samsung ue40d5520 flashing red light
  • wreksta
    • Aug 2013
    • 508
    • england
    Re: samsung ue40d5520 flashing red light
    Any more ideas welcome or its a waiting game for psu to arrive
    • wreksta
      • Aug 2013
      • 508
      • england
      Originally posted by johnboy1313
      Just an FYI, I stripped a 55D6420 Monday. At one point, I tried to power it up with the LEDs unplugged from the PSU which resulted in a flashing red light and a pulsing power supply. My power supply would click about every second if I remember correctly. Your symptoms make me wonder if you have an LED out.
      Hello mate could you read the voltages from psu main connector with led disconnected
      • wreksta
        • Aug 2013
        • 508
        • england
        Silly moment here my mind went blank how to read the fuse black to earth and red either side of the fuse if it is im getting 0v both ends
        • mmartell
          • Oct 2013
          • 3189
          Tom I for one am just confused by the fact that there is voltages on the input pins and by the fact the supply cycles with or without anything connected to it. I've heard replacing the main cures this but I can't fathom how or why.
            Possibly due to low load on the PSU outputs, or some kind of failed communication that the power board is attempting to perform.
            • mmartell
              • Oct 2013
              • 3189
              I'm going to try holding my PSON pin low see if I can make the damn thing stop cycling.
              • wreksta
                • Aug 2013
                • 508
                • england
                #27
                Help testing this fuse is power in then red and black to either side of fuse in volts mode
                  No, with TV power OFF test on 2000 ohms range.
                  • mmartell
                    • Oct 2013
                    • 3189
                    The fuse by the plug ? It's a/c so one probe other side of fuse other probe to other input wire I guess. If you're getting voltage on the main filter cap you're getting a/c through the fuse.
                    Or did I misunderstand your question.
                    • wreksta
                      • Aug 2013
                      • 508
                      • england
                      #30
                      I get 0.0.1 with ohms can you not voltage test it
                      • johnboy1313
                        • Nov 2012
                        • 1959
                        The TV has been stripped. The main board has already been sold.
                          That seems to be OK. It doesn't make much sense to test the voltage across a fuse, it gives you very little info.
                          • wreksta
                            • Aug 2013
                            • 508
                            • england
                            #33
                            Any checks we can do then tom we need to learn what is blowing on these boards mate
                              No immediate suggestions. I need one to work on myself and look at.
                              • mmartell
                                • Oct 2013
                                • 3189
                                Ok so I just learned my PS is active high not low like I thought. It stops cycling when PSON is held low and only voltage present is 5VSB. Apparently it's not tolerant of a floating input and I wonder if 5v is too high for it ?
                                • wreksta
                                  • Aug 2013
                                  • 508
                                  • england
                                  #36
                                  Im goint go test my psu in a working tv mate if it turns out it is that and when my replacement comes ill send you this faulty one if you want tom
                                  • wreksta
                                    • Aug 2013
                                    • 508
                                    • england
                                    #37
                                    Will report bk in an hour or so
                                    • mmartell
                                      • Oct 2013
                                      • 3189
                                      I pulled the PSON pin from the socket and grounded it and plugged everything back in. The power supply is nice and quiet but the power light still flashes albeit a little bit different. Hot and cold make no difference to it must be component failure somewhere on it.
                                      • mmartell
                                        • Oct 2013
                                        • 3189
                                        Hour almost up wreksta, what did you find out ?
                                        • wreksta
                                          • Aug 2013
                                          • 508
                                          • england
                                          #40
                                          Sorry forgot to update swapped psu with mates and my board powered his tv so tried my main and his tv fired straight up so scratched my head s bit went home and stripped full panel to find 4 blown led, s jumpered the pads after removal tv fired up and worked perfect could not tell 4 of the leds wont there replaced them anyways and tv was a good un
                                          All in all was the led light strip
                                          these are in pairs and disconnecting one good strip from the other wont work as they must fire in order
                                          • m1ch43lzm
                                            by m1ch43lzm
                                            05-12-2025, 08:37 PM
                                          • ohren
                                            by ohren
                                            09-08-2023, 05:24 PM
                                          • H34TO
                                            ITE IT8390 (IT8390E-256) programmer "ITE Download Board 4" user manual + firmware, flashing ITE ECs on the cheap
                                            by H34TO
                                            Recently I've gotten into EC flashing due to my broken laptop(s) and started frantically searching methods for flashing the IT5571E-128 chip on the cheap(due to me beaing a student and not having a job) and noticed that ITE newer chips can be flashed via ISP (In-System Programming) either via SMBus or the KBC (EPP - Enhanced Parallel Port) interface. While these can be achieved with programmers like SVOD4/3 or the RT809H/F those options are WAYYY out of my budget so I was horrified. But recently I stumbled uppon some programmers on aliexpress that claim they can program a variety of ITE chips...
                                            06-17-2025, 07:17 AM
                                          • howardc64
                                            by howardc64
                                            Problem
                                            08-04-2024, 10:36 PM
                                          • Welchs101
                                            LED light flashing trying to fix LED driver board
                                            by Welchs101
                                            Hi i have an LED garage light. It has two bulbs/strips of led lights in it. One of the bulbs is flashing. I dissassembled the light to get to the LED driver board.
                                            i am enclosing pictures.
                                            given that one works and the other does not (ie...flashing) i thought i should be able to fix this.....or at least determine what is wrong.
                                            the led driver board basically had "two" drivers on the same board. I began probing using my multimeter trying to find differences between the two. Now there may be diff i did not find but one difference i did find was...
                                            09-01-2021, 07:41 AM
