sony bravia kdl-46w2000 3 blinking lights pause then 3 again
  • azza1234
    • Nov 2013
    • 124
    • united kingdom
    Hi there was just wondering if someonw could point me in the right direction of repair
    Yesterday I got a Sony Bravia KDL-46W2000 for that was being sold as faulty due to a storm surge and now its got the 3 blinking light fault which ive read is something on the power board do you have any ideas where to begin ?
    Kind regards
    Re: sony bravia kdl-46w2000 3 blinking lights pause then 3 again
    Service manual can be your friend:
    (wait 30 seconds for "get download" to appear)
    Also has main board & power board schematics.
    3 blink code (page 8): UNREG10.5V or PANEL5V trouble. DCALERT1.
    So check those outputs from PSU.
    • Dang
      • Aug 2013
      • 440
      Kind regards
      Lucky boy, that was £20, good deal.
      • azza1234
        • Nov 2013
        • 124
        • united kingdom
        [QUOI E=Dang;411438]Lucky boy, that was £20, good deal.[/QUOTE]
        Did i put £20 if not how do you know I only paid that for it lol
        • Dang
          • Aug 2013
          • 440
          Gumtree.
          • azza1234
            • Nov 2013
            • 124
            • united kingdom
            Tested the outputs and they have 0 volts?
              The UNREG10.5V is measuring 0V? (Pin 7 and 8 of CN6200)
              Check pin 2 CN6202 for POWER ON signal.
              • azza1234
                • Nov 2013
                • 124
                • united kingdom
                hi ive connected it all again but when you put the power cable in theres a click then theres a sizzling like noise from the red area in the picture then it clicks again and the 3 blinking lights start
                could the fault be the sizzling like noise in the red area?
                  Sizzling noise if accompanied by smoke/burning/fire/bad smell/destruction: can be a fault
                  Otherwise, power boards can make a variety of different sounds due to how they work (look up "coil noise") and it's hard to tell if any particular one is a problem or not, so it's good to just go by what you know, checking voltages, tracing back the fault, etc.
                  Of course, if you had another PSU, and it did NOT make that noise, then you could use that as a reference point, but if you can't do that then there's not much information that provides.
                    What DC voltage do you get at the main filter caps 180uF 450VDC C6006, C6008 when you hear the relay click on? Measure it RIGHT AT THE TWO LEGS OF THE CAP C6006 or C6008.
                    The section you redlined is the PFC Voltage booster section.
                    More likely you also do not have the 18v, 15, or 33V which are generated by the same transformer.
                    • azza1234
                      • Nov 2013
                      • 124
                      • united kingdom
                      I get 326v on both
                        So it does not boost up to about 400V before 3 blinks occurs?
                        • azza1234
                          • Nov 2013
                          • 124
                          • united kingdom
                          Sorry yer goes to 390v
                            K, and you have nothing on UNREG10.5V pin? 0V? Or low voltage? Or too much? Please check before 3 blink occurs.
                            • azza1234
                              • Nov 2013
                              • 124
                              • united kingdom
                              Getting 11.6v now on unreg 10.5
                                OK, do you see any pins marked PANEL5V? What do they measure?
                                • azza1234
                                  • Nov 2013
                                  • 124
                                  • united kingdom
                                  No can't see any pins with panel 5v
                                    OK looked it up and PANEL5V is generated by main board.
                                    The UNREG10.5V check is an under volt detect. So I think UNREG10.5V is OK at 11.6V, it is unregulated after all.
                                    Please post a picture of the main board(s)
                                    • azza1234
                                      • Nov 2013
                                      • 124
                                      • united kingdom
                                      hi im away from the tv atm will try to get pictures tomorrow if not will be monday
                                      many thanks
                                      • azza1234
                                        • Nov 2013
                                        • 124
                                        • united kingdom
                                        Are these pictures ok?
                                        • JUCaESAl
                                          Sony bravia KD-65AF9
                                          by JUCaESAl
                                          Hola a todos, necesito el esquema electronico de la placa 1-983-356-11 de un televisor sony bravia KD-65AF9.
                                          Hello everyone, I need the electronic diagram for the 1-983-356-11 board of a Sony Bravia KD-65AF9 television.
                                          10-20-2025, 04:03 AM
                                        • androripara
                                          Sony Bravia 55HX820 - 4 times blinking red standby led
                                          by androripara
                                          i am trying to repair a Sony KDL-55HX820 led TV which is throwing error code 4 (standby led flashing four times).
                                          I followed the troubleshooting flowchart at page 69, and between pin1 and pin7 of CN6002 i am reading 1.91V so i guess i can rule out the B Board as the culprit.
                                          Before ordering new G* Boards (by the way, should i change both? it is not specified in the manual) i wanted to try and do more advanced troubleshooting since i've read in other threads people resolving their problems on the 46/55 HX 820/823/825 models by replacing the Samsung led...
                                          10-19-2023, 05:16 AM
                                        • gkolio
                                          Sony Bravia 55w905a - 4 Red LEDs Blinking then Pink Tint
                                          by gkolio
                                          Hi have problem with 4 reds blink take lot help that forum and tell me change led strips and all going very good tv alive now but in down left have pink tint little and see only in white pages what wrong doing?
                                          12-01-2023, 09:09 PM
                                        • YasaCh
                                          Sony kdl 40p5500 red light keeps blinking 3 times
                                          by YasaCh
                                          Hello...
                                          my tv almost 2 years not powerd on and when i turned it on nothing happened and only 3 red light keeps blinking
                                          i opened the back cover no sign of damage on the powery suply or motherboard
                                          when i plug in the power i hear the reley sound like tik first and another tik..after that only red keep blinking..
                                          another thing is even after i unplugged the power, The tv keeps red blinking 3 times for 2 almost 2 munites
                                          07-07-2025, 11:53 AM
                                        • PopsCaps
                                          Sony Bravia KDL-40V2500 that will not power on
                                          by PopsCaps
                                          I have a Sony Bravia KDL-40V2500 that will not power on. The indicator flashes red 3 times.
                                          I do not hear any sound and I cannot see any backlight.
                                          I have tried disconnecting every cable on each board one at a time to see if anything changes.
                                          The only change is when I disconnect AC-DET cable on the Power Supply board or on the other end if I unplug the CN7009 connection on the B-Board and try to power on the TV the indicator will stay on solid green until I power off.
                                          My friend ordered another used power supply board but it is also doing the red indicator flash 3 times...
                                          03-25-2025, 11:23 AM
