ok I left only the bridge from pin 11 of the P card to PIN 1 of the pb card, I connected the P card to the A (main) card and when I do so I have voltage 5. 16 and 24v for a few seconds then the television goes back into protection, removing card A and bridging the SUB P ON I HAVE NOTHING, ok I'll do a check as you said, I'll update you
Panasonic Oled 55EZ950E, no picture, red led blinking every 4 sec
hi, Davi.p as you indicated, I checked all the control pins of the connector of the P board and the voltages when turned on rise and then fall again, I tried to make a bridge between the pwn on pin and the 5 volts and on the P board as well as having 5 volts fixed on the 16 volt test point by measuring I have 5 volts fixed, the 16v are not activated
hi Davi.p I made the connections you indicated, connecting pins 13 and 17 together, then I connected them to pin 11 but the 16 volts on the P board are not activated, furthermore by making this connection I no longer have the 5v standby, by disconnecting the two pins 13 and 17 the 5 volts return, this is very strange, it seems impossible to me that the 16v cannot be activated
I guess that SUB-ON is not a control pin to turn on the 16v but is the 5vsb rail (5V is too high for a control pin..) !!! (Aaah.. Panasonic, confusion!).... so i guess also pin 11 is right GND (why you told so first and after not??), if you check the P board connector at open circuit and you see SUB-ON=5v and Power-On=0v then we are at horse... so connect only SUB-ON---Power-On and check for the 16v output.. if ok then redo the previous guide test..Last edited by Davi.p; 02-15-2024, 09:15 AM.
