RCA Projection TV Blurry Picture
  • Thorerik
    • Jan 2014
    • 5
    RCA Senium rear projection Model HD61W140 Chassis ATC311. Cannot complete auto convergence. I get a message that a sensor failed. The picture is a blur across the entire screen. I do not have a service manual. I can get to the service menu but cannot read it due to the blur. It is an old TV but had a great HD picture when operating properly, Any ideas on what to do?
    Thanks,
    Thorerik
  • freakaftr8
    • Oct 2012
    • 3743
    Re: RCA Projection TV Blurry Picture
    You could start by removing the screen frame and cleaning the mirror and lenses.
    • R_J
      • Jun 2012
      • 9558
      How is the overall convergence? are the red & blue lined up with the green. If its a convergence issue there could be a open fuse neer the flyback caused by broken solder connections on the flyback transformer.
      • Thorerik
        • Jan 2014
        • 5
        I looked around the flyback and didn't see anything obviously fried. The overall convergence is off on the entire picture. When looking at an active TV broadcast channel you can see the representations of the red, blue and green images.
        I guess what I really need is a Factory Service Manual for this model (free if possible). Can anyone help me?
        Thanks,
        Thorerik
        • R_J
          • Jun 2012
          • 9558
          There are 3 fuses near the flyback transformer (I believe they are brownish color) one of them could be open.
          I found this that might help you http://www.ifixit.com/Guide/Repairin...vergence/12179
          • RON_CET
            • Jun 2012
            • 217
            thats for a ITC222 chassis Thorerik has a ATC311 there not same chassis
            this link might give you some help
            also the service manual is on RCA cd-rom disc and you'll either have find a pdf dump of the disc or a RCA ATC311 cd-rom disc for servicing schematics or alignment data
            go here for service manual
            Ron Driver,BSEE,CET,ISCET,NESDA
            • R_J
              • Jun 2012
              • 9558
              I don't have access to the rca manuals right now so I could'nt cross the manual to the chassis.
              I did'nt work on that model very often, most likley on convergence board, check if there is +22 and -22 volts on J19700 if its there, check the transistors on the convergence board. I seem to remember replacing parts on this board.
              • Tr0ll
                by Tr0ll
                Original T-con:
                First replacement T-con:
                10-07-2023, 07:48 PM
              • JJAAMM
                by JJAAMM
                Problem
                07-06-2023, 06:01 AM
              • TR103
                by TR103
                - it keeps rebooting
                01-22-2025, 04:12 PM
              • Mgiffune
                by Mgiffune
                06-09-2024, 10:28 AM
              • rtstorm
                Philips 55PUT4900 picture lines and blur
                by rtstorm
                Hello, i got this TV that have a washed out picture with vertical lines. Can this be a T-com issue or the LCD panel is gone? Does any one of you guys have this kind of issue. This one i specific for me because it have blur image and vertical lines....
                10-13-2021, 06:23 AM
