Hello I picked up this TV from a friend broken. He said it was working fine then one day just wouldn't turn on. After looking at a few thread on this and similar sets I ordered a replacement eeprom and swapped it but it didn't improve the operation of the TV.
When you press the power button on the TV or the remote control the orange vizio emblem briefly flashes white then right back to orange. If you hold down the power button it will repeat this same cycle once every couple seconds.
I checked the voltages on the power supply while pressing the power button. The 12v comes up to 12v for only about 1/10th of a second then drops back to 0v. The on signal from the main board pulses the same way. I disconnected the cable from the main board and used a 3.7v battery cell from ground on the power supply to the "Remote ON/OFF" pin. As long as the voltage is applied to the pin the 12v supply comes up to 12.2v and remains steady. The voltage on the large primary side capacitor goes up to 396v also from 167v when the supply is turned off.
After doing a couple checks I decided to connect another lead from the battery to the Backlight ON/OFF pin. This is where things go wrong. The backlights flash on and off at a couple times a second and the 12v output drops between every flash as well. I suspect there may be something going on with the power supply when it's under a load and is why the set will only power very briefly then back down.
If I unplug either or both sets of ccfl bulbs the power supply does the same thing and only small LED near the OZ9977BGN chip flashes. This LED also flashes along with the backlights when they are plugged in.
I'm not all that familiar with troubleshooting these types of power supplies. So I figured I would turn to more seasoned pros for suggestions.
If I can't repair this one I have no problem ordering a replacement power supply but I want to be reasonably sure that it's a wise investment
If more photos or information is needed just let me know and I'll see what I can do.
