Sony 49XH9505 four flash of death
  • protonusr22
    • Nov 2022
    • 12
    • Romania
    I own a Sony 49XH9505 123.2cm Smart Android 4k quite new bough brand new in 2021. Just after the warranty has expired it had died on me.
    The symptoms are the following: right after turning on backlight turns on and this loading screen appears, than the display turns off and the red led flashes four times.
    Any idea how to fix it or if it at least fixable? Does this sign related maybe some SoC/DSP and its circuits or just some simple power supply issues somewhere ?
    Many thanks in advance,
  • kasfamily
    • Aug 2014
    • 765
    • Russia
    Red led flashes four times - Balancer Error. Most likely the backlight is faulty, disassemble the panel
    • lotas
      • Jan 2016
      • 4611
      • Russia
      Code error
      • protonusr22
        • Nov 2022
        • 12
        • Romania
        Thanks for the answer! So you suppose one or more leds in series are in short/open?
        • protonusr22
          • Nov 2022
          • 12
          • Romania
          Originally posted by lotas
          Code error
          Thank you!
          • EazyBone
            • Jun 2023
            • 1339
            • United states
            This doesn't mean it's the LEDs. It means its LED circuit. Yes one can be open, BUT the code says it could be any of the 4 things listed. If you can test with multimeter and have a led tester that'd be your be bet before replacing the LEDs (I made that mistake before). Open the back and take a picture of whole thing together and each board.
            • protonusr22
              • Nov 2022
              • 12
              • Romania
              EasyBone: I have attached the pictures
              Since last time I have tried the "easy" solution I have found on youtube, cutting and grounding the BL_ERR pin but no success. When i first started up the tv with this modification it booted up and stayed in the language selection menu for 2-3 seconds, than the 4 red blinks.
              Edit: " *I have tried to find the schematic of the led driver board but with no results. - also, i have tried to unplug the ribbon cable on the right side of the board that goes to the main logic board - the tv still boots up and than crashes with 4 / 6 blinks. "
              Thank you guys in advance,
                • 12208
                • U.S.
                So undo that ground out if you haven't already, with everything hooked up as normal, turn on tv, or if it won't turn on, just check the voltages of the pins of connector 6401, might have some pain getting the bottom ones/odd numbered, can probably skip the grounds but report all the other voltages here.
                • EazyBone
                  • Jun 2023
                  • 1339
                  • United states
                  6401 is probably fine, I suspect 6501 voltages. Something from led driver board or psu leading to it. Obviously should be checking all voltages from each connection.
                  • protonusr22
                    • Nov 2022
                    • 12
                    • Romania
                    is there somewhere a schematic diagram available? i could not find any :/
                    • kasfamily
                      • Aug 2014
                      • 765
                      • Russia
                      Backlight for this panel
                      https://aliexpress.ru/item/100500622...00036353888930
                        • 12208
                        • U.S.
                        So what's the delay, you have no multimeter? If not then probably best you can do is replace boards or backlights and hope.
                        • EazyBone
                          • Jun 2023
                          • 1339
                          • United states
                          He wants a diagram so that he can look at it intensely
                          • kasfamily
                            • Aug 2014
                            • 765
                            • Russia
                            Make a request - OZ9218 - http://www.o2micro.com/company/conta...inquiries.html
                              • 12208
                              • U.S.
                              Dude, knock off the second guessing me, you are far from an expert in tv repair, so without proof of what is wrong, just save it.
                              • EazyBone
                                • Jun 2023
                                • 1339
                                • United states
                                Why you always so angry on here.
                                4 blink. Led circuit. PSU led connector. Seems like a place to look at.
                                  • 12208
                                  • U.S.
                                  Not angry at all, nobody likes a second guesser on their case, so don't be like a few of the nit-wits here, we already have enough of those types. You are from the U.S.A so you should know proper etiquette, like instead of contradicting someone, just say why don't you also try testing whatever it is you think, not BS like uhh that is fine so it is this that's wrong, understandable to you? And even you should know that this connector is where most testing should start.
                                  • diif
                                    • Feb 2014
                                    • 6978
                                    • England
                                    Please follow your own advice nomoresonys, take this nonsense private and quit with the quite obvious BS.
                                      • 12208
                                      • U.S.
                                      Ok big boss man, in the mean time GFY.
                                      • kasfamily
                                        • Aug 2014
                                        • 765
                                        • Russia
                                        "GFY" it means - " Good For You" ?
                                        • Ihandyrepair
                                          4 red flash led 65X950G boot Sony and android logo but then black
                                          by Ihandyrepair
                                          HI guys
                                          I got here a Sony 65X950G - I tried to find any repairs guides for this model but not many online
                                          here is the issue
                                          I have Sony and android logo. but then 4 led red flash lights front of the tv
                                          I have 3.3v ref. 12v reg then T con 12v when I press the power on button
                                          but then I get black screen and 4 red flash light at the front LED
                                          but I get 3 led flash on the LED driver board.
                                          I check that few X900F or C YouTube repairs, seems that if you have 4 led red flash it could be due of LED black light error
                                          so I tried...
                                          07-11-2024, 01:45 AM
                                        • ekozeko333
                                          [Help] Lenovo Yoga Slim 7-14ARE05 (DA0LS3MBAF0) – 25Q80DVN1G Flash Is All FF, USB-C PD Stuck at 5V
                                          by ekozeko333
                                          I’m trying to recover a Lenovo Yoga Slim 7-14ARE05 with board DA0LS3MBAF0 Rev:F. I’ve run into an unusual issue where USB-C PD is stuck at 4.7–5V and the system won’t boot (keyboard lights flash briefly, then nothing).
                                          🔥 The Problem Started After Suspected ESD/PD Fault
                                          I experienced a power issue or ESD event through a USB-C charger
                                          After that, the NX20P5090 power switch was visibly burned and was replaced
                                          Now the PD controller always negotiates 5V @ 2A, even with known-good chargers
                                          🧠 What I’ve Done So Far
                                          Flashed...
                                          06-21-2025, 02:48 AM
                                        • corrize
                                          Nikon D800 camera - flash don’t work and capacitor don’t charge
                                          by corrize
                                          Hello, I'm stuck in troubleshooting…
                                          The flash system works like that : when the (mechanic) flash button is pressed, the flash mecanically pop up, and a circuit buck boost elevate 7v (batt) to 200-300v (?) for charging the big capacitor. And when the photo shoot button is pressed, the capacitor is discharged in the xeon light.
                                          In the D800, there is a first « power board » close to the battery. 2 wires (batt 7v) goes to another little « flash board ». I measured 7v, so ok.
                                          When I press the flash button, it's detected by the system, flash icon appear on LDC display....
                                          10-01-2022, 10:02 AM
                                        • Carlos#2003%
                                          Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
                                          by Carlos#2003%
                                          Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
                                          02-15-2024, 07:52 PM
                                          Sony VAIO SVF11N1L2E Hybrid (2-in-1) Fit multi-flip Specification for Upgrade or Repair
                                          This specification for the Sony VAIO SVF11N1L2E Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SVF11N1L2E boardview and SVF11N1L2E schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                          09-06-2024, 05:27 AM
