Asus ROG Strix G17 , Identifying a part number from the boardview diagram ID
  • SilverbackITGuy
    • Nov 2025
    First of all, I hope I got this into the right section. Apologies if I did not.
    I was working on my Asus ROG Strix G17 (2021) G713QM-RS96, and I guess I pre-heated the board too much replacing the DC Jack and one of the small parts came off. I looked for it on my soldering mat, and it was nowhere to be found. So now, the laptop is powered from the new DC Jack I installed, but it will not charge the battery from that jack. Only powers the hardware.
    I looked at the boardview diagram in another post for the G713QM, and it looks like the diagram displays it as X450, a 4 contact IC on the edge of the board next to the DC Jack.
    Can anyone tell me how I can look up a part number for the missing piece using the ID from the boardview diagram? I did electronics years ago, and it was really basic. I am not educated on using boardview diagrams and how to cross reference the ID on them to a part number that I can order from an electronics vendor.
    Thank you for any help that can be given.
  • khaahk
    • Dec 2013
    • 827
    • Estonia
    From G713 boardview it seems that X450 is crystal oscillator for lan card - it should not affect the charging but the lan card will not work without it.
    Adapter power might be detected by pin 9 - going to R6003 on the other side of the board.
    • SilverbackITGuy
      • Nov 2025
      Thanks for that info.
      I don't use the lan card ever. Just the wifi. So that might not have been found. I probably need to replace that too in case I need hardwired LAN connectivity. Do you know what that part number is?
      I will also check pin 9 and make sure the solder joint is good and solid. will let you know if I find that was the cause.
      thanks again.
      • Mdink
        Schematic diagram for clevo w65jo and board part-number 6-71-w65j0-d01
        by Mdink
        Hello, I need help me with schematic diagram for clevo w65j0 and part number 6-71-w65j0-d01.
        07-10-2025, 11:35 AM
      • SJones88
        Asus M6500XV laptop boardview / schematic - part number M6500XU R2.0
        by SJones88
        I am looking for a board view and schematic for my Asus M6500XV R9 7940HS / 16GB DDR5 RTX 4060 Laptop the laptop board markings show M6500XU R2.0 (I am assuming the XU / XV naming here are probably the same board but different GPU/CPU/RAM/SSD/Screen configuration but uses the MX6500 MU board in the range of these laptops)
        09-29-2025, 11:27 AM
      • esinior
        Smd code to part number
        by esinior
        Hi i have a smd part with probably mark "QO 11" or "Q0(zero) 11" on it, and its package is SOT89, i doubt its KTB1260 PNP transistor, but in measuring with diode mode of multimeter it shows number 1.4 between emitter and collector pins and its not open circuit, and .59 from collector to base and .8 from emitter to base , and these numbers doesn't match a pnp transistor, i couldn't find any part number and datasheet for it, does anybody have information for that part number?
        I've attached pics of this part
        Thanks...
        08-20-2024, 02:50 AM
      • Yanleb
        Panasonic part number in service manuals
        by Yanleb
        In the Panasonic service manuals, both in the board schematics and in the part listing, the part numbers that are given are Panasonic part numbers instead of the actual part numbers.
        This is especially annoying for small SMD components like diodes and transistors when you only have 1-3 digits printed on the component body.
        For an example, look at the attached PDF.
        Do you have a way to cross reference the Panasonic part number with the actual part number?
        Thanks....
        07-03-2023, 08:16 PM
