Bush bled24fhdl8 stuck in standby
+ More Options
Posts
  • vinceroger69
    • Mar 2012
    • 6714
    hi another project BUSH BLED24FHDL8 stuck in standby solid red light only pics of boards attached where do i start?
    only 6 wires from psu to main
    pin 11 and 12 gnd
    pin 10 adj 00.1 volt
    pin 9 ena 00.0
    pin 7 and 8 +12v 12.2 volts
    voltage regs on main are all 1117 b
    u5 0.00 3.31 5.17
    u6 0.61 1.86 3.53
    u2 0.00 3.28 5.18
    so where do i test next pressing the on button does not change voltages at all.
    Re: Bush bled24fhdl8 stuck in standby
    If ENA does not toggle, then main board is bad, it is not sending the ON signal.
    • vinceroger69
      • Mar 2012
      • 6714
      cheers tom just rechecked with on the set buttons and a remote no change at all i will see how much a main is do the voltage reg readings look ok to you? cheers tom
      good pic of the board anything u can suggest to check?
      http://flattvparts.co.uk/index.php?m...ducts_id=15654
        What's part number of U6? It seems a little odd.
        Full image:
        http://flattvparts.co.uk/bmz_cache/4....2444x2076.jpg
        Near coils, left hand side of board, there are chips U3, U4 and U7. Part #s of these?
        Fuse F1 good? Bottom LHS.
        Fuse F110 good? Top LHS.
        • vinceroger69
          • Mar 2012
          • 6714
          Fuse F110 good? Top LHS. no voltage either side checks ok on ohms test
          1117 b u6
          u4 aic2857f
          u3mp1423dn
          u7aic2857f
            Just 1117 on U6? Nothing else?
            • vinceroger69
              • Mar 2012
              • 6714
              soz tom bad migraine today eyes hurting haha it says 1117 b ad a21g.
                I would expect something like -18 on that regulator, so that does not seem right, but it is possible it is unmarked.
                Can you see any way to measure the voltage across capacitors E3, E4 and E9, with board powered up?
                • vinceroger69
                  • Mar 2012
                  • 6714
                  e3 0 volts
                  e4 5.2 volts
                  e9 1.3 volts
                    U4, AIC2857F is suspect, but I cannot find datasheet for it.
                      Found a pin out, close enough...
                      So of U4, check pin 2, pin 8 and pin 7 voltage, board powered up, relative to ground (i.e. black probe on ground/chassis.)
                      • vinceroger69
                        • Mar 2012
                        • 6714
                        u4 aic2857f
                        gr8 12014
                        if thats helps
                        • vinceroger69
                          • Mar 2012
                          • 6714
                          tom that pic does not match ie the indent does not match to pin 1
                          0.01 0.01
                          12.24 0.01
                          0.01 0.00
                          0.00 0.01
                          the indent is top left on u4 if this makes sence back soon another freecycle set to collect will be bk very soon.
                          u4 aic2857f
                          gr8 12014
                          https://cdn.badcaps-static.com/pdfs/...f75d06d109.pdf may help you tom.
                            The schematic pin out is drawn differently to the real pin out, this is fine. Just use the pin numbers I mentioned, using dot on device as reference, not the schematic.
                            So, it looks like the main processor is not turning on that converter. Not much else to do other than price up a main board at this point, probably another board with bad firmware. You can try searching for a replacement flash chip, which may be one way of fixing the board, but that's not always available.
                            • vinceroger69
                              • Mar 2012
                              • 6714
                              i have found one on ebay he wanted 35.00 or offers so i have bid 25.00 on it pity this set does not have a remote or stand but is in great condition still worth doing in your opinion?
                                Don't sell many small TVs without stand, big TVs 37"+ are fine but small TVs go on cabinets, bedside table, etc.
                                • vinceroger69
                                  • Mar 2012
                                  • 6714
                                  im not sure what to do the main board i found on ebay i have just realized is for a 19in led set so not sure if it will work or can i change the panel size i think the person selling it is a member on here sorids so i have just emailed him to ask him his thoughts. there is one on ebay selling now bids up to £52.00 same set no stand but has a remote so i will need to spend about £37.50 board and a remote so not sure what to do as cant guarantee the screens good yet but looks ok.
                                    If both panel types are same (CHIMEI - CHIMEI etc.) and both 1080pFullHD or 720pHD (depending on which yours is), then it -should- be OK.
                                    • vinceroger69
                                      • Mar 2012
                                      • 6714
                                      the screen in this is a LM236AA51 made by vision photoelectic technology co.ltd made in china does look likes it 1080 so i may take a chance on the board as hes a member on here and has said i can try it
                                      http://answers.argos.co.uk/answers/1...ons.htm?page=3
                                      • vinceroger69
                                        • Mar 2012
                                        • 6714
                                        just to let anyone reading this thread the outcome at the moment i am waiting for a cheap main board to come up for sale the one i thought i found was not the correct one a connector was missing so this is on hold as i will also need a remote control and a stand.
                                        • PNI E.
                                          Samsung ue55tu7170u not turn on and no standby led main bn9650990e
                                          by PNI E.
                                          Hi guys, I’m back here my friend give me her tv, that doesn’t turn on and no standby red led. When u plug in the cord the red led of one two second is on, then turn off. If you push the power button or the remote the red led blinks but nothing happen. I give u some photo with voltage, don’t look the fuse….because I blow it for mistake nd I dint have the right replace so I just put it for test the tv. The standby voltage should be 11,88 volt on the diode, but I have 13 volts. I put in the photo the different volts I test and there are someone negative…I don’t know if it s normal. On...
                                          03-17-2025, 04:23 AM
                                        • cheeky2
                                          by cheeky2
                                          05-25-2024, 03:27 AM
                                        • AleMonti
                                          LG 55EG910V - no power and no standby light
                                          by AleMonti
                                          I'm trying to troubleshoot and repair this old LG OLED curved TV, model 55EG910V.
                                          I did some basic troubleshooting and reviewed most related posts here, but I wasn't able to isolate the issue.
                                          The TV shut itself off during playback and never came back to life - the standby light remains off. My dad claims that it has happened a few times in the past but the issue resolved itself after some time. Not this one.
                                          After checking the basics I did the following:
                                          • I measured all voltages and as expected the only active supply is the 3.5V standby. It
                                          11-04-2024, 05:02 PM
                                        • lego1234567
                                          LG 32LB1R - stuck in standby mode
                                          by lego1234567
                                          Hi. I have the following problem with my TV. After connecting to mains, the standby led (red) turns on, but TV is not responding to remote control or buttons on TV. After some measurements, I found out that +5 V standby voltage is present, but I dont have ON/OFF signal coming in to turn PSU on. It stays at zero volts. After looking at the schematic of the mainboard, I should get ON/OFF signal coming in at the R1402 resistor, but it stays around +3,5 V. So I removed it and I was able to turn on TV with buttons on TV, but not with remote control.
                                          What could be the problem ? Thanks...
                                          01-21-2024, 03:39 AM
                                        • Dani_2024
                                          by Dani_2024
                                          10-28-2024, 05:06 PM
