Sony 49XH9505 four flash of death
  • protonusr22
    • Nov 2022
    • 12
    Hello guys,
    In the meantime I have tried an other quick and dirty trial for fixing this tv. Indeed, one of the backlight leds are gone. On the driver board there is an error detection pin that goes straight to the logic board. If I pull this line down to the ground (I assumed it is safe because it is an output of the led driver and it has a series resistor already on the board). Now the tv passes the self test and runs smooth without resets or any kind of glitch. Fortunately the defective led is on the bottom-left side of the screen and it is not visible during normal operation (eg. watching a movie or playing video games) so I have decided not to replace the backlight assembly because than I would risk breaking in half the LCD during removal.
    Many thanks and I wish you all a great day,
    • kasfamily
      • Aug 2014
      • 765
      • Russia
      Rational decision...
      • protonusr22
        • Nov 2022
        • 12
        • kasfamily
          • Aug 2014
          • 765
          • Russia
          You correctly decided not to disassemble the panel, the diagonal is large and if there is no experience, it can be damaged
          • nomoresonys
            • 12083
            • U.S.
            Some changing info here, you reported that you already tried grounding out the error wire but it did not work, are you saying you did it incorrectly the first time?
            • nomoresonys
              • 12083
              • U.S.
              #26
              Ok, I see, you did it right the second time.
              • protonusr22
                • Nov 2022
                • 12
                #27
                Yes, first time i have tried the BL_ERR between the logic board and psu.
                • Ihandyrepair
                  4 red flash led 65X950G boot Sony and android logo but then black
                  by Ihandyrepair
                  HI guys
                  I got here a Sony 65X950G - I tried to find any repairs guides for this model but not many online
                  here is the issue
                  I have Sony and android logo. but then 4 led red flash lights front of the tv
                  I have 3.3v ref. 12v reg then T con 12v when I press the power on button
                  but then I get black screen and 4 red flash light at the front LED
                  but I get 3 led flash on the LED driver board.
                  I check that few X900F or C YouTube repairs, seems that if you have 4 led red flash it could be due of LED black light error
                  so I tried...
                  07-11-2024, 01:45 AM
                • ekozeko333
                  by ekozeko333
                  🧠 What I’ve Done So Far
                  Flashed...
                  06-21-2025, 02:48 AM
                • corrize
                  Nikon D800 camera - flash don’t work and capacitor don’t charge
                  by corrize
                  Hello, I'm stuck in troubleshooting…
                  The flash system works like that : when the (mechanic) flash button is pressed, the flash mecanically pop up, and a circuit buck boost elevate 7v (batt) to 200-300v (?) for charging the big capacitor. And when the photo shoot button is pressed, the capacitor is discharged in the xeon light.
                  In the D800, there is a first « power board » close to the battery. 2 wires (batt 7v) goes to another little « flash board ». I measured 7v, so ok.
                  When I press the flash button, it's detected by the system, flash icon appear on LDC display....
                  10-01-2022, 10:02 AM
                • Carlos#2003%
                  Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
                  by Carlos#2003%
                  Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
                  02-15-2024, 07:52 PM
                  Sony VAIO SVF11N1L2E Hybrid (2-in-1) Fit multi-flip Specification for Upgrade or Repair
                  This specification for the Sony VAIO SVF11N1L2E Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SVF11N1L2E boardview and SVF11N1L2E schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                  09-06-2024, 05:27 AM
