Samsung Plasma HP-R5052 Won't fully come out of standby
  • 2dbit
    • May 2012
    • 81
    So, with this tv, I suspect the SMPS has an issue, but I could be wrong. Still learning!
    When the power button is pressed, I get a lot of relay clicks on the board, and VA comes to life, but VS and all subsequent voltages don't really come around. (VS hovers around 300mV, I say hovers because it tends to drift as low as 100mV and as high as 400)
    The voltages measured on the board are as follows:
    (Measured on connector CN804-1)
    STD-5V is 5.15v
    PS-ON while in standby measures 3.716 to ground, but when the power button is pressed, drops to 6.1mV. This to me sounds like the logic board is happy and is telling the SMPS to fully turn on?
    I did see VCA and VCS voltages pulsing, but I am not clear as to what those should be doing, so I am not sure if there is a defect there.
    (Measured on CN810)
    STD5V measures at 5.15v
    VS-ON - 3.339
    PS-ON is 3.72v until power button is pressed, then drops to 6mV.
    I have tried individually unplugging each board testing and plugging back in, No effect.
    I'm to the point where I think I need to unplug absolutely every board from the SMPS and trigger it on. It would seem that all that's required is a jumper from PS-ON to RTN. I have seen where people use a 100ohm resistor. Not sure if that's necessary or not. Haven't done anything yet, so I'll see what this community has to say first!
  • 2dbit
    • May 2012
    • 81
    Re: Samsung Plasma HP-R5052 Won't fully come out of standby
    Ok, so the problem was isolated to two blown mosfets on the powersupply board. Well, two shorted Fets, and a blown fuse. Thinking that was it (I have no schematic so when everything around it appeared to be normal I assumed they were the only failure) I ordered two new Fets and a couple of fuses. Put it all together with the output connector removed to protect all downstream boards incase of failure(thank god I did that)and BAM, a few seconds after power application the fuse blew so hard it separated its own case, blowing the top half of the SMD fuse past my head...scary as hell.
    Realizing that I'm already out ~$20 in parts on this thing, when I found a "new" power supply on fleabay, I figured it was just easier than dealing with this one. I received the power supply and this thing is far from new. Aside from a thousand telltale signs that this thing has been previously installed in a TV, it had no ESD packaging. It was wrapped in bubble wrap that had packing peanuts static clinging all over when removed from the Zappos box.
    Ok, so I give the seller an A+ for effort. It was very well protected within its box from any sort of impact that could occur during shipment. But an F for ESD protection and an D- for product description (hey at least it was the right part).
    ANYWAYS. Back to the point. Installed same as the other and powered on. Turns on just fine and puts all the right voltages out. So, I figured ok...lets do this.
    Hooked it all up and well...there's at least an image on the screen. Next post will contain pictures of what the new issue is.
    • 2dbit
      • May 2012
      • 81
      Here's the current problem with the TV.
      It powers up, but the blue screen has white (with some color) snow at the top and bottom. Here's a picture of the blue screen with menu pulled up:
      Here's a pic of a Solid black screen (ignore the diagonal shadows cast from a nearby object on the screen)
      Here's the signal pattern of scrolling gradient:
      • 2dbit
        • May 2012
        • 81
        Bueller...
          Check panel voltages: Vs, Vset and Ve, are OK and measure at stickered ratings.
          • 2dbit
            • May 2012
            • 81
            I checked and double checked. All voltages are 0.2v or less from sticker
              OK, see if you can find Yfr and Yrr control on Y-main. Try adjusting it. What happens?
              • 2dbit
                • May 2012
                • 81
                I will have to do that when I get home. I have a digital oscilloscope, its only 60Mhz, so its under the 200 mark that would be ideal, if I mess with those pots, how can I ensure I get them back to where they belong if they're not the issue?
                • anotherdude
                  • Feb 2013
                  • 488
                  • uk
                  they are usually marked with a pen to show were they where
                  • 2dbit
                    • May 2012
                    • 81
                    OK, will report back
                      I have used a 20MHz scope to check plasma waveforms, no problem. I always set the pots by eye - looking at the panel for minimum maldischarge point.
                      • 2dbit
                        • May 2012
                        • 81
                        Ok, so rotating the two pots... the bottom pot (they're not marked) would cause the image to only get worse (fuschia), rotating the top pot, only once rotated to the extreme, would get rid of almost all the snow, but the image is something terrible at that point. On a black screen, the menu is mostly just white. While at minimal snow, rotating the other pot would only add fuschia to the picture.
                        • 2dbit
                          • May 2012
                          • 81
                          could it be possible dirty power? Suppose I could always scope it...
                          • rju
                            Samsung 60" Plasma TV, Blinking Standby LED
                            by rju
                            A sports bar/restaurant with ~40 Samsung Plasma TVs. This is the 2nd TV that has a blinking standby LED. I'd like to learn how to repair these TVs because I'd guess that over time more and more of them will develop this symptom. My hope is to repair the bad PCB, however if that's not realistic then I'd replace the bad PCB.
                            Model PN60F5300AF, Type PN60F5300, Model Code PN60F5300AFXZA
                            Upon applying power, the red standby is steady. When I tap the power button, the standby LED immediately blinks twice, then it blinks once ~ every 4 secs. Also, Upon applying power, the...
                            07-21-2020, 05:23 AM
                          • check12
                            Samsung Plasma PS43F4500AW Won't Start (flashing standby)
                            by check12
                            Hi ... Samsung Plasma PS43F4500AW ... when powered with 240V mains standby flashes, pressing PWR button causes standby LED to go out but nothing further happens.
                            I have already removed and benched the SMPS, jumpered PS_ON to GND, VS_ON to 5.3v and have VS & VA voltages and all other voltages available at CN4007.
                            VS=213v
                            VA=58v
                            SVT_VS=213v
                            This suggests to me that the SMPS is probably ok but I have no experience of TV repair so could do with some help.
                            I have removed the XY-Drive board and checked all the ribbon cable...
                            11-21-2021, 07:46 AM
                          • 7ony
                            Samsung plasma - flashing standby light
                            by 7ony
                            The TV is a 2013 Samsung plasma, model # PN60F5300AFXZA.
                            Snagged it up in non-working condition a couple years ago. Previous owner said that sometimes he could get it to come on after repeated tries but other than that he couldn't get it to turn on.
                            Personally I haven't been able to get it to turn on at all. The standby light comes on solid when plugged in, but pressing the power button results in the standby light flashing once every 4 or so seconds. No "click" noises, no light from the panel at all. Just the flashing standby light.
                            No visible...
                            08-31-2020, 05:18 PM
                          • fharris1977
                            Vizio D50u-D1 Dead Set No Standby
                            by fharris1977
                            Hi. I got a Vizio with no power or standby, and won't turn on with remote or button. I checked the voltages on the connector and all read 0.00V or nearly 0(0.050 ON/OFF pin). None of the pins are labeled STB for standby although I do see some 5V pins. Other than the obvious standby led, which isn't coming on, is there a way to check for standby voltage on this PS. I'm trying to see if my problem is the PS or mainboard. Some Vizios I have fixed with no standby led me to think it was the PS but it turned out being the mainboard. Any experience with this set would be greatly appreciated.
                            12-28-2023, 10:25 AM
                          • Crystaleyes
                            Samsung BN44-00259A standby question
                            by Crystaleyes
                            Hi all.
                            I started a thread while back regarding TV power supply standby circuitry as it is something I am not quite on top of.
                            SMPS theory and function is becoming more familiar, however the standby part is still a bit of a mystery.
                            Anyway, a friend has this TV with the above mentioned power supply board which has no standby voltage, nor any other voltages leaving the board.
                            The mains AC comes in fine, gets filtered and rectified with power is on the main filter cap as well as the transformer and drain pins of the ICE3B0665J, but that's it.
                            08-11-2023, 05:15 AM
