lg55ub850v
  • newtothis
    • Mar 2013
    • 1556
    • england
    lg55ub850v
    lg55ub850v
    Few posts on this one with no fix.
    Usual symptoms of solid led on main with 5 blink led on psu.
    Found bad mosfet for 12v tcon .. only .8v out
    Replaced and have led for tcon on main and 12v hitting tcon.
    Still no back-light.
    So have both leds on main lit. All voltages present from PSU. Still getting 5 flashes on PSU and no power to drv_on.
  • nomoresonys
    • 12318
    • U.S.
    It's most likely the mainboard. probably same old bad bga solder connections.
    • Diah
      • Feb 2013
      • 6511
      it sound issue at LED BL
      • newtothis
        • Mar 2013
        • 1556
        • england
        BL are fine. Forced on by injecting 3.5 to pwron and drv. No flash from BL either... main never sends signal to drv.
        No BGA issues... all packages removed and reballed.
        Replaced ic100 and ic101 just in case.
        No change
        • nomoresonys
          • 12318
          • U.S.
          Maybe trace drv on back through mainboard and see what it hits before the bga and check those components.
          • nomoresonys
            • 12318
            • U.S.
            Post a good focused picture of mainboard and one of the whole back.
            • Diah
              • Feb 2013
              • 6511
              No change
              ohhh big work...
              then what about if you simulate by slide out the wire of DRV_ON from PSU socket and jumper the pin as you did before to PWOR_ON... and turn on what will you have on the screen???
              • advant
                by advant
                02-03-2020, 12:25 AM
              • x_orange90_x
                TCL 50S535 bad tcon or panel issue?
                by x_orange90_x
                Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
                03-29-2025, 11:02 PM
              • cheeky2
                by cheeky2
                05-25-2024, 03:27 AM
              • EazyBone
                Sony XR-77A80J OLED 5 Blink
                by EazyBone
                Another eazybone post took on this OLED now.
                Symptoms. Hit power, white light shows briefly and then 5 blink red code. TCON issue per chart on first picture.
                I'm thinking I have a power board issue though, which is one of the options
                Now to check pin voltages from PSU to main and PSU to tcon
                Pic 2
                1 tcon on 12 -- 0v (when I hit power this goes to 3.1 stays for short time and back to zero)
                2 bl err -- 0.16
                3 evdd on --0
                4. Ac off det 3.187
                5 power on -- 3.362 BUT fluctuating randomly to 3.352
                6 stby...
                10-24-2023, 09:09 PM
              • Dani_2024
                by Dani_2024
                10-28-2024, 05:06 PM
