Samsung LN52A850S LCD Vertical Line
  • 8cuda
    • 46
    Not sure if the TV panel is causing the single thin vertical line, right down the center of the screen. After a hour or two, the vertical line goes away. Heated the T Con board, the ghosting image would go away.
    I replaced the T Con board with board from ebay, cracked screen per the seller.
    The vertical line still remains, but the ghosting image is gone.
    Can the issue be caused by the mainboard or bonding tabs?
  • capkid
    • Oct 2010
    • 1339
    Re: Samsung LN52A850S LCD Vertical Line
    It looks like a panel issue.
    LG Plasma Mal-Discharge Correction Service
    • richajem
      • Dec 2013
      • 28
      I have the same exact TV and with the same sort of problems.
      1) Ghosting appearance even after replacing the T-Con board, still looking into panel tab bonds
      2) Single dead Line running right in the middle
      This tells you that these particular Samsungs had a manufacturer problem that Samsung didn't want to dive into as far as recalls or even remotely to help.
      So far I took it apart as far as the panel but not as deep into the removal of the panel frame to see if the tab bonds are the issue. That is next.
      • tibimakai
        • Jan 2012
        • 3680
        Most likely bad panel. Try the tab fix with pads.
        • bassim
          • Jan 2016
          Hi
          Did you get this fixed as I have the exact same problem?
          Manjit B
          • mrsith
            Samsung UE58TU7100K - no picture, vertical line
            by mrsith
            Hi.
            Got UE58TU7100K with no picture - backlight comes on though. Figured out that's a perfect candidate for cut tape method.
            This model has just one LVDS tape coming off main board - and two panel boards underneath the LCD screen are connected to each other via small tape. Like curved screens. I've tried to disconnect half of the screen (5he side without LVDS connector on it, obviously), no joy.
            Disconnected the tape (main board side). Applied a small piece of tape, covering first ~4-5 pins. Powered the TV on - got picture. In negative, but that's...
            02-07-2023, 11:18 AM
            09-07-2024, 05:50 AM
          • kotel studios
            Samsung LC32HG70QQUXEN - vertical and horizontal stripes across the screen
            by kotel studios
            Just now my Samsung LC32HG70QQUXEN monitor gave up on me. On cold boots I get many vertical stripes going across the screen (see the attached picture). After it runs for 1-2 minutes those go away but there are horizontal stripes going across the whole screen no matter of the input and PCs I use. (couldn't take an picture of it since the image size goes to 20MB and the camera doesn't pick them up)
            In a video about a 27" monitor with an similar issue the guy removes one resistor and supposedly the entire monitor goes back to life? For sure this fix is only temporary....
            08-06-2025, 02:07 AM
          • sputnikoff
            samsung un58tu7050 single vertical line.
            by sputnikoff
            Had a friend drop this tv off and initial issue was no power.I could see faint glow when powered up .Lamps all fired up fine.I removed flat lvds cable and reseated it,then tv screen came on.After i reassembled it now has single line pretty well dead center of screen.Is there ongoing display issues anyone is aware of.Any input welcome.
            02-25-2023, 09:42 AM
          • TrueSword88
            Kogan - KALED65XU9220STB - Blue Vertical Line
            by TrueSword88
            Hi all.
            I have a Kogan 65' LCD Panel with a thin blue vertical line (top to bottom) on left hand side of panel.
            The line just happens to coincide with the end of COF and start of the next COF (attached).
            The line is permanent no matter what I've tried. I've tried pressure testing the panel (top to bottom) and all over, I didn't notice any difference with the line, either temporary or semi-permanent.
            Also tried unplugging all flex cables, cleaned with isopropyl then re-inserting to no avail - line remains.
            Hoping to fix...
            05-05-2023, 04:28 PM
