Sony KD 49X8307C
  • Diah
    • Feb 2013
    • 6613
    you measure before the LED socket and reported 3V AC,,, this is wrong with TV repair always we measure V DC. with references to TV chassis
    so put your DM ob V DC and fix it t the pin of the sockets at power bards side BL_ERR the no 4 one at the second row , easy to find.... with ref. to TV chassis.... plug the TV in wall to power it up... read the low and the high value it show on this pins and report back
    • Donny2derby
      • Apr 2023
      • 228
      • Uk
      Diah wtf man. How am I supposed to get my pin on the 2nd row of that connector? If you want me to get it with the plug connected that seems impossible. It’s buried underneath the 1st row of pins.
      Do you want me to measure with the plug CN6401 disconnected?
      • Diah
        • Feb 2013
        • 6613
        the socket should be connected in place ... and the LED BL sockets also should be in place connected
        • Donny2derby
          • Apr 2023
          • 228
          • Uk
          Ok Diah. I have tested to the 4th pin on the bottom row of the plug and I got 3.4v Dc on power up. Instantly and it maintained. With no fluctuations.
          • Diah
            • Feb 2013
            • 6613
            if its hard to you... leave it,,,, as all in connected in place put yours DM on 250 V DC and with reference to chassis measure the low and high at the 2 pints at sockets +OUT1 & 2 oh BL socket
            • Donny2derby
              • Apr 2023
              • 228
              • Uk
              #26
              If I try to plug the female end into the connector and test Diah, the margin of error to potentially short across to other pins is less than a millimetre. This seems impossible.
              • Donny2derby
                • Apr 2023
                • 228
                • Uk
                #27
                Yes Diah is impossible to get meter pin in between top row of pins to be able to test on second row.
                • Diah
                  • Feb 2013
                  • 6613
                  this is the row 1 stand by not the other row LOL
                  • Donny2derby
                    • Apr 2023
                    • 228
                    • Uk
                    #29
                    I have auto ranging DM. I can select DC voltage only. Please give me a few moments.
                    • Diah
                      • Feb 2013
                      • 6613
                      okay,,, when you fix it on one pin power up the tv and check... same way to other pin
                      • Donny2derby
                        • Apr 2023
                        • 228
                        • Uk
                        #31
                        Both pins measure 63v DC to chassis.
                        • Diah
                          • Feb 2013
                          • 6613
                          yours BL seam fine....
                          upload photo of the whole back of TV boards show how they are connected... to drive you for next step test
                          • Donny2derby
                            • Apr 2023
                            • 228
                            • Uk
                            #33
                            Ok Diah here is photos of power board and main board. Please don’t tell me you need photos also of T-con board as this would require me removing bezel etc to get down to backlight panel and that is something I could not do at moment as telly is at home and I would need assistance from someone at work to help me.
                            • Diah
                              • Feb 2013
                              • 6613
                              okay..
                              1- remove the metal cover of the T-CON to have access to T_CON ( don't forget to let the T-CON boards screwed to TV Chassis )
                              2- power on the TV and check if there 12V on F1 Fuse from both side on the T-CON Boards if yes
                              3- disconnect one ribbon cable from T-CON to panel at time and power on the set check if BL come on and the screen show half screen.. do it for both side at time
                              • Donny2derby
                                • Apr 2023
                                • 228
                                • Uk
                                #35
                                Ok Diah I have found F1 fuse on T-con board. Continuity test is good so fuse is ok. Can you point me to where I should be testing for 12v dc? I tried with reference to chassis but this gave me 0v. I want to be sure this is where you wish me to test.
                                Or is there somewhere else on T con board I need to test to?
                                • Donny2derby
                                  • Apr 2023
                                  • 228
                                  • Uk
                                  #36
                                  Do you want me to test for 12v from fuse onto all pins on T-con ribbon cables?
                                  • Diah
                                    • Feb 2013
                                    • 6613
                                    NO
                                    if the fuse to chassis 0V mean mainboards didnt send signal t-con_on... so we need now to do this test
                                    testing power boards and T-CON and panel as standalone
                                    1- disconnect the sockets between Power boards and Mainboards ( from mainboards side )
                                    2- disconnect the 2 LVDS cable between Mainboards and T-CON ( from T-CON side )
                                    3- if you have 1K R use it in case you don't have.. you need to recheck the pins points bellow 3 time to be sure they are correct.
                                    4- we connect
                                    STBY3.3V ----1KR ---- to all together pins POWER_ON & BL_ON & TCON_ON then plug in wall check the screen if iz come on..... and check if there all Volts on sockets REG12V ( 12V) and on T-CON fuse 12V
                                    • Donny2derby
                                      • Apr 2023
                                      • 228
                                      • Uk
                                      #38
                                      Ok I think I’m understanding you now Diah. Keep T-con board screwed to chassis so I can test F1 fuse reference to chassis.
                                      This gave 0v Dc so it seems we have fault here yes? If you can advise of next test I will try tomorrow to follow on. Is nearly 9pm now and I will soon be sending you invoice for overtime charges LOL.
                                      • Donny2derby
                                        • Apr 2023
                                        • 228
                                        • Uk
                                        #39
                                        I don’t have 1k ohm resistor at home Diah. Thank you for your help so far. I will follow this on tomorrow.
                                        • Diah
                                          • Feb 2013
                                          • 6613
                                          you can flip the power boards the pin which always 3-3V are the STBY pin... the others pin easy to locate them as you have the print chart of the sockets at the top of the boards
                                          • x_orange90_x
                                            Sony KD-75X750H no backlights
                                            by x_orange90_x
                                            I just removed the back cover to test the backlights because when I first plug it in it will flash once and then start dark but I can see the image. I got 131v on string 1 and 167v on string 2. Usually when I get a bad set the meter reads 300v and they won't light up. When testing, each set lights up inside the tv. When I plug in the power and check the leads with my multimeter both strings are only about 3v.
                                            Does this difference in voltage between the strings indicate that the lesser has bad LEDs? Or is it normal that they are not the same voltage? I've read some about this tv and...
                                            07-16-2025, 07:49 PM
                                          • Carlos#2003%
                                            Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
                                            by Carlos#2003%
                                            Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
                                            02-15-2024, 07:52 PM
                                          • dkneyle
                                            Sony KDL-46HX850 Can't upgrade/update firmware
                                            by dkneyle
                                            Diagnosed this TV as having a failed main board which I've replaced with one from a KDL 55HX850. They are (supposedly) the same board.
                                            Being 'Smart TV' it requires a firmware reboot when you swap out boards such as T-Con or main board. It starts with a black screen and flashing yellow and green LEDS, indicating it needs that firmware boot. The procedure described all over the web is to put the software into the root directory of a FAT32 formatted USB drive and it should load that up once plugged into USB1 port. But not for me. I can see the LED on the USB chip flash for about...
                                            09-25-2024, 10:44 PM
                                            Sony VAIO SVF11N1L2E Hybrid (2-in-1) Fit multi-flip Specification for Upgrade or Repair
                                            This specification for the Sony VAIO SVF11N1L2E Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SVF11N1L2E boardview and SVF11N1L2E schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                            09-06-2024, 05:27 AM
                                            Sony VAIO Duo 11 Hybrid (2-in-1) Duo 11 Specification for Upgrade or Repair
                                            This specification for the Sony VAIO Duo 11 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Duo 11 boardview and Duo 11 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Sony VAIO...
                                            09-06-2024, 05:30 AM
