Another sony led back lighting problem.
  • freakaftr8
    replied
    Re: Another sony led back lighting problem.
    Originally posted by multimeter
    only trouble is,an lcd panel has many diffuser sheets in them,trying to define a faulty led can be hard,with ccfl,you have more of a chance,as if one fails it tends to give a uniform shadow,but the feed back circuit will prob only give you around 2 secs to see before it shuts the inverter down.
    THis is very true. Best way is usually the hardest by removing the panel..then doing g my power up trick..
  • tibimakai
    replied
    Which one is the balancer?
    To me, it looks like one of the LED driver ICs must be bad. I had pretty much the same thing, but half of them didn't light up. I had two ICs out. Mine it was an 46NX720 model.
  • multimeter
    replied
  • freakaftr8
    replied
    Never mind. I found a hole burned in one of the balancer Ic's. either going to try to rebuild the balancer board or replace it not sure yet it appears that this board is hard to find.
    on another note I did learn something new that might come valuable to other members. If you disconnect the LVDS cable from the tcon board then as you are plugging in the TV hold the power button at the same time you will get a momentary white screen and it will light up all LEDs for approximately 1.5 seconds and you can do this again and again and you will be able to see if you have any bad LED's behind the screen. I came across this on accident but it appears that it is a useful tool in trying to find a bad led.
  • freakaftr8
    started a topic Another sony led back lighting problem.
    Kdl 55hx729 picked it up tonight with a 5 blink code. Repaired the bad ribbon LVDS cable and found that the LED's on a quarter the bottom go out after 2 seconds of being on. Of course this throw the for blink balancer issue. I'm thinking it is a certain led problem due to the fact that they do work upon first startup. after testing the balancer board I am pretty certain that led is overheating and shutting down immediately incense the LED's are wired in series one goes out the rest go out. I think I'm just going to pull the panel in check the LED strip one by one. Has anybody had any success rate at this problem.?
    I know there has been a few other members on the forum having the same issues with their LED Sony backlit TV. Has anyone successfully repaired this yet?
    http://i845.photobucket.com/albums/a...ps42cfe091.jpg
    http://i845.photobucket.com/albums/a...ps4b65285e.jpg
  • crackedprint
    Sony HCD-HX80R Amplifier Volume Control Problem
    by crackedprint
    I have a strange fault on a Sony amplifier. The volume control varies the display from MIN, then 1 up to 30 and then MAX as expected. At MIN there is no sound. However, at 1 it is quite loud and increasing above 1 does not change the sound level.
    I have tried a Cold Reset as per the service manual.
    I have looked at the I2C clock and data to volume control chip IC501 (BD3499FV). Data is only sent to IC501 when the volume is set to MIN or 1. At any other setting no data is sent to IC501.
    I have looked all the way through the service manual and tried many online...
    01-21-2025, 12:18 PM
  • retrorepair
    SONY KDL-40P3600 Picture Problem
    by retrorepair
    Hello gurus, hope you can assist me...
    I have a Sony KDL.40P3600, with an issue on the left side of the screen (pictures attached).
    I think the problem is the panel, but before send it to trash, i would like to get a second opinion.
    Thanks in advance.
    10-11-2024, 05:12 PM
  • guruji
    Sony mbx-266 problem
    by guruji
    Hello
    I this Sony mbx-266 it powers
    on all the voltages are normal the strange part iOS the caps key num key works which shows the machine has booted but no video at all internal dp and the ext vga or hdmi.I have changed the bios but same issue. What do I check ??
    07-25-2025, 08:10 AM
  • ivtec
    sony kdl 32 bx 300 turns off and back on help
    by ivtec
    Hi my old Sony i turn it off and it turns itself back up and many times remote wont work have to unplug tv...
    07-03-2024, 10:52 AM
  • boyebaran
    hisense 65k560 back light problem
    by boyebaran
    hi to all
    tv turn on and show logo(backlight on)than backlight turn off than red led in front blinking 7 time. the tv remote control working fine (sound on no picture).backlight changed same problem
    in 65k560 how to remove protection of backlight? picture of inverter and sockets attached .
    please advise me tnx
    05-20-2025, 07:11 AM
