samsung 58 inch plasma
    Re: samsung 58 inch plasma
    One scope will try when I get in what I need to do
      As long as that's capable of measuring up to 400V, it should just about be usable. Though, if they have an analog unit like this:
      https://www.google.co.uk/search?q=an...=1920&bih=1099
      it could be more useful.
        This is what it can do
          Yep - looks OK - just make sure to get a probe with 10X capability (ideally, 10X probe.)
          The 10X divides the 400V by 10 times giving 40V which won't damage the instrument.
            right how do i work this probe ?
              Picture of it?
                This Is what I have
                  Is 1X or 10X printed on that probe?
                  If you use 1X probe, the instrument might be damaged.
                    it says vp510 on one and 10:1 200mhz on the other also says 1000v on the black part of the red stick
                      then says 500v in the red stick that was not connected
                        10:1 is what you want. Same as 10X. Closer pic of that one?
                          Yer it says
                            Turn unit on, and see if you can figure out how to turn channel 1 on, set to 10V/DIV (with 10X probe makes 100V/DIV) and 10ms/div time.
                            I didn't see it before but it's a scopemeter, a nice bit of kit. Not used one myself, so would have to find manual.
                              its from our other place in finland so our place wont miss it too much !
                                Like that ?
                                  You should press V/mV until the display at top shows 10V DC for CHANNEL A. Then press "NS S" to select 10ms (do not mix up with 10ns or 10us.)
                                    Like that
                                      Yes, then press vertical MOVE until line centred in middle of display.
                                        yes done
                                          what next
