2007 Insignia LCD 32" - Large Capacitor on PSU squeeling
  • RollaGrad
    • Dec 2013
    • 11
    I was given an Insignia lcd-32-07 because it wouldn't power off one time and then it wouldn't turn on. Originally after receiving it, the television would power on after pressing the power button numerous times on and off. (During this time, there was clicking noises when I would hold down the power button) While it eventually power's up, when plugged into the outlet a high pitched noise is heard coming from the power supply (more specifically the large 450V 150uf capacitor. If the TV is turned on the high pitched noise gets louder.
    I checked voltages on the PSU and am getting the standby voltage of 3.3V.
    My large capacitor, which appears to be producing the whine maintains 170V when in standby, and ramps to around 350-400V when powered on as expected. None of my capacitors look bulged, but I went ahead and replaced the large capacitor in hopes of this solving the issue.
    Unfortunately, the TV had the same issues so I went ahead and ordered a new power supply after seeing no blown caps on the main board. The new power supply arrived today and I installed it. To my dismay, immediately after plugging it in the squealing started (although a softer whine). The TV does now turn on after one press of the power button and stay on (picture looks fine) but the capacitor continues to produce a high pitched noise, becoming louder when turned on and when turned off after being on, starts into an cycling stage of squealing (sounds like the high pitched noise is charging, then resets and repeats)
    At this point, I am fairly sure there is a downstream issue. I recently graduated from an engineering school in Electrical Engineering, so I have a some background in electronics. However, I am stumped. Does anyone have suggestions on where I should go from here?
    Thanks so much! I've been troubleshooting for quite some time.
    Here are pictures of the Power Supply Board and TV
  • NihonNoir
    • Jan 2014
    • 231
    • US
    Re: 2007 Insignia LCD 32" - Large Capacitor on PSU squeeling
    This won't help you, but I happened to come across this video of a squealing power supply after replacement when looking up my own TV. http://www.youtube.com/watch?v=Itw0LKtwGjY
      Are there any labeling on those connectors on the output side of the power supply?
      • RollaGrad
        • Dec 2013
        • 11
        Thanks for the replies! NihonNoir, my situation isn't the same type of buzzing you have in that video. Mine is a distinct high pitch whine coming from the large PSU capacitor upon even plugging in the power cord.
        Bud, yes there are labels on the power supply output. I've included pictures of all outputs. I have noticed that once I unplug the cable containing the 3.3V, 2 - 12V, 5V, 9V pins and plug in the power cord. The whining is not there, just a very very slight hum, which I think to probably be normal. I know the 3.3V is a standby voltage in order to be able to turn the TV on, but do you have any insight as to what might the other voltages are for or the possible issue here?
        I checked the main board for blown caps, only to find that, visually, they all looked fine and not bulged. I have attached pictures below (Sorry for the poor quality) There is a picture that shows the aforementioned cable unplugged, and also where it is plugged into the main board.
        Thanks again!
        • Ltank
          • Jun 2013
          • 776
          The timing capacitor in the circuit that affects the drive circuits to the transformers. Check ESR on caps or for a bulging capacitor. The capaitor affects the freguency. The frequency is too low thus the squeeling. This is on the PS board Get a pic of the tag from rear of set to get the correct Service manual or power supply schematic. How about a pic of the top side ( component side) of the PS?
          • selldoor
            Slow Learner
            • 7870
            That board looks to have a fine selection of mediocre to bad caps- cant see them properly but if populated with JH or ltec 85degree caps they have probably dried up.
            • RollaGrad
              • Dec 2013
              • 11
              Ltank,
              I will attach the TV tag when I get home. Thanks for the responses!
              Selldoor,
              Yeah I know for sure there are a handful of JH caps. Perhaps I should try a recap. Would they possibly cause the large cap to whine?
              • Ltank
                • Jun 2013
                • 776
                Normally a transformer whines when opeating at a lower frequency. A dried cap would have very high ESR. In a oscillator circuit I guess they will vibrate. They should not vibrate when used in a steady dc circuit.
                • srs
                  Insignia NS-50DR620NA18 w/ large vertical lines & no picture
                  by srs
                  I'm not sure what to do next and came here since y'all helped me fix a 50" plasma TV back in 2014, which is still working!
                  A friend gave me an Insignia NS-50DR620NA18 50" TV that suddenly developed large vertical lines on it. He said he had no idea what might have caused it and has replaced it with a larger TV. He was going to throw it away.
                  I did not notice any bulged or leaking caps on any board, the voltages produced by the power supply match the voltage that the pins are marked. The backlight leds are working. I have tried cleaning the ribbon cables...
                  04-22-2023, 02:40 PM
                • cajoeg
                  Insignia NS-LCD019-09 issue: Power light turns blue for 3 seconds, the flashes red before going solid read again
                  by cajoeg
                  Hello, I'm new to the group and to trying to repair a LCD TV. During the past few years, I've been collecting/repairing/restoring vintage personal computers (Commodore, Apple II, Atari, TRS-80, Texas Instruments, and Timex Sinclair). This has been my retirement hobby. Now I've gotten interested in trying to repair a LCD TV that I have and used regularly when working on vintage computers.
                  The LCD I'm working on is a Insignia NS-LCD019. I've downloaded the service manual that I could find, but it must be a different revision since not too many items in the service manual match the TV...
                  02-10-2025, 04:01 PM
                • MikeRWK
                  Insignia NS-39L700A12 backlight transformer high pitched wine
                  by MikeRWK
                  The tv won't turn on most of the time. It will try for a few seconds and quit, there's a lower buzzing then if it fires the transformer whines. All the caps look good visually there aren't any bulged caps or indications of leakage.
                  When I press on the transformer in question the whine changes.
                  Here's a video of it https://streamable.com/gatxa4...
                  01-23-2021, 03:12 PM
                • tony359
                  2007 Macbook logic board fault
                  by tony359
                  Good day all,
                  I got a 2007 MacBook from a friend. The fan was not working so it was overheating.
                  Once the fan was swapped, I installed an OS and it worked fine.
                  The board had quite a few corroded spots so I removed it, touched those spots with a soldering iron, washed the board in PCB cleaning fluid (I've done that many times), rinsed it with distilled water, dried it etc.
                  Unfortunately it doesn't work anymore. It does turn on, fan spins, power LED turns on. But no picture.
                  If I see that right, I have missed VCORE on L7100 (page 59)....
                  01-23-2025, 06:59 AM
                • camelion
                  All password for asus series 2007
                  by camelion
                  All password asus 2007
                  2007-01-01 abldabla
                  2007-01-02 aaaa4aba
                  2007-01-03 aa219daa
                  2007-01-04 ab4hbbla
                  2007-01-05 ahaalo0b
                  2007-01-06 aabbaaal
                  2007-01-07 aabb00ld
                  2007-01-08 a1ddo10d
                  2007-01-09 aoaadaab
                  2007-01-10 aoaabadb
                  2007-01-11 bb12lhl0
                  2007-01-12 b4h4a1al
                  2007-01-13 laaa0adb
                  2007-01-14 daobobl2
                  2007-01-15 d10bdba1
                  2007-01-16 dodl1ad1
                  2007-01-17 dlaaallc
                  2007-01-18 ba12lla9
                  2007-01-19 bch4abdb
                  2007-01-20 0a04oaba
                  2007-01-21 0aaadbaa
                  2007-01-22...
                  06-06-2013, 01:59 PM
