Panasonic Oled 55EZ950E, no picture, red led blinking every 4 sec
  • riparo
    • Jan 2024
    • 72
    • ITALY
    Hi everyone, I have a Panasonic OLED TV model 55EZ950E, as soon as I turn it on I don't have any image the LED goes from green to red LED blinking every 4 sec, I found the service manual suggests checking OLED PANEL, PB BOARD, T-CON connectors but it seems like everything ok, I didn't find any burns under the pb board
    I attach a link to download the service manual, thank you for anyone who can help me
    https://tel-spb.ru/download/?brand=P...0E_LA73.rar​
  • Diah
    • Feb 2013
    • 6399
    we need the set all boards photo.... to see where and how connected
  • riparo
    • Jan 2024
    • 72
    • ITALY
    Attached are the photos of the TV cards,from the service manual they suggest checking the card called pb card the central one, I tried to DISCONNECT everything leaving the p card connected, the main ps card and the main board but the problem persists I think the problem is on the first power supply cardClick image for larger version
    • riparo
      • Jan 2024
      • 72
      • ITALY
      can anyone help me? I checked on the main called p main psu the 16 volts are missing, what could the component be?
      • Diah
        • Feb 2013
        • 6399
        put every socket in place and just disconnect the 2 LVDS between Main board and T-CON ... power on and check on T-CON the 12 V & 24V on both fuse side near the sockets white and black
        • riparo
          • Jan 2024
          • 72
          • ITALY
          ok thanks for the reply I'll check
          • Davi.p
            Hobbist Tech
            • Sep 2009
            • 4367
            • Italy - Milan
            Hi, is there 400VDC and approx 15VDC on the 3 pin connector P<>PB boards, respect to HOT GND pin? Have you replaced those 2 black caps on the PB? Replace back with original ones my advice..
            • riparo
              • Jan 2024
              • 72
              • ITALY
              Thanks for the help you give me, I'll check tomorrow and update you
              • riparo
                • Jan 2024
                • 72
                • ITALY
                Hi everyone, I carried out the checks as per the suggestion, the 24 volts are not present on the PB board, on the 3 pin connector P<>PB boards there are only 380 volts which are lowered when the TV goes into protection, the 15 volts are absent, on the p board the main capacitors have 320 volts, the 5 volts are always present while the 16 volts are present only at the moment of switching on then when the TV goes into protection they are no longer there while on the t-con they are neither present 12 and not even 24 volts,
                I await your other suggestions​Click image for larger version
                • Diah
                  • Feb 2013
                  • 6399
                  what are you doing....?? read my post 5 and do it exactly
                  • riparo
                    • Jan 2024
                    • 72
                    • ITALY
                    Hi Diah I tried as you suggested by connecting all the cables and leaving the 2 LVDS don't look at the photo posted, I used it to indicate the voltages I checked, all the connectors were connected except LVDS but I don't have any voltage, nor 12 nor 24 volts, as I underlined before I have those values on the cards, I have the 5 volts fixed, then the 16 volts disappear as soon as the red LED error appears, the 24 volts on the card called pb are also missing, while there is 'LED error all the voltages of the main capacitors are lowered, in the p board I have 320 volts while in the pc board 380
                    • Davi.p
                      Hobbist Tech
                      • Sep 2009
                      • 4367
                      • Italy - Milan
                      I don't like to fight every time or challenge with others, but someone in this forum elected himself as "the OLED man", that advice (and others..) can't work! If main board connections to tcon are interrupted , the tcon dc dc converters doesn't start, so tcon SoC doesn't start and communicate the main board to switch on the panel supply rails..
                      "Riparo": are output values mentioned on the power boards silkscreens or manual? The PB board has a brown tie of cables that goes to the tcon.. i've never seen or heard tcon working at 16v... i see on the P board a group of red and brown cables to the mainboard, then from there some white cables to the tcon.. i cannot spend just now time to get and read manuals, but my guess is that P board provides 5 and 12v to main board, beacause main board needs 12v for audio, tcon via lvds cables and tcon/panel via second cable.. the PB board feeds maybe the panel but at which tension? 16..24..variable volts? which one?
                      Let's say that panel works at 16v.. them are present for a bunch of seconds, so the problem lies more probably on the screen circuitry, so i guess bad panel is the most possible, this because tcon approved panel feeding (tcon ok) but an overload takes place immediately.. bye..
                      • Diah
                        • Feb 2013
                        • 6399
                        pull shit
                        yes i am OLED man..
                        yes OLED TV Main boards and PSU work together with out LVDS in place
                        yes PSU and T-CON and Module can run alone in standalone test mode
                        yes OLED MB working only the sign of audio Optic port lit red..
                        do you want more to learn.
                        • Davi.p
                          Hobbist Tech
                          • Sep 2009
                          • 4367
                          • Italy - Milan
                          PSB+Screen alone needs a modification (jumper wires)..
                          • Davi.p
                            Hobbist Tech
                            • Sep 2009
                            • 4367
                            • Italy - Milan
                            riparo: you surely ask yourself "so what to do?" , i think starting the screen self test will produce again tv protection... your only hope is that tcon SoC or surroundings ram/rom has bad soldering and them are driving bad the oled panel or simply commands MB to shut off (watchdog? or what else..), so the first thing for me is to try heating with hot air a bit some minutes but not so high temp. the SoC area, not a real reflow.. 3minutes for starting.. let't hope..
                            PS: are you able to see tickets of which is the manufacturer of the oled panel? it's important.. maybe is LG.. them suffers bad tin..
                            • riparo
                              • Jan 2024
                              • 72
                              • ITALY
                              first of all I thank you both Diah Davi.p , the values mentioned are those silk-screened on the P card, when I turn on the TV and then it goes into protection the 5 volts remain fixed, while the 16 volts are seen for a few seconds and then disappear, measuring the 4 mosfets positioned near the red connector on the P HO 14 VOLT fixed, couldn't there be a problem with the P board? Why isn't it providing the correct voltages? the PB board PORTS POWER to the T-CON, but on the PB the 24 volts necessary in my opinion to turn on the panel are missing. I must specify that when the TV goes into protection even on the main I have no power the optical port turns off, I tried to connect only the P card and only the main but the TV always goes into protection, that's why I assume that the problem is on the P card, CMQ if I can I leave the service manual if you want to take a look and I await your suggestions https://tel-spb.ru/download/?brand=P...Z950E_LA73.rar
                              • Davi.p
                                Hobbist Tech
                                • Sep 2009
                                • 4367
                                • Italy - Milan
                                i see no voltages tables on the boards, is it that difficult to report them here?
                                • riparo
                                  • Jan 2024
                                  • 72
                                  • ITALY
                                  here are the voltages, I noticed that when it goes into protection the relay switches off, which is why there are no more voltages, only 5 volts present, could it be a defect in the relay?Click image for larger version
                                  • Davi.p
                                    Hobbist Tech
                                    • Sep 2009
                                    • 4367
                                    • Italy - Milan
                                    Ok so is an LG panel, take all with the doubt... watching the bigger photos (without taking the manual) i see the PB board provides 24V and only that to tcon, P board provides 12V to main board and then it goes to tcon via left white cables and probably is the only 12V (right lvds doesn't have fuse so no power supply). Main board commands PB to switch on via right 2 brown wires. So try if you want my advice to heat the tcon board with hot air..
                                    • riparo
                                      • Jan 2024
                                      • 72
                                      • ITALY
                                      ok thanks I try to follow your advice warming up the chip for 3 minutes at a temperature not very high I'll let you know
                                        ASUS VivoBook Vivobook Pro 15 OLED D3500QC-L1351W Notebook Pro 15 OLED Specification for Upgrade or Repair
                                        This specification for the ASUS VivoBook Vivobook Pro 15 OLED D3500QC-L1351W Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Vivobook Pro 15 OLED D3500QC-L1351W boardview and Vivobook Pro 15 OLED D3500QC-L1351W schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                                        09-07-2024, 04:30 AM
                                      • FZG
                                        Panasonic AG-1000B VHS player with bad picture quality
                                        by FZG
                                        Hello!
                                        I recently got an old VHS player from Panasonic and just for fun I want to try to repair this device. It is an AG-1000B portable VHS player from 1990 and it has a problem with picture quality in playback mode.
                                        Picture in playback mode is very noisy and often loses sync but the still images are nearly perfect.
                                        I want to know, is this something that could be solved by recapping or is the video head likely gone?
                                        Also, what mechanism is this?
                                        Any feedback is appreciated!...
                                        05-06-2024, 07:16 AM
                                      • pingaroon
                                        Panasonic TX-37LXD85 blinking LED no picture
                                        by pingaroon
                                        Just so you know, I have zero knowledge or experience of fixing TVs - I'm a laptop repair guy, who can do board repair, so hopefully you guys can guide me how to determine where the fault may lie.
                                        So, TV has worked perfectly for years. Watching it tonight, the screen suddenly switches itself off and there is a red LED which blinks every few seconds forever. It doesn't blink a certain number of times, it just blinks on and on until the TV is manually powered off
                                        Powering off the TV, and back on, the LED goes green and the sound from a roof aerial...
                                        01-27-2022, 02:01 PM
                                        Gigabyte AERO 14 OLED BMF-72ESBB4SH Notebook Specification for Upgrade or Repair
                                        This specification for the Gigabyte AERO 14 OLED BMF-72ESBB4SH Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 14 OLED BMF-72ESBB4SH boardview and 14 OLED BMF-72ESBB4SH schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                        09-07-2024, 07:12 AM
                                        Gigabyte AERO 16 OLED BSF-A3LA964SP Notebook Specification for Upgrade or Repair
                                        This specification for the Gigabyte AERO 16 OLED BSF-A3LA964SP Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 16 OLED BSF-A3LA964SP boardview and 16 OLED BSF-A3LA964SP schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
