DDT21H95 DAEWOO CRT TV ADVICE PLEASE
  • zen
    • 511
    Hi all
    This set is not powering , with standby LED flashing GREEN/RED
    PSU secondary supplies present& i assume ok
    Line output transistor measures good
    Took a chance & replaced LOPTX but still same
    Can anyone help with advice or schematic ?
  • zen
    • 511
    Hi
    Managed to prevent the switched supplies from decaying by applying an external 2V5 to pin 4 of the 5 regulators grouped together.
    Starting to suspect the PHILIPS HERCULES CHIP that pretty much carries out all the processing & drives
    Nothing resembling line drive from pin 62 , no data activity either.
    • kasfamily
      • Aug 2014
      • 765
      • Russia
      Hi, maybe the TV model - DDT21H9Z ?
      • lotas
        • Jan 2016
        • 4610
        • Russia
        DAEWOO DDT-21H9ZZF,ZZR CHASSIS CP-099F
        https://elektrotanya.com/daewoo_ddt-.../download.html
        • zen
          • 511
          Hi , yes that's the chassii
          Also just to add , crystal oscillator for chip is spot on at 24.5mhz
          • cubytus
            Samsung UN50TU8000FXZC shows thin horizontal green line when warm
            by cubytus
            Hi to all,
            I was given this TV, an entry-level 4K 50" set. Some have criticized its lack of contrast and relatively poor colour rendering, but for my needs, it's very decent.
            I reset everything to factory settings, but this line keeps on fading in and out when watching a streaming channel from the Tizen firmware. Interestingly, it only happens when TV is warm, after about 1h45 of it being turned on.
            Watching a movie from an external source doesn't trigger the line as easily (needs 2 hours), and from a normal viewing distance, is hardly noticeable. It...
            01-10-2024, 01:26 AM
          • TrueSword88
            Kogan - KALED65XU9220STB - Blue Vertical Line
            by TrueSword88
            Hi all.
            I have a Kogan 65' LCD Panel with a thin blue vertical line (top to bottom) on left hand side of panel.
            The line just happens to coincide with the end of COF and start of the next COF (attached).
            The line is permanent no matter what I've tried. I've tried pressure testing the panel (top to bottom) and all over, I didn't notice any difference with the line, either temporary or semi-permanent.
            Also tried unplugging all flex cables, cleaned with isopropyl then re-inserting to no avail - line remains.
            Hoping to fix...
            05-05-2023, 04:28 PM
          • FALKLAN
            Running Line Voltage and Integrating LED Pods - Automotive
            by FALKLAN
            Howdy everyone! I hope all is well where ever you are!
            I'm attempting to integrate a couple of LED pods into an automotive reverse lamp circuit. The problem being, while the vehicle is running there is a 8.5v current present on the reverse lamp power wire. Needless to say is that all LED pods and lights dimly illuminate while the 8.5v is present, so the LEDs are always powered on while the vehicle is running. When the vehicle is shifted into reverse, the voltage changes to 12 volts.
            I am uncertain how to convert this line into a switched 12v output line for the LED pods....
            02-05-2025, 12:30 AM
          • mindoverflow
            ASUS GTX 1650 Gpu.Initialize Interrupt request line stuck asserted
            by mindoverflow
            hello,
            there is an asus gtx1650 which displays fine in windows but if i run a benchmark test it displays artifacts and the driver crashes after a second or two.
            I changed pads and thermal paste.
            I run mats test but it is reporting 0 errors.
            I then tried to run the mods version 400.271_1650 test, it first ran and stopped with a 'breakpoints limit reached after 5 retries' error and the fans went full speed.
            After a reboot, I tried to run the test again, but now the test fails and says "ERROR: Couldn't clear GPU's interrupt...
            02-09-2022, 03:22 PM
          • Technomancer
            Nintendo 2DS SD Card Reader issue. Problem on the clock line?
            by Technomancer
            I have a 2DS that I am working on that has a problem reading SD cards. It knows that card is in the slot (which, means the detect pin is working anyway) but it says it can’t read the card.
            Here is what I have done so far:
            -Tried SD card in another 2DS and on PC, works great.
            -Tried piggybacking another SD card slot (just so I didn’t have to take the other one off), same issue.
            -Compared voltage drop readings from a working 2DS to the faulty one. All reads are very close except one, the 7th pin from the left, with the pins closest to you, which I believe...
            06-07-2022, 09:01 PM
