samsung 58 inch plasma
    Re: samsung 58 inch plasma
    getting the same reading from the top pin on the black connector
      View My Video
        OK, now try without buffers; any change? Y-main is looking bad.
          I'll have to check it tomorrow I'll do it as soon as I finish thank you for your help so far mate its very much appreciated
            Can they be fixed ? Also would that transitor being slightly different make any difference
              Without schematics, you're likely to spend a lot of money and time fixing it. Beyond my time, at the moment, at least; you're free to try yourself. The X-main should be checked next, I'll attach an image when you're ready.
                Checked the board with out buffers and readings don't change
                  Will check X-main tonight, when I get back from uni.
                  Just for comparison, here's a Y-sustain(=Y-main) output test on a Fujitsu/Hitachi plasma panel I was testing: http://www.youtube.com/watch?v=nGr5ydz9gTk&t=3m10s
                    Hi mate just tried it on the same blue thing on the x main and got a much better reading
                      any more checks i could do on the y main ?
                        Could you show X-main waveform.
                          Here It goes up and down a bit though
                            Still doesn't look right - show me where you're probing please.
                              The blue one like the other side
                                Which lead of that; top or bottom?
                                  top
                                    The wave should look better if X-main were working, then.
                                    Check that the X- and Y-main boards are both getting Vcc.
                                    Could be a bad control board.
                                      i think it might be the control board too there is a glass fuse on it thats only got power to one side nothing at all to the other just where the power comes into it i was just going round it before just checking everything if that makes any sense ??
                                        Where is this fuse?
                                          Here I just took it off to have a look at the back
