samsung ue40d5520 flashing red light
  • wreksta
    • Aug 2013
    • 508
    • england
    Hi all just got a sdt in there cheap £55 the standby light is flashing
    I disconnected the led cable and tuner board cable from the power supply board and measured voltages from the power supply to the tuner board connection I get no voltages at all on any pin until I hear the power supply pulse then the voltages rise then drop within 2 seconds and it repeats
    any ideas there is on pin that gives a steady 5v all the rest are fluctuating
    power supply board is bn44-00422b
    http://www.google.co.uk/imgres?clien...bwYDoDg&zoom=1
    Re: samsung ue40d5520 flashing red light
    There's a thread on here regarding the 55" D5000 series which is more or less the same as yours, with same symptoms. Bad main board.
    • wreksta
      • Aug 2013
      • 508
      • england
      Tom when all boards disconnected I get fluctuations on the connector lead that leads to the main board but disconnected only 1 pin is a steady 5v the rest are from from no volts up to mm 10-12v then back dosn to mm no volts within second ill see jf I can get a videonfor you
        Yes, that TV has the same symptom which makes it look like main board bad. Thread:
        https://www.badcaps.net/forum/showthread.php?t=34566
        (My error, that's a D6000, but I think the only major different is the D6000 is a Smart set.)
        • wreksta
          • Aug 2013
          • 508
          • england
          He got a start up screen I dont mate
            Do you get stable 5V standby? Or is that varying too?
            I'm SURE I saw one about D5000 which was similar, but I might be getting mixed up...
            • mmartell
              • Oct 2013
              • 3189
              There seems to be a plague of these lately
              • wreksta
                • Aug 2013
                • 508
                • england
                With all boards disconnected and the led cable all disconnected running only the psu with ac cable in
                I get pulsing noise from psu and only one pin on the white connector is showing 5v and the rest of the pins fluctate
                  What voltage do you see across the 450V caps?
                  No schematic, Samsung stopped releasing them I think, so we're kind of working blind...
                  • mmartell
                    • Oct 2013
                    • 3189
                    Are the BLON, PSON and PWM lines oscillating as well ?
                    • wreksta
                      • Aug 2013
                      • 508
                      • england
                      A5v is the only voltage I can read steady
                      • mmartell
                        • Oct 2013
                        • 3189
                        Right but you said the others are oscillating. Does that include the ones I asked about ?
                        • wreksta
                          • Aug 2013
                          • 508
                          • england
                          About 360v ramping up 390 every time it pulses then drops again go 360v
                          and all except grnd and a5v fluctuate
                          • wreksta
                            • Aug 2013
                            • 508
                            • england
                            Mmartell all ps on bl on and power sw are all 0v until hear the power supply pulse then ramp up to 3v then down to 0v again
                            I have ordered a replacement power supply but wont come for a week
                            so hoping to try and narrow this down
                              Sounds like PFC fault - I'd focus on startup capacitor for PFC section or main run section.
                              • wreksta
                                • Aug 2013
                                • 508
                                • england
                                Any ideas tom where exactly to start ive tested all mosftes and diodes all check out etc so on my diagnosis do you all agree my psu is fuxored
                                  Knowing how complex some of these PSUs are, in newer Samsung LED that is, I could not say for sure. It does SEEM like it, though.
                                  • johnboy1313
                                    • Nov 2012
                                    • 1959
                                    Just an FYI, I stripped a 55D6420 Monday. At one point, I tried to power it up with the LEDs unplugged from the PSU which resulted in a flashing red light and a pulsing power supply. My power supply would click about every second if I remember correctly. Your symptoms make me wonder if you have an LED out.
                                    • wreksta
                                      • Aug 2013
                                      • 508
                                      • england
                                      My psu pulses with led strip plugged in or out and if im corrsct those startup caps are power Ed in line before then led section so should have higher voltages on those caps ks that right tom
                                        The 450V caps are primary side. In a 40", the LEDs will work on around 100 to 200V end to end. I have an LED driver from a 40" Technika LED (fell off a wall...) which is rated 130V. It used a Samsung FHD panel from 2011, similar to yours. The LEDs will be driven off the secondary.
                                        Not enough experience with these I'm afraid to give much help. My only big LED TV fixes have been unrelated to backlight or PSU.
                                        • m1ch43lzm
                                          by m1ch43lzm
                                          05-12-2025, 08:37 PM
                                        • ohren
                                          Upgrading a Samsung ue55nu7096u with logic board from an ue55ru7105k -- good idea?
                                          by ohren
                                          I hope this is the right forum to post in despite not technically being a repair, but still a question of swapping boards.
                                          I thought I'd explore the possibility to upgrade an existing working Samsung ue55nu7096u with the logic board (and power board if needed) of a newer model (ue55ru7105k) of the same size and appearance (and resolution). The reason being I'd like the extra inputs of that board including component in, an extra HDMI port and bluetooth. Its panel is broken so I have no use for the board otherwise.
                                          The models launched in 2018 and 2019 respectively....
                                          09-08-2023, 05:24 PM
                                        • H34TO
                                          ITE IT8390 (IT8390E-256) programmer "ITE Download Board 4" user manual + firmware, flashing ITE ECs on the cheap
                                          by H34TO
                                          Recently I've gotten into EC flashing due to my broken laptop(s) and started frantically searching methods for flashing the IT5571E-128 chip on the cheap(due to me beaing a student and not having a job) and noticed that ITE newer chips can be flashed via ISP (In-System Programming) either via SMBus or the KBC (EPP - Enhanced Parallel Port) interface. While these can be achieved with programmers like SVOD4/3 or the RT809H/F those options are WAYYY out of my budget so I was horrified. But recently I stumbled uppon some programmers on aliexpress that claim they can program a variety of ITE chips...
                                          06-17-2025, 07:17 AM
                                        • howardc64
                                          by howardc64
                                          Problem
                                          08-04-2024, 10:36 PM
                                        • Welchs101
                                          LED light flashing trying to fix LED driver board
                                          by Welchs101
                                          Hi i have an LED garage light. It has two bulbs/strips of led lights in it. One of the bulbs is flashing. I dissassembled the light to get to the LED driver board.
                                          i am enclosing pictures.
                                          given that one works and the other does not (ie...flashing) i thought i should be able to fix this.....or at least determine what is wrong.
                                          the led driver board basically had "two" drivers on the same board. I began probing using my multimeter trying to find differences between the two. Now there may be diff i did not find but one difference i did find was...
                                          09-01-2021, 07:41 AM
