Philips 50PUS6503 - dead panel? Picture
                                          by Rubenlily
                                          Hey,
                                          I gave up on my last TV and got a new one to try.
                                          Only vertical lines. Sound is OK. Screen is black with a few white lines until I change channel, then these colors gradually starts filling up the screen.
                                          Is this fixable in any way or should I just give up on this one too?...
                                          08-21-2023, 01:07 PM
