Hisense 55Q9G Android reset / factory firmware reload
  • mon2
    • 13984
    Please see attached. Found this in a YT video. Is this the PWM frequency to change? I recall Hisense tech mentioning 180 zones - perhaps change this value to a lower value?
    ( not sure if we have this same menu but will ask the client later today )
    • Diah
      • Feb 2013
      • 6357
      this what did you show also there over load at BL the value should be not more as ---- Min BL 0... 20BL 30 .... Mid BL 80 , 80BL 90, Max BL 100 .... so at user setting menu set BL level to ... 35 -40
      PWM Freq are one of BL zone... but it related to Factory Factory Option which key and version didn't show at yours photo
      • mon2
        • 13984
        Sorry - picture is from a video on youtube - not our unit. Will ask the client to take pics. TBH - scared about this menu but will review. Too many cases where the unit was bricked
        • Diah
          • Feb 2013
          • 6357
          keep silent don't ask.... he will missing all... u should ask before give it back to owner and u know its still have issue
          • mon2
            • 13984
            At this time, I finally have the latest firmware for this 55Q9G and also the 65" version of this model. Can this firmware be applied using a USB key to correct the parameters? Even though this TV with the 65" firmware has auto-updated to the latest - can we apply the 55" firmware? TBH - does the USB firmware tool even know the difference of the firmware packages? I think not as long as the pkg file is properly CRC'd.
            • Nicktronic
              • Mar 2023
              • 247
              Hi, would you mind sharing where you got the firmware. I'm having the exact same issue with a 55Q9G. I would like to try re-flashing too.
              • Nicktronic
                • Mar 2023
                • 247
                Thank you for the FW mon2. When I turn the TV on, it gets to the home screen, but after about 10 seconds the TV turns off. It's not enough time for me to start the FW install off the USB stick. I read that if you hold the power button on the remote when turning the TV on with the USB stick plugged in, it will auto install the FW. All I got was the "checking" window like it was checking the FW prior to install. When that completes the TV turns off and goes no further. Any thoughts on what could be happening? I'm stuck....
                • Davi.p
                  Hobbist Tech
                  • Sep 2009
                  • 4297
                  • Italy - Milan
                  #28
                  Hi, my guess is: set apart the replacement main board, take the original one to a service shop to do an emmc reballing, then try the update with the correct file.. if it works then wait, there's a further step.. bye..
                  • Nicktronic
                    • Mar 2023
                    • 247
                    Thank you David.p, I will see what options are around for recalling...
                    • masterm
                      JVC LT-43C888 (manufactured by Vestel) does not start after trying factory reset, details below
                      by masterm
                      TV: JVC LT-43C888 (purchased in 2018). This is a smart TV with Netflix, Youtube, Freeview and other applications via 'Viewd' app store
                      Problem with TV:
                      - Netflix stopped working so i tried to do factory reset from the TV menu.
                      - I confirmed on-screen but the factory reset did not happen even. It did not take me to 'first-time installation' screen as mentioned in the manual.
                      - After waiting for some time, the TV went into a boot loop.
                      - JVC logo comes on the screen and LED light flashes for some seconds, then it reboots again and the same thing happens
                      04-30-2024, 03:03 AM
                    • neilc6
                      Factory Reset Westinghouse WG55UR4100 Android TV
                      by neilc6
                      I repaired the backlights on this model (symptom flash of backlights, repaired seven bad, part#3P55TA004-A2 new strips available at Shopjimmy) and now the TV is stuck on the home screen. I can only turn the TV on with the remote and no buttons work once booted on the home screen. Only the TV buttons volume -/+ and on/off work. There is no physical menu or input buttons.
                      I think a factory reset will clear it but not a lot of options. Tried the Sony Android methods of holding down the on/off button while plugging it it and holding down vol- with power on/off....
                      05-26-2021, 03:26 PM
                    • pfrcom
                      Reset/erase Hynix SC210 to factory default
                      by pfrcom
                      Some Googling made this seem straightforward, but it ain't necessarily so:
                      First try was Hynix Drive Manager, supposed to be able to do PSID reset
                      In Win7 x86 context, what shoddy software – this greeted me first time I clicked it from Start menu:
                      After wild goose chase triggered by the OpenGL bit, I tried swapping graphics cards until penny dropped when it still objected to a Radeon HD3450
                      How I got it work:
                      1. Command prompt
                      2. Change to install directory \Program Files\SK Hynix Drive Manager
                      3....
                      04-23-2022, 07:30 AM
                    • AJ847.63e
                      A1708 unable to reinstall Monterey after factory reset - disk utility error 478
                      by AJ847.63e
                      I've got a A1708 which we decided to sell off as we no longer use it. We factory reset the device to wipe all data which went fine but when trying to reinstall macOS it fails with the generic “ MacOS “Installation Failed, An Error Occurred While Installing”. I've tried the usual solutions like the first aid utility apple recommends and also disc utility delete the partitions but still get the same error. Digging into the logs you can see it's giving an error 478 but unfortunately wasn't able to get much info on that on google so I'm unsure where to go from here....
                      02-20-2023, 02:51 AM
                    • jougounou
                      Ricoh spc830dn factory reset
                      by jougounou
                      Hello everybody
                      just wanna know how to factory reset my ricoh spc830dn printer
                      01-03-2023, 02:07 PM
