RCA 32 LCD TV Model RLC3273A-B
  • rasscal
    • Jun 2009
    • 21
    I'm having the exact same problems as the Set in this thread
    https://www.badcaps.net/forum/showthread.php?t=25446
    Same model, (when I get home I'm going to check the serial number to see if I didn't buy that exact TV as the OP)
    Anyways, the symptoms are as follows.
    Turn tv on (Standby LED goes from red to blue), backlight turns on, but no image on screen. About 5 seconds later backlight turns off. 3 seconds after that, set goes back to standby (blue LED turns back to red).
    I checked the PSU voltages and they all seem fine, no visibly swollen caps. There is a pair of wires (BLON/PWM) from the mainboard directly to the inverter board. If I jumper the PSON the and the BLON to 5v, both the power supply and backlight turns on, and the backlight stays lit as long as I leave it that way, so it appears neither the PSU or inverter has a problem.
    To test this out, I completely disconnected the inverter (no power, no BLON/PWM) and I disconnected the T-Con from the mainboard. I also disconnected the 24V line to the Mainboard (which appears to be for the audio amplifer portion of the mainboard)
    I just left the control button/IR/Power LED board and the +5v/12V/5SB connections attached and switched on the set. Same result, LED turns blue, but goes back to red (standby) after about 8 seconds (5+3), so it appears that the problem is with the Mainboard.
    Can anybody confirm my diagnosis?
    BTW, the mainboard is marked CV318H-X which appears to be used in many RCA/Westinghouse/Curtis/? sets. Anybody have a schematic or any idea what might have failed on it if it is indeed the problem?
    Thanks.
  • multimeter
    • Jan 2011
    • 739
    • united kingdom
    Re: RCA 32 LCD TV Model RLC3273A-B
    Thanks.
    if the voltage rail from the mainboard to ps_on is dropping off,it will trigger a series of shutdown procedures,does ps_on voltage drop off when monitering with your multimeter?,seeing as you have disconnected inverter etc,it could well be a main board failiure.
    any pics of the psu,mainboard?ive seen the other thread pics,but they can be different,and may show up something that others and my self could see
    fixed so far...376 lg lcd tv's,24 onn tv;s,24 panasonic lcd,16 jvc lcd,12 marshall jcm800 amps,refurb of various disco equipment lighting,old style disco decks ,and a flymo!
    please let us know if everything works ok if your tv gets fixed, as it will be and aid for anyone else having the same problem and wishing to fix it.it would save people clogging up this site with topics that are duplicated,and can be found easily using the search function.,and taking up valuable space.enjoy your fixed tv!,hopefully!
    • rasscal
      • Jun 2009
      • 21
      Turns out my memory was a little off when I wrote my previous message. The startup sequence is like this:
      Press power button. Set turns on, red LED turns Blue, PSON goes to 4.15 volts from 0.04
      2 seconds later backlight turns on, but no image on screen
      5 seconds later, backlight turns off AND LED turns red from blue
      1 second later PSON goes from 4.15 to 0.04 volts.
      I also watched the 5VSB and 5V lines and both were about 4.9volts.
      The 5VSB never fluctuated as the set turn on or off.
      The +5V switched off 1 second after the LED turned red (in step with the PSON line going low)
      I was told that the set was only just over a year old, and there seems to be a few of these on the local Craigslist for sale "As-Is". Replacement boards don't seem to be available yet, although the mainboard design looks it's been around for a while. I think I might try a board from a different TV set to see if I can get the screen working.
      Here are pictures. The back shows the pinouts
      My set's serial number ends with 407, the one in the other thread ends with 545. I think I can safely say they are pretty much identical, right down to the part numbers on the boards.
      • AustinComputerDoctor
        Sharp CC-60LE640U - after mainboard replacement, backlite turns on -- but cannot update firmware / see menu
        by AustinComputerDoctor
        I am looking / wondering if anyone knows where a good firmware download link is for a LC-60LE640U, the sharp support sight says the screen is archived but offers no links.
        I see backlite is active,
        but I cannot get the screen to return back to menus , etc
        This is all after replacing the mainboard...
        any assistance is greatly appreciated.
        03-25-2024, 12:43 PM
      • Stephen
        MacBook Pro 14" M1 Pro Turns on functions then turns off when I plug in USB C cable
        by Stephen
        MacBook Pro 14" M1 Pro Turns on functions then turns off when I plug in USB C cable to reset the computer. I disconnect the battery fully and then reconnect it and it won't turn back on. After letting it sit for a day I plug the battery back up, and the MagSafe 3 cable and it powers on and stays ons, once I plug in a USB C cable into the port closes to the MagSafe port it turns off and the Amber light turns off and won't turn on. No water damage, nothing, I want to do a DFU restore to wipe the computer since the customer stated they did an update and ever since it just decided to not work...
        03-15-2024, 09:37 AM
      • Mirenia
        Dell Latitude 7420 - Touchscreen not working since Mainboard replacement
        by Mirenia
        I've got a little "problem child": my Dell Latitude 7420 2-in-1, which had a faulty mainboard.
        I replaced it, but ever since, the touchscreen no longer works — and honestly, I’m running out of ideas…
        In Windows Device Manager, I just see an I2C HID Device with error code 10. Sporadically, the touchscreen is recognized correctly for just a few seconds, but I haven’t been able to determine under which circumstances this happens.
        The touchscreen also doesn’t work in UEFI/BIOS, although it’s enabled...
        03-30-2025, 06:47 AM
      • www
        LG L192WS-BN backlight turns off after 1 second
        by www
        I am testing an old LG L192WS-BN monitor I have that gives an image, but has a backlight issue. When you turn it on the backlight turns on 1 second and it turns off, turns on again, 1 second and it turns off and stays off. Using a flashlight I can see there's still an image.
        I replaced a bulged cap on the main board, but made no difference. I also got another exact same model monitor that has a broken ccfl (the connector got ripped from the panel and the main screen connector is also broken so I can't use this panel to test), tried using the main board from this one, same issue....
        03-24-2024, 05:26 PM
      • zklgfs
        Anker SoundCore 2 Bluetooth Speaker Turns Off After a Few Seconds (Possibly Firmware Issue?)
        by zklgfs
        I have an Anker SoundCore 2 (A3105) that I saved from the trash (well, I guess there's a reason why it was supposed to go into the trash...). The problem is that it always turns off after a few seconds (sometimes it stays on a bit longer, between 30 and 60 seconds, but it still turns off). The power light turns on and the bluetooth light starts blinking, but both abruptly turn off again. The "turn off sound" is still played after the lights turn off. Sometimes, it also loops the on-off cycle several times without me pressing any buttons. If I connect an AUX cable, music...
        08-11-2025, 02:14 PM
