I correct the post, the 5 volt power supply is present, the 16 and 24 volts are missing after carrying out the test as you suggested
Panasonic Oled 55EZ950E, no picture, red led blinking every 4 sec
Originally posted by Davi.p View PostThe Sub-pwr-on needed probably to be tied to gnd to activate the pfc+24v
Originally posted by Davi.p View PostCheck these components..
hello Davi.p update you on TV, I made the connection again, without making the bridge from pin 11 and 13 , I only left the bridge from pin11 card P to PIN 1 pb card, connected the P card to card A (main) and when I do current I have the voltage 5. 16 and 24v for a few seconds then the TV goes back to protection, if instead I connect card p-pb and card A I have not 16 and 24 not even for few seconds, to premise that these tests I carried out with the tcon disconnected
the long work week is coming to the end and i think i can follow you..
when you done my test you went out saying you havent more 16v, this made me think my test damaged something, but you never had a steady 16v, so no damages, now i noticed the simplified block schematic reports a couple of switches that enables PSB 16v output, those are always on (strangely!!) but disabled in standby, now if short "5v to Sub-P-on" didn't worked, check Sub-power-on pin at no load, if it is high level then needs to be shorted to gnd to make all power board be active, if that is the case, repeat all my test with the necessary changementLast edited by Davi.p; 02-09-2024, 01:41 PM.
Originally posted by Davi.p View Postthe long work week is coming to the end and i think i can follow you..
