Philips 21PT5006/79
  • burntfingers
    • Jan 2011
    • 148
    Philips 21PT5006/79
    Hi, folks.
    I tried to get the schematic diagram for this set at various places but to no avail.
    I was wondering if you did know where to get it.
    Have this dead set, with power supply working and voltage at the collector of horizontal output transistor, but no pilot light on.
    I did check for faulty diodes and the like but nothing - I need the diagram to trace the fault.
    Could you kindly help, thanks.
  • selldoor
    Slow Learner
    • Dec 2010
    • 7870
    Re: Philips 21PT5006/79
    Try searching under chassis number - lots of hits
    • burntfingers
      • Jan 2011
      • 148
      Thank you guys, got it.
      You are such starts; much appreciated help!
      • Andrew F. Ali
        • Jan 2014
        • 2450
        • Trinidad & Tobago
        Check for voltage on the Horizontal Oscillator transformer which would be connected to the Collector of the Horizontal Oscillator Transistor which in turn will switch on the Horizotal Output Transistor. Check for approximately 0.3V or 0.5V on the Base of the Horizontal Oscillator Transistor. If No Voltage at the Base then there is no Horiz Oscillation to trigger Horiz Out Trans.
        • hs5424
          Dynacord powermate 1600 block diagram.
          by hs5424
          Hi All,
          I obtained a schematic diagram for the above mixer but I am wondering if a block diagram exists as I am trying to fix a problem in the protection circuit which I find a little confusing using a circuit diagram only. In the good old days the workshop manuals always had a block diagram with a circuit discription. Very useful for fault finding.
          The protection light is perminently on. The right sode has a -80DC on the feed to the speaker, hence the protection led on. I have removed all the O/P transistors which checked out OK. I tested all other transistors in circuit which seem...
          07-31-2025, 01:35 PM
        • G33RT
          Philips 8200 series 65PUS8204/12 stuck at Philips Logo
          by G33RT
          Philips 8200 series 65PUS8204/12 stuck at Philips Logo, it does not reboot it just stays on the logo.
          It does power up when pressing the power button.
          I already try the power button while plugin the plug with no result.
          Also put the latest firmware autorun-TPM191E_R.001.004.100.000.upg on a MBR/FAT32 USB stick at USB port2 with no result either.
          Could this be an PSU or eMMC issue ?
          07-19-2025, 03:43 AM
        • gabri2211
          I'm looking for the wiring diagram for led monitor model DHI-LM19-L200
          by gabri2211
          hello everyone, I'm looking for the wiring diagram of this led monitor.
          the model is DHI-LM19-L200, but I think that any other diagram of a DAHUA monitor could be equivalent.
          I really hope that among you someone can help me to repair this monitor, the screen is black, it doesn't seem like a backlight problem.
          I see the presence of 12 volts, 5 volts, but without a diagram the repair is very difficult.
          thanks to those who will answer
          12-10-2024, 04:37 PM
        • double_DD
          Philips curling iron - is this a common AC cable?
          by double_DD
          Wife has 2 Philips hair curling irons half defective - after learning how they're supposed to work and testing them, it turned out that both have defective power cables, and both on the same place; broken wires due to wire bending.
          As they were both relatively easy to disassemble, and cables are plugged not soldered (as they can rotate in the handle), I was sure it would be easy to find replacements. But - NO! I'm unable to find anything similar on ebay or Aliexpress.
          Not sure if this is something Philips proprietary, or a standard, but the cable plug...
          08-18-2025, 10:04 AM
        • janos6662000
          Philips 47PFS7509/12 LCD TV problem
          by janos6662000
          Hi
          I have here a Philips 47PFS7509/12 LCD TV which came to me with a weird problem : without signal i could access menu, make a factory reset, access menus, etc.
          When i applied cable signal to check image, i had normal picture, but TV was restarting.
          I downloaded original firmware and applied the update, but the problem remained.
          From a colleague i received a "factory package software" which is a lot bigger.
          I made another firmware update, but still did not solve the problem.
          Somewhere on the way the error got worse, because at the moment the...
          08-12-2025, 12:54 PM
