Panasonic TX-37LXD85 blinking LED no picture
  • pingaroon
    • Nov 2019
    • 121
    • uk
    Just so you know, I have zero knowledge or experience of fixing TVs - I'm a laptop repair guy, who can do board repair, so hopefully you guys can guide me how to determine where the fault may lie.
    So, TV has worked perfectly for years. Watching it tonight, the screen suddenly switches itself off and there is a red LED which blinks every few seconds forever. It doesn't blink a certain number of times, it just blinks on and on until the TV is manually powered off
    Powering off the TV, and back on, the LED goes green and the sound from a roof aerial TV channel is heard for about 3 seconds, but with no picture, and it then switches itself off and the LED goes into its perpetual red blink cycle.
    Can anyone help a total novice at least determine where the fault may lie (I'm handy with a multimeter). I've seen spare T-CON boards and inverter boards on ebay for this model and I'm hoping swapping one of those will do the trick.
    Thanks in advance,
  • nomoresonys
    • 12085
    • U.S.
    Re: Panasonic TX-37LXD85 blinking LED no picture
    Shine a torch on it maybe from an angle if needed, hit menu see if you see an image at all or text.
    • nomoresonys
      • 12085
      • U.S.
      Try a couple simple resets, unplug tv for 5 minutes, plug back in try it, another, unplug tv press and hold power button on tv for 30 seconds, plug in and try it.
      • nomoresonys
        • 12085
        • U.S.
        Probably tho it's time to take the back off and investigate, can you post some good focused straight on pictures of the whole back and each board?
        • pingaroon
          • Nov 2019
          • 121
          • uk
          Hi, shining a torch reveals there *is* in fact a picture, so it looks like this is a backlight issue. I get no more than 3 seconds and it switches to blinking red LED mode.
          • pingaroon
            • Nov 2019
            • 121
            • uk
            Hi, none of the resets have brought it back, but I now know it's a backlight problem as the picture is in fact there.
            • pingaroon
              • Nov 2019
              • 121
              • uk
              Hi, yes I can do this tomorrow, thanks.
              • nomoresonys
                • 12085
                • U.S.
                Another easy step is in signature below.
                • pingaroon
                  • Nov 2019
                  • 121
                  • uk
                  Hi, I found someone who knows a lot more than me who's willing to repair it. I'll update what the fault was once done for the record. Thanks for your assistance (and the warning)
                  • nomoresonys
                    • 12085
                    • U.S.
                    Ok, thanks for the future update.
                    • pingaroon
                      • Nov 2019
                      • 121
                      • uk
                      Hi, it was the inverter board - a few bad caps had blown and taken out some transistors along the way. All up and running again. Thanks
                      • nomoresonys
                        • 12085
                        • U.S.
                        Glad to hear it, thanks for the update.
                        • riparo
                          Panasonic Oled 55EZ950E, no picture, red led blinking every 4 sec
                          by riparo
                          Hi everyone, I have a Panasonic OLED TV model 55EZ950E, as soon as I turn it on I don't have any image the LED goes from green to red LED blinking every 4 sec, I found the service manual suggests checking OLED PANEL, PB BOARD, T-CON connectors but it seems like everything ok, I didn't find any burns under the pb board
                          I attach a link to download the service manual, thank you for anyone who can help me
                          https://tel-spb.ru/download/?brand=P...0E_LA73.rar​
                          01-11-2024, 12:35 PM
                        • Tof
                          Panasonic Oled TX-65FZ800E, no picture, red led blinking every 4 sec
                          by Tof
                          Hello everyone, here is the issue I am facing with my Panasonic Oled TX-65FZ800e.
                          When the TV has not be used for some hours, I power up the TV with a video input and the image is displayed perfectly for 30seconds and then the TV switch off with the red light blinking every 4 seconds for ever.
                          The service manual explanation: EVDD_SOS (EVDD 24V error) with check point (oled panel, P board, A board, T-CON)
                          I opened it and found a burned connector on PB-board on the 24V pins.
                          The 24V wires have change a bit of color due to the overheat and the corresponding...
                          02-01-2022, 03:18 PM
                        • FZG
                          Panasonic AG-1000B VHS player with bad picture quality
                          by FZG
                          Hello!
                          I recently got an old VHS player from Panasonic and just for fun I want to try to repair this device. It is an AG-1000B portable VHS player from 1990 and it has a problem with picture quality in playback mode.
                          Picture in playback mode is very noisy and often loses sync but the still images are nearly perfect.
                          I want to know, is this something that could be solved by recapping or is the video head likely gone?
                          Also, what mechanism is this?
                          Any feedback is appreciated!...
                          05-06-2024, 07:16 AM
                        • Bazfletch3
                          Panasonic TH-65FX800A backlight LED's working but picture is very dark
                          by Bazfletch3
                          Hi all
                          While I have quite a decent background in electrical & electronic troubleshooting & repairs, this is my first time stripping down an LCD TV for repair.... I have inherited a 3yr old Panasonic LCD which has a picture, but it is quite dark (too dark to be watchable - but still quite easy to see; I didnt need a torch to see it).
                          I started by checking and trying to adjust all of the picture and backlighting levels, but that made little to no difference. I also did a factory reset.
                          From there I envisaged that the backlighting wasn't working, however...
                          01-08-2024, 10:18 PM
                        • Tr0ll
                          by Tr0ll
                          Original T-con:
                          First replacement T-con:
                          10-07-2023, 07:48 PM
