Panasonic TC-P42S30 issues
  • SCITOMMY
    • Dec 2013
    • 35
    • US
    #41
    Re: Panasonic TC-P42S30 issues
    I find it wierd that you bought a "refurbished" board and it seems to have shorted components. I thought refurbished meant fixed and working.
    • Ccalxr
      • Oct 2012
      • 33
      • U.S.
      #42
      one would only think!
      • Ccalxr
        • Oct 2012
        • 33
        • U.S.
        #43
        ok so i did get my hands on a digital voltmeter and some of the mosfets are short on both boards. not all the same. go figure...
        • SCITOMMY
          • Dec 2013
          • 35
          • US
          #44
          Did you put the old board back in? Are you getting the same symptoms now as the new board?
          • Ccalxr
            • Oct 2012
            • 33
            • U.S.
            #45
            havent put the old one back in yet. ill let you know once i do
            • Ccalxr
              • Oct 2012
              • 33
              • U.S.
              #46
              just a quick update. bought a new A board just to see if it was that and no... same thing. so it has to be the sn board or the panel. right now im having a hard time finding a new sn board
              • SCITOMMY
                • Dec 2013
                • 35
                • US
                #47
                Did you put in your old SN board?
                Did you get a refund on the new SN board that was bad?
                What is the same with the new A-board installed?
                If the SN board is shorted, you will get blinks no matter what.
                • Ccalxr
                  • Oct 2012
                  • 33
                  • U.S.
                  #48
                  yes, i put the old SN board back in which brought it back to the original problem with the lines on the screen.
                  I did get a full refund on the bad SN board and didnt even have to pay for return shipping.
                  Same with the new A board.
                  I understand that im supposed to get blinks if the SN is shorted but really I should be getting blinks no matter what. A problem in the panel should be forcing a blink code. The tv should not be able to turn on with this issue without forcing a blink code, which is why this problem is so frustrating.
                  • Ccalxr
                    • Oct 2012
                    • 33
                    • U.S.
                    #49
                    is there a way to test the buffer ic's on the sn board? i have a feeling that they are causing the problem.
                    • tw2005
                      • Oct 2011
                      • 6458
                      Did'nt you report after getting hold of a multimeter you found shorted transistors on your original SN board?
                      • Ccalxr
                        • Oct 2012
                        • 33
                        • U.S.
                        #51
                        tw2005, yes I did. I was able to get a few of the mosfets to "beep" using the digital meter that I have, however on the bad board, I was able to get those same mosfets in the same locations to beep as well. The difference is, on the bad board, there were two extra mosfets (30F131) that beeped, that didnt beep on my original board. I have another panasonic board (i know its good) from another tv with the same mosfets that are used on the TNPA5349 board and when I tested them with the meter, they beeped as well. This leads me to believe I dont have my settings right on the meter and that certain types of mosfets are causing beeps even if they are good. As I said before, my digital multimeter skills are quite lacking and this particular meter does not have "diode mode"
                        • tw2005
                          • Oct 2011
                          • 6458
                          Ok in cct yes you can get a quick beep and a reading is usually ok but a continuous beep and say 0 or something real low is a short. So sounds like you maybe back to where you started and possibly no shorted IGBTs? I was amazed seeing reported shorted IGBTs and the TV on with no blinks.
                          The detail in the SM is so poor I can't make out the test points. I'm thinking either a gnd point and running the probe slowly along the buffer output connectors and see what happens in continuity mode or there is a testpoint marked TPVFG, try that and the outputs.
                          • SCITOMMY
                            • Dec 2013
                            • 35
                            • US
                            #53
                            Are you sure your ribbon cables going to the buffer board are OK?
                            The horizontal solid white bar on your picture happened to my TV when one of my ribbon cables were completely removed when trying to reseat them with the TV running (like a dope).
                            • SCITOMMY
                              • Dec 2013
                              • 35
                              • US
                              #54
                              I guess you could just wait until you can get your hands on a good SN board or send the one you have in for repair.
                              • Ccalxr
                                • Oct 2012
                                • 33
                                • U.S.
                                #55
                                i never pulled the panel tabs while it was running but it was like this before I got a hold of it so someone else could have. its a possibility, but it didnt look like it had ever been taken apart before.
                                • Porky1
                                  • Jan 2014
                                  • 10
                                  Speaking of the ribbon cable could someone help me out with removing my board. I have the repair parts and am trying to get the board out but I'm having difficulty with the ribbon cables. I have flipped up the bar on the connectors and given a gentle tug on the ribbons but they don't seem to move. What am I missing?
                                  Help!!!! Please.
                                  • tw2005
                                    • Oct 2011
                                    • 6458
                                    Help!!!! Please.
                                    Provided the bar is all the way up, just grab it with 2 fingers either side (index,thumb), and pull it gently nice and straight. it'll be wedged in there so it will just pop out after it moves a little. just enough pressure to get it to pop out, You don't want to get rough and tear it as the conductors will tear like paper.
                                    When they're inserted in again when you feel a little resistance they seat in just a little bit more.
                                    There should be notches on the side of the ribbon to guide you as to how far and how straight the cable is.
                                    You could even take a photo of them before you undo them the first time as a guide.
                                    • ugamazing
                                      Best place to source RAM chips? 8GB 820-00850 boards to 16GB or 32GB
                                      by ugamazing
                                      I'm looking to upgrade several 8GB 820-00850 boards to 16GB or 32GB for personal use. I am curious what the best practice and process is for sourcing new replacement chips, and what vendor(s) you guys prefer? Another question is, how do I find compatible chips and their corresponding part/model numbers? For example, in the 820-00850 schematic, the DDR chip U2600 model listed (EDFB232A1MA) corresponds to 1x32GB chip. Of course, I would need 4x8GB chips to replace the 4x2GB chips currently on the board. How do I find compatible 8GB chips? Is it as simple as searching "BGA178 8GB 2133"...
                                      08-31-2022, 07:34 AM
                                    • HKS00
                                      Panasonic CF-20 Track pad issues
                                      by HKS00
                                      Hello Everyone,
                                      My name is Haris and, I am new to the forum. I would appreciate any help I can get.
                                      Little back story on me and the issues that we are dealing with...
                                      I work on a fleet that uses Panasonic CF-20s we have about 65 of them. Up until the beginning of the year they all had warranty so all the repairs were covered. Fast-forward to now and all of the units are out of warranty and it can't be extended past this point. We don't have the budget this year to replace them, so we will be stuck trying to fix any issues that may come up.
                                      03-08-2023, 10:34 AM
                                    • newgen2005
                                      Panasonic DMR-ES30V power issues
                                      by newgen2005
                                      I picked up a Panasonic DMR-ES30V (UK). When I first plugged in there was nothing, appeared completely dead, I then turned it on and off a couple of times at the mains supply and it came on. It accepts a cassette but then spits it out straight away, the DVD drive functions sometimes but then the unit turns off with nothing on the display. I took the back off and noticed the fan does not spin. The display for the DVD side does seem a little dim when it is working.
                                      I have looked on google and people say it is most likely a capacitor/s.
                                      Just looking for some advice on which...
                                      09-26-2024, 03:49 AM
                                    • gre0013
                                      Panasonic TC-59R62 Overscan issues. How to adjust?
                                      by gre0013
                                      Hello. I need help opening the service menu on a Panasonic TC-59R62
                                      Its an old CRT with bad overscan. The top left of the screen is cut out and I need to adjust it. Ive tried multiple methods online ie, holding volume down on the TV then pressing recall (with the 30m timer as well). Nothing I have tried has been able to bring up the menu if there's one at all.
                                      Or is there an adapter I could use to fix this? Trying to use the TV for old retro games but again the top left of the screen is cut out and cant see anything displayed there.
                                      07-26-2024, 10:14 PM
                                    • BigPete
                                      Panasonic Heatpump Dryer Repair
                                      by BigPete
                                      I picked up a Panasonic NH-P70G2, though it would apply to the NH-P80G2, NH-P70G1 and NH-P80G1 models as well, as maybe some other models. This one was coming up with a H86 error. After lots of testing and googling it was an error with one of the thermistors in the condenser area.
                                      The attached French service manuals is incorrect, TH11 is gray and is a 95k thermistor and TH12 is black and is a 35k thermistor.
                                      In my case TH12 was bad. I was able to get a 35k thermistor on AliExpress. It's 6mm in diameter.
                                      Unfortunately the whole machine has to come apart to fix it.
                                      I have...
                                      11-01-2025, 06:40 PM
