50" insignia turns on and off repeatedly
    Re: 50" insignia turns on and off repeatedly
    With X-main and Y-main unplugged, any difference in behaviour?
    • j33jared
      • Jan 2014
      • 31
      • US
      Is this showing the powerboard bad or vs is bad
        Those voltages can be low if the X-main or Y-main is bad. So it's important to isolate them first to see if the power board is bad or not.
        • j33jared
          • Jan 2014
          • 31
          • US
          When I take plug off going to right board nothing changes.
          When I unplug left board the va reads about 120 steady. The vs then reads funny. Just has a 1 at the left side of meter. When I take black lead off it jumps to 25 for a second before going to 0
            Is your meter set to the 200V DC range, or 200V AC range? You want DC.
            • j33jared
              • Jan 2014
              • 31
              • US
              #26
              Ok switched to dc
              With left board unplugged the va reads 55 and still getting funky reading from vs
              With both plugged in I get about 23 out of va before counting down to 3 and vs gets up to about .6
              With right unplugged I get the same 23 and .6
                Sorry, my error. Try the one range higher than 200V, at 1000V.
                Vs can be around 210V so is enough to push your meter to over-range indication ("1" meaning input over-voltage, which isn't damaging, but you need to switch to next highest range.)
                • j33jared
                  • Jan 2014
                  • 31
                  • US
                  #28
                  On 1000
                  Right unplugged....getting 023 to 030 out of va and 001 out of vs
                  Both plugged in.....getting same
                  Left unplugged....getting 55 from va and 212 from vs
                    So, you have a short on the left board. If you mean left, looking from the rear, that's the Y-main board.
                    • j33jared
                      • Jan 2014
                      • 31
                      • US
                      #30
                      Yeah when i say left that is from the back
                        Y-main then. Repairability limited, you can try replacing the IGBTs on it, but can be a lot of work and hardly worth it if board is cheap. Look for LJ9#-######A part number to find replacement part. Note last letter usually "A" but can vary.
                        • j33jared
                          • Jan 2014
                          • 31
                          • US
                          #32
                          Looks like a little over a hundred for the ymain
                          • j33jared
                            • Jan 2014
                            • 31
                            • US
                            #33
                            lj92-01601a
                              Hmm, so do you feel like replacing IGBTs then? It can be hard work, but will cost a lot less than $100, you would need a good quality soldering iron (temperature regulated) and good soldering skills.
                              • j33jared
                                • Jan 2014
                                • 31
                                • US
                                #35
                                I have never done any soldering
                                • j33jared
                                  • Jan 2014
                                  • 31
                                  • US
                                  #36
                                  How much do you think those would cost
                                    Might be best to get a new board, then.
                                    Repair kit, should you find someone capable of installing it?
                                    http://www.shopjimmy.com/samsung-bn9...repair-kit.htm
                                    • j33jared
                                      • Jan 2014
                                      • 31
                                      • US
                                      #38
                                      Thanks for all the help. I think I should just get the board. I'm afraid I would have no idea what to do with that kit.
                                        If you buy from a seller which strips down TVs for parts, make sure to buy from one who guarantees them and offers a warranty and returns policy.
                                        • j33jared
                                          • Jan 2014
                                          • 31
                                          • US
                                          #40
                                          Any trusted sites to find lj92-01601a ?
                                          • cajoeg
                                            Insignia NS-LCD019-09 issue: Power light turns blue for 3 seconds, the flashes red before going solid read again
                                            by cajoeg
                                            Hello, I'm new to the group and to trying to repair a LCD TV. During the past few years, I've been collecting/repairing/restoring vintage personal computers (Commodore, Apple II, Atari, TRS-80, Texas Instruments, and Timex Sinclair). This has been my retirement hobby. Now I've gotten interested in trying to repair a LCD TV that I have and used regularly when working on vintage computers.
                                            The LCD I'm working on is a Insignia NS-LCD019. I've downloaded the service manual that I could find, but it must be a different revision since not too many items in the service manual match the TV...
                                            02-10-2025, 04:01 PM
                                          • Stephen
                                            MacBook Pro 14" M1 Pro Turns on functions then turns off when I plug in USB C cable
                                            by Stephen
                                            MacBook Pro 14" M1 Pro Turns on functions then turns off when I plug in USB C cable to reset the computer. I disconnect the battery fully and then reconnect it and it won't turn back on. After letting it sit for a day I plug the battery back up, and the MagSafe 3 cable and it powers on and stays ons, once I plug in a USB C cable into the port closes to the MagSafe port it turns off and the Amber light turns off and won't turn on. No water damage, nothing, I want to do a DFU restore to wipe the computer since the customer stated they did an update and ever since it just decided to not work...
                                            03-15-2024, 09:37 AM
                                          • www
                                            LG L192WS-BN backlight turns off after 1 second
                                            by www
                                            I am testing an old LG L192WS-BN monitor I have that gives an image, but has a backlight issue. When you turn it on the backlight turns on 1 second and it turns off, turns on again, 1 second and it turns off and stays off. Using a flashlight I can see there's still an image.
                                            I replaced a bulged cap on the main board, but made no difference. I also got another exact same model monitor that has a broken ccfl (the connector got ripped from the panel and the main screen connector is also broken so I can't use this panel to test), tried using the main board from this one, same issue....
                                            03-24-2024, 05:26 PM
                                          • zklgfs
                                            Anker SoundCore 2 Bluetooth Speaker Turns Off After a Few Seconds (Possibly Firmware Issue?)
                                            by zklgfs
                                            I have an Anker SoundCore 2 (A3105) that I saved from the trash (well, I guess there's a reason why it was supposed to go into the trash...). The problem is that it always turns off after a few seconds (sometimes it stays on a bit longer, between 30 and 60 seconds, but it still turns off). The power light turns on and the bluetooth light starts blinking, but both abruptly turn off again. The "turn off sound" is still played after the lights turn off. Sometimes, it also loops the on-off cycle several times without me pressing any buttons. If I connect an AUX cable, music...
                                            08-11-2025, 02:14 PM
                                          • andrhouseolly
                                            Dell Precision 5510, AAM00 LA-C361P Rev:2.0 turns on, no image.
                                            by andrhouseolly
                                            Hi.
                                            I kindly ask you to help me solve the problem.
                                            Dell Precision 5510, motherboard AAM00 LA-C361P Rev:2.0
                                            The board turns on, there is no image.
                                            Read more. When the power supply is connected, the front panel indicators light up briefly.
                                            When you press the power button, the button indicator lights up. The board works
                                            there is no image, there is no matrix initialization, there is no image on HDMI.
                                            When turned on, the fans do not spin, but when they warm up they start spinning.
                                            When you turn off the button, the fans spin up to full speed for a short...
                                            05-11-2024, 03:14 PM
