Re: Another sony led back lighting problem.
It is not weird that they sent the wrong side.. They are just another seller that does not know what they are doing !
LUCKILY, their mistake worked out good for you and saved you some extra work.
Glad to hear that you got it back together and are running again !!!
Followup.
I ordered this Part http://www.iccfl.com/product_info.php?products_id=21543
It was the A side. But I needed the B side.
When the shipment arrived (7 days from time of order) it was actually the B Side they shipped. Weird.
I reassembled the tv, ended with 5 extra screws. whoops. Turned on the TV and VIOLA, it works. all LEDs on and no autoshut downs.
What a learning experience. Overall I spent $54 in parts/shipping, but I am very pleased with myself.
Thanks to everyone on here for their assistance and inspiration (seriously)
You showed me a repair was feasible! "Hat Tip"
Originally posted by AMRivlin View PostMAN! I think this is it!!! (I accidentally destroyed the broken led strand trying to remove the bulb, so i will buy this and pray i can reassemble the tv properly.)
How did you source it? I couldn't locate/google it to save my life.
[/IMG]
These usually have a heatsink underneath them that is soldered down, so they need to be removed with a heatgun.
First you have to cover the nearby bulbs with a few layers of foil and then you have to apply flux to the bulbs and then heat it till you see the solder glisten.
IF, you have a real good soldering iron and if you are not trying to salvage a bulb, they can be removed with that, but you first have to snap or carve the top of the bulb yellow off so that you can heat right down on the bulbs metals easier. again , flux needs to be used
if you are not trying to salvage a board, but you want to salvage bulbs or transplant then do not use foil and heat as much as you can from the bottom of the board
This will work, but you have to watch your brightness depending on how many bulbs are in each string.
For instance, the apples have 20 bulbs per sting so removing one bulb would raise the other bulbs 0.15 volts higher than normal which isn't too bad. But, On a 9 string bulb setup like the one in this post, the voltage would go up 0.375 volts per bulb and that is too high for long term at high brightness.
Originally posted by bammbammfran View Posthow many separate bulbs board strips are on that screen ? 4 ?
how many plugs pins are on each plug of each strand or 63 ? 14 ?
can you post a few pictures ?
did you try hooking it up to see whichstrip had the trouble bulbs ?
I usually change the bad bulbs ?
I did find one used strip here but the plug might be in the wrong direction
I just enlarged those pictures and it looks like you probably have two version boards
one version has the plug on one end and the other has it on the other end
and it has 9 3 volt bulbs on each strand.
so probably they are staggered like bulb 1-8-15-23-30 etc will be on one strand and 2-9-16-24-31 etc on another
you can check one bulb at a time using a 3 volt battery or all 9 on the strand at once using a 24 volt power source (19 volt laptop adapter might just be enough to do it- if not it will do 7 at a time)
bulbs have a positive and negative side and will only light in one direction, so you have to figure out which way the first bulb of the strand travels first since some strands might have the positive side towards the main plug and some might be the reverse and start at the opposite end.
Here are 2 photos:
What I did on a Sony Bravia 55hx850 is just remove the one troubled LED light and essentially shorted out both ends of where the LED light would connect (basically a bypass). Used it for two months like that until I received a cracked LED tv with a similar LED light. Now looks as good as new
bulbs have a positive and negative side and will only light in one direction, so you have to figure out which way the first bulb of the strand travels first since some strands might have the positive side towards the main plug and some might be the reverse and start at the opposite end.Last edited by bammbammfran; 06-27-2014, 06:38 AM.
Originally posted by bammbammfran View PostChanging bulbs on a screen that size will not be any fun to do !!!
here is an idea of what is involved on a 27" apple led
http://youtu.be/orJ-zEdSAAQ
3 codes are printed on the bar of 63 LEDs
SLS40_5630_120_1D_B_Rev1
I assume this is the part number
(SonyLightStrip 40" 5630 120HZ 1D? B? Revision 1)
KM-8 94V-0 1028
No idea, maybe an assemble line part #?
On the back a barcode with
K928 H
100012
40U168
Possibly an assembly / inventory # for the technician building the tv?
even if i manage to dismantle the tv, how would i replace 1 LED, by replacing the entire strand?
Can someone explain in detail this:"Use a 100 ohm resistor from the psu side BL-ERR to ground"
Is the BL-ERR easily identified?
The LED Driver board replacement arrived ($10 on ebay). This did not fix the problem. So it appears to be a dead / burnt out LED.
Per the previous message, I would have to replace said bulb.
3 Options:
1. Repair Bulb (Sounds beyond my ability)
2. run a 100 ohm resistor from the psu side BL-ERR (also beyond my knowledge)
3. Take to a Sony Repair Center (sounds expensive)
Or buy a new tv.
If anyone can walk me through 1 and/or 2, I will buy a case of beer for you.
If you live in San Jose and you can help in person, even better, and more beer for you. (just after the repair)
Looks like a bad led bulb
These are normally set up in a strand, kind of like string along xmas bulbs
and sometimes one will get weak and the strand will still work.
most of the time the bad bulb will shut down the one strand and that will cause the driver board to shut all of the other strands of the bulbs.
The ones that I worked on are mostly apples, and to change those, you have to use a heatgun
well.. depends on how the leds are powered, if the whole panel is powered then the one led has failed. but if they are powered individually (doubt it) then you might have a driver issue (doubt it) you will have to open the tv and removed the lcd and expose the backlight without getting dust inside, replace the led and put everything back. It could acutally be really bad backlight bleed!!! do your own research!!!
thanks, but that sounds tricky as i am not very confident at soldiering.
Are you sure the LED is out/damaged or could it be the LED Driver Board. (I have one on order to swap out.)
How does one go about replacing the actual LEDs (I know how to replace CCFLs, but never saw a LED repair DIY)
if your happy with the fault you could try and run a 100 ohm resistor from the psu side BL-ERR to ground. It will bypass the fault but may cause more damage later as it seems one of your leds have failed.
The following is regarding a similar problem with a Sony Bravia KDL 40NX711 (Purchased July 2011) (3900hrs on the Panel, via the Diag menu)
This is an LED Backlit TV.
We just moved over 2000 miles and setup our Sony TV in our new home. 4 weeks after moving in the Tv turned off on it's own, it does turn back on but only stays lit for 1-2min before shutting off.
I was able to diagnose the issue through the blink code and the diagnostic menu.
It is Blink Code 6 (Backlite) Error Code 08. (also had error code 12 and 14 on 1 occasion)
I assume this is the Inverter/Driver board. See the attached images below.
I don't mind the black spot, but the tv wont stay on more than 2 min. Since it turns on and I can still see inputs, this leads me to believe the power and tcon are functioning properly.
I found the board on ShopJimmy and Ebay and hope this fixes the issue. For $10 it is worth trying.
While turned on, I can see a darker area just above the Sony emblem on the frame, about 2"x2" (It does not run the width of the screen)
well my replacement LED driver board came in and TV works flawless now. Those little ICs on the driver boards are a problem as it ohms out differently from the other ICS on that board. the original problem was upon startup the screen would be fine then I would lose half of the bottom left hand strip.
Yes that's the board. Agreed it would be more cost effective to replace the board. Other issues with my driver board persist as well
The board, above the T-con with metal cover on it, right? I believe that is called LED driver board.
Here is mine:
http://www.shopjimmy.com/sony-st4055yl-s01-yl-board.htm
That I had to replace myself. I would have ordered the ICs from China, but I was anxious to see it running, so I have just did as you did, and got another board for $58.
Actually I think I'm using the wrong terminology. I would assume the balancer is connected to the power supply. The local dimming driver is connected to the t-con board that's unit that's bad. Looks like I can't locate the IC's as they don't seem to sell em in the US and I'm not going to order and quantities of China so I just found the board for $70 so I ordered it we'll see how this turns out
