Sony KD 49X8307C
  • Donny2derby
    • Apr 2023
    • 228
    • Uk
    #61
    Originally posted by Diah
    hahahah,,,, thats cool... nomoresonys on the last list
    Yes but only for now! He hasn’t made fun of my soldering skills and has offered solid advice on using resistors instead of copper wire and how to test diodes properly.
    You were top of list Diah until you took the piss out of my solder work😅
    • Diah
      • Feb 2013
      • 6435
      soldering need 2 things almost... stable hand ( not fat arm man ) and good eyes sight. the reset what to use or how to use just belong to soldering man creative mind.
        • 12276
        • U.S.
        #63
        I can't win this contest, can't concentrate. I'm here in central U.S.A. in late winter but in my mind I'm on the beach in Maui with my toes in the sand and a drink in my hand.
        • Donny2derby
          • Apr 2023
          • 228
          • Uk
          #64
          Ok lads. I’ve removed the dodgy links and solder and cleaned the board up best I can. Some small damage to one of the tracks but fortunately it’s to the pin which isn’t connected to anything.
          When micro solder tips get delivered tomorrow I will bring them into work and attempt more professional install.
          • Donny2derby
            • Apr 2023
            • 228
            • Uk
            #65
            Ok lads the micro solder tips arrived and I have made a more accurate job of linking the pins advised.
            i will take the board home tomorrow morning, plug it all back together and try it.
            Does this look more suitable Diah?? nomoresonys thanks for the tip about using resistors for the links!
            What should I expect to happen now then Diah? Should I get 12v on T-CON fuse? Should the panel come on?
            Im hoping to watch the boxing on this tonight at work so the pressures on now😄
            • Diah
              • Feb 2013
              • 6435
              first don't put the PSU IN TV... keep it out side alone on the table.. just plug it in wall and measure V DC the 12 V with reference to GND,
              we need to be sure there are no damage happened to the PSU....
              Click image for larger version  Name:	IMG_1911.jpg Views:	0 Size:	559.5 KB ID:	3231145
              • Donny2derby
                • Apr 2023
                • 228
                • Uk
                #67
                Ok Diah. Happy days. All 12v pins you asked me to measure to ground give the 12v!
                Please advise of next steps. Exciting.
                And for next time, to assist my own learning and knowledge. Is what we did a fairly common fault finding procedure which can be carried out on most PSU?
                I appreciate what you asked me to perform must be a very simple procedure for you and you must get bored of telling people to do the same easy stuff over and over so I want to be able to carry out the simple stuff for myself which will help me with my own understanding of how things work.
                Thanks.
                • Diah
                  • Feb 2013
                  • 6435
                  Thanks God yours PSU still a live. so now remove all 3x R you added... clean the points and fit the boards back to TV chassis with screw.
                  some things to explain about the PSU sockets which connect to Mainboards ... to avoid any mistake by yours side.
                  you have 2 row of the sockets.. the down one "Red color line" are Odd numbers ( 1-3-5-7-9-11-13-15-17-18-21-23-25-27 )
                  the one on the Top "blue color" are even numbers ( 2-4-6-8-10-12-14-16-18-20-22-24-26-28 )
                  the yellow circle are the clip of wires which make it hold at he sockets hole .. ( by pressing it down we can pull " slide out " the wire from it place if it need at testing )
                  from perverse testing you reported there are 0V on T-CON Fuse .. however you test just now the PSU generate TCON_VCC12V just now... ( it mean the Mainboards didn't send signal to T_CON_ON pins )
                  there for we will going to help the TV with way to trick the PSU to send 12V to T-CON
                  A- all sockets LVDS should be connected as original.
                  B- slide out the wire of T-CON_ON from the socket ( on the top row pin No 24 ) , be sure the end of the wire isolated to avoid it make contact to chassis or any other place ..
                  C- Insert in the sockets hole 1KR between top row Pins 24 & pins 9 at the low row )
                  plug in the TV and power it up. , check the screen and the t-con fuse if there 12V on both side with Ref to TV chassis.
                  • Donny2derby
                    • Apr 2023
                    • 228
                    • Uk
                    #69
                    Ok Diah thank you for this help and knowledge. Is girlfriends birthday today so I will carry out as you ask tomorrow and report back.
                    • Donny2derby
                      • Apr 2023
                      • 228
                      • Uk
                      #70
                      Diah the removal of the core you told me to remove is not particularly easy. The smallest screwdriver I have to hand at the minute isn’t small enough to make a firm contact with the yellow clip which releases the core. I’m trying to remove it whilst pushing down on the yellow clip but it’s not coming out easily.
                      • lotas
                        • Jan 2016
                        • 4749
                        • Russia
                        #71
                        You don't need a screwdriver here; use a needle, awl or a sharp thin knife to pry the tab (latch) up and pull out the wire.
                        And there is no need to press anything.
                        • Donny2derby
                          • Apr 2023
                          • 228
                          • Uk
                          #72
                          Thanks lotas. I’ve managed to get the core out now. Just rigging up a link from 24-9.
                          • Donny2derby
                            • Apr 2023
                            • 228
                            • Uk
                            #73
                            Ok I have performed the test as you describe Diah and sadly there is no life on the screen and also no 12v on T-con fuse.
                            What I don’t understand though is, there are 4 cables running from CN6401 to the T-con board. 3 grey wires and 1 white.
                            The core 24 I removed from CN6401 is black and also so is core 9. So that wouldn’t force 12v onto T-con would it?
                            • Diah
                              • Feb 2013
                              • 6435
                              What I don't understand though is, there are 4 cables running from CN6401 to the T-con board. 3 grey wires and 1 white.
                              The core 24 I removed from CN6401 is black and also so is core 9. So that wouldn't force 12v onto T-con would it?
                              yours jumpers between 9 & 24 didn't make contact with sockets pins inside...... or the TV are off not ON
                              to know its ON.. pin 9 should have about 3.3V
                              • lotas
                                • Jan 2016
                                • 4749
                                • Russia
                                #75
                                Without a motherboard, nothing will run, no autonomous system will work here (this is Sony), all commands are executed by the motherboard.
                                • Donny2derby
                                  • Apr 2023
                                  • 228
                                  • Uk
                                  #76
                                  I have a bench power supply at work Diah. Shall I take pin 9 out of the plug and use the bench power supply to put 3.3v DC on it?
                                  • Diah
                                    • Feb 2013
                                    • 6435
                                    what?????? bench power supply ?????????
                                    did you read my post 58
                                    • Diah
                                      • Feb 2013
                                      • 6435
                                      yes... i think he still didn't bring all together back
                                      • Donny2derby
                                        • Apr 2023
                                        • 228
                                        • Uk
                                        #79
                                        Post 58 is a post of mine Diah. 68 I did read. A bench power supply is something that you can use for the purpose of voltage injection.
                                        • Donny2derby
                                          • Apr 2023
                                          • 228
                                          • Uk
                                          #80
                                          Everything is plugged back in and screwed down.
                                          • x_orange90_x
                                            Sony KD-75X750H no backlights
                                            by x_orange90_x
                                            I just removed the back cover to test the backlights because when I first plug it in it will flash once and then start dark but I can see the image. I got 131v on string 1 and 167v on string 2. Usually when I get a bad set the meter reads 300v and they won't light up. When testing, each set lights up inside the tv. When I plug in the power and check the leads with my multimeter both strings are only about 3v.
                                            Does this difference in voltage between the strings indicate that the lesser has bad LEDs? Or is it normal that they are not the same voltage? I've read some about this tv and...
                                            07-16-2025, 07:49 PM
                                          • Carlos#2003%
                                            Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
                                            by Carlos#2003%
                                            Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
                                            02-15-2024, 07:52 PM
                                          • dkneyle
                                            Sony KDL-46HX850 Can't upgrade/update firmware
                                            by dkneyle
                                            Diagnosed this TV as having a failed main board which I've replaced with one from a KDL 55HX850. They are (supposedly) the same board.
                                            Being 'Smart TV' it requires a firmware reboot when you swap out boards such as T-Con or main board. It starts with a black screen and flashing yellow and green LEDS, indicating it needs that firmware boot. The procedure described all over the web is to put the software into the root directory of a FAT32 formatted USB drive and it should load that up once plugged into USB1 port. But not for me. I can see the LED on the USB chip flash for about...
                                            09-25-2024, 10:44 PM
                                            Sony VAIO SVF11N1L2E Hybrid (2-in-1) Fit multi-flip Specification for Upgrade or Repair
                                            This specification for the Sony VAIO SVF11N1L2E Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SVF11N1L2E boardview and SVF11N1L2E schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                            09-06-2024, 05:27 AM
                                            Sony VAIO Duo 11 Hybrid (2-in-1) Duo 11 Specification for Upgrade or Repair
                                            This specification for the Sony VAIO Duo 11 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Duo 11 boardview and Duo 11 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Sony VAIO...
                                            09-06-2024, 05:30 AM
