samsung 58 inch plasma
    Re: samsung 58 inch plasma
    ZD2001? That isn't a fuse unfortunately. F2000 is, though.
      dam i thought i was on to somthin i have it span round and just the power plugged in im only getting 1.5v in some places though
        Any places to check on the back ?
          Nothing stands out, but I do have one other thing to check. Can you get a picture of the connection area around the white ribbon cable going into the X-main board? It runs from the control board.
            Just here ?
              I'm interested primarily on the X-main side but that ribbon yes. The X-main side could have some test points.
                Here?
                  any ideas i aint
                    i might have a bit of info i have a t con board from a 50 inch its not the same but close so i plugged it in and tried it .now when i got the tv it had a fried data ribbon from the t con to the y main so i bought 2 i plugged it in and as soon as i did the t con fried the data ribbon or started too again ?
                      Just a bit busy right now with coursework, I'll try and update later.
                        ok no problem
                          Any more ideas
                            I didn't see your post; thought you had not responded. Do you still have the scope?
                              Yer I loaned it on the never never ha ha
                                OK, leave it at 10ms/div but set it to 1V/div.
                                Take a picture of the waveform you see on each point.
                                  This must be a common problem because I have just got 2 50inch plasmas with the same problem
                                    Tom just testing the points now ill start left to right with pics
                                      Here goes
                                        No 2
                                          Nothing from pin 3
