Sharp LC-80UQ17U Power Supply Board problem
  • bscottjohnston
    • Aug 2023
    • 52
    I just picked up a Sharp LC-80UQ17U here in Denver on Craig's. The previous owner said he was watching it and "pop" it stopped. Opened it up to find a blown fuse on the high Voltage side of the PS. I bypassed it with a 7.5 Ampere automotive fuse and saw a flash in component NTC7001 (as the fuse popped). I am not going to try to apply any more power to the board until I can locate a schematic. Does anyone have the schematics to RUNTKB217WJQZ?
  • francoservo
    FRANKITOO
    • 4
    • México
    hello pin AC_DET what condition is maybe is to hi
    • bscottjohnston
      • Aug 2023
      • 52
      I am afraid I don't understand what you mean. I perceive you mean "check the AC_DET test point and see if its lo or hi" but I am not sure where to do that...
      • bscottjohnston
        • Aug 2023
        • 52
        It would appear as though some sort of schematic is on the back of the board. Is it safe to assume that these boards are single layer? Sorry for the DQs - I did avionics in the Navy but never at a board level. Click image for larger version
        • bscottjohnston
          • Aug 2023
          • 52
          Okay so here's a question for the experts. RL7001 on the back of the board (HF12FF marked on the relay package) is showing 300 Ohms or so on the relay coil but short across the switch contact. The datasheet for HF12FF doesn't show if its normally open or normally closed. The icon on the backside of the board shows open. It just so happens its adjacent to NTC7001 that gave off a small flash when I did my "fuse testing". Anyone have specific knowledge or experience with this part? Click image for larger version  Name:	HF12FF.png Views:	0 Size:	1.15 MB ID:	3218674
          • прямо
            • Sep 2022
            • 261
            • Indonesia
            "The datasheet for HF12FF doesn't show if its normally open or normally closed."
            Sure it does. It shows a normally open diagram, and the switch contacts will be closed when the coil is energized.
            If you measured almost no resistance (0 ohm or exactly the resistance of your probes being touched together) then yes, it is shorted.
            Most likely because the contacts have fused together, or just simply stuck. If stuck, you can try applying 12V DC to the coil and check if that will make them unstuck, if not then replace the relay.
            Also, it is recommended when working with power supplies to use a DBT (dim bulb tester) so you won't end up with components blown to bits when there is still a failure in the circuit.
            When the main fuse is blown, what you need to check first is always the bridge rectifier in diode mode, then the semiconductors in the primary side (more diodes, transistors or mosfets)
            After the primary side is confirmed to be ok, then you can move on to the secondary side where the low voltages are.
              • 12330
              • U.S.
              I second the dim bulb tester, easy to make for a few dollars, can check youtube for many how tos.
              • bscottjohnston
                • Aug 2023
                • 52
                Holy Cow - this dim bulb tester is brilliant. What a great way to work on power supplies without roaching them. Heading to my Home Despot today to grab parts and build. Thanks all.
                • bscottjohnston
                  • Aug 2023
                  • 52
                  This MOV reads .86 MegaOhms in circuit. I have other PS boards that work with MOVs that are wide open this close to the fuse. Is close to 1 MegaOhm a defect? I have to think it is without any Voltage applied.
Name:	TVR 14561.png
                  • прямо
                    • Sep 2022
                    • 261
                    • Indonesia
                    If you can read the fine print on the varistor you can find out the spec, but you should measure its resistance out of circuit to get a better reading.
                    • francoservo
                      FRANKITOO
                      • 4
                      • México
                      hello check the voltage on d7950 (BU5V) or conect in this point extermla power supply an check if the main borad tour on the relay or the stnd by led is blinking
                      • bscottjohnston
                        • Aug 2023
                        • 52
                        This TV is too huge and too expensive. I have decided to go with a repair service on eBay while I continue to teach myself SMPS circuits. Thanks for all the opinions here. I did indeed learn something even though its been 30 years since I left Navy electronics school.
                        • прямо
                          • Sep 2022
                          • 261
                          • Indonesia
                          The power supply board is very easy to remove, it is usually mounted by screws on a galvanized steel chassis inside the TV, and repairing it doesn't really need the TV at all.
                          ​Don't understand why the TV size and value would be a hindrance.
                          • bscottjohnston
                            • Aug 2023
                            • 52
                            It was indeed easy to remove and was fairly easy to diagnose to a degree. However, I cannot find the relay here in the US and didn't want to mess with it. I don't want to recycle this one as its huge, looks great and is extremely heavy.
                            • lotas
                              • Jan 2016
                              • 4859
                              • Russia
                              On the relay contacts there is a low resistance thermistor in parallel for a soft start and it seems to you that the contacts are stuck together.
                              • bscottjohnston
                                • Aug 2023
                                • 52
                                I think that is true too. But I cannot source the relay so I sent the entire board out for repair
                                  by sam_sam_sam
                                  After all of...
                                  07-13-2024, 08:14 PM
                                • m1ch43lzm
                                  by m1ch43lzm
                                  05-12-2025, 08:37 PM
                                • penangit
                                  Hp v193 monitor power supply board
                                  by penangit
                                  Hey everyone,hope everyone is fine, I got an issue hoping you guys can help me,
                                  I got a HP V193 monitor it has a E59670 now i got a few of these, been using them for long time now, however this particular monitor was blacking out for a few times then after unplugging and plugging it back in it gets back to normal until now its dead.
                                  I tried switching the power supply board with another similar monitor and it works,so I'm trying to fix this power supply board I got some basic in electronics as a hobbyist.
                                  Steps taken so far:
                                  Checked all...
                                  02-21-2023, 04:00 AM
                                • lostone
                                  Looking for help with a Viewsonic VP230mb where the backlight comes on only momentarily
                                  by lostone
                                  Hello, I came here after finding some similar questions asked on other monitors and hope someone here can help me get an ancient Viewsonic VP230mp (23" 4:3 LCD) back to working condition.
                                  First a little background, I have a background in computer and electrical engineering, and I'm smart enough to know I know nothing about LCD displays and how they work. For this topic I'm as green as they come.
                                  When the display is turned on the viewsonic logo displays in the uppper left for 2 seconds then the screen goes black, the power LED is green (on) and when a computer is connected...
                                  05-19-2024, 11:40 AM
