Samsung HP-T4254 got horizontal lines and 2-3" stripe
  • Ijaz Ahmed
    • Dec 2013
    • 35
    • Pakistan
    Happy New Year to all...
    I have got a HP-T4254 (NTSC model) Samsung plasma out of a junkyard. Upon inspection, it was found that the TV had missing main PSU board. I bought the PSU from China and the TV came to life. Let me admit that I had no idea that I need to adjust VS and Va (as the PSU had been changed)
    I tested (for about half an hour) on composite Video In and VGA, it worked great. Then I took it home and connected cable to the TV and started auto program search (channel tune up) and during this process, the TV turned off with a small smoke and a strange blast type small sound.
    Upon examination, the VIPer 22A in the standby power supply of the main PSU was found blown up. I changed it and TV came to life again but started showing horizontal lines and wide horizontal stripe on the lower side of the PDP. These lines are not pure black but the area glows somewhat (as can be seen in the picture)
    Please see the attached picture and suggest me what else to check on the TV. What I guess is that it could be a bad chip in the Y-Buffer board. I have removed and reconnected all cables to the Y-Buffer but the problem remained there.
    I have almost every tool and instrument in my lab, just need guideline from experts
    [/IMG]
    Re: Samsung HP-T4254 got horizontal lines and 2-3" stripe
    Could be bad plasma panel or bad buffer board/buffer IC. Pictures of the boards would help.
    With a pitch black input video are the lines glowing with the rest of the panel or not?
    • Ijaz Ahmed
      • Dec 2013
      • 35
      • Pakistan
      Hi tom66, thanks for a prompt reply. I will take apart the cover and take some pictures tomorrow.
      At least in the wide stripe, I am sure it is not pitch black but there is glow with some reddish tone. You can also notice the two groups of white lines in the 2-3" wide horizontal black strip.
      • Ijaz Ahmed
        • Dec 2013
        • 35
        • Pakistan
        And regarding your doubt about the bad panel, I am just wondering if it is possible for a PDP to go bad when a standby power supply burns on a working TV. The only thing I can think of is that everything in the TV could have gone crazy as the power to the main AV board got interrupted while all other voltages were there.
        • Ijaz Ahmed
          • Dec 2013
          • 35
          • Pakistan
          Changed the Y-Buffer, the problem remained as it is and at same locations.
          Could it be control board ? I don't think about bad E, F or G boards because in that case, vertical lines should appear.
            I cannot see a control board fault causing this. It's possible if/when you moved the TV the panel got damaged/chipped on the edge? Also possible the ribbon cable is not fully seated.
            The buffers are basically shift registers with data and clock - the control board cannot discriminate between individual lines.
            • Ijaz Ahmed
              • Dec 2013
              • 35
              • Pakistan
              Quite a logical answer but why the black area/lines glow while the rest of the panel is displaying the picture ?
              That is the only thing which is confusing me to think about electronic fault rather than a Y-electrode or panel damage.
              Would a color pattern test help in finding something ?
                Could the damage perhaps be on the Z-side of the panel? (X-main on Samsung panel.) You'd still get a glow, but it wouldn't discharge properly. Also, sometimes plasma cells can be affected by their neighbours, especially if the plasma panel is a little worn out.
                • Alastair E
                  Chief Womble
                  • Mar 2013
                  • 1963
                  • U.K.
                  If the fault is unchanged with new buffers, the panel is no good.
                  The background glow in those dead areas will be leakage from the good areas adjacent to them.
                  Probably damage to the Kapton film tabs from the glass of the panel to the buffer-boards....
                  These cannot be replaced as are part of the panel itself.
                  TELEFIX
                  • Ijaz Ahmed
                    • Dec 2013
                    • 35
                    • Pakistan
                    I will examine the panel for any visible damage and do a color pattern test (don't know even there is some pattern test even available on this 2007 panel).
                    A local tech was telling me that if the +5V supply failed during the operation, it could have affected the AV board or the logic board. So I was thinking to do a color pattern test as well.
                    • Alastair E
                      Chief Womble
                      • Mar 2013
                      • 1963
                      • U.K.
                      Seriously doubt the AV board would cause that fault. Its just very slightly possible that the Control/Logic board could--but again Highly unlikely.
                      Check each Kapton film with magnifying-glass, you'll prob see a scratch or a small burn somewhere....
                      TELEFIX
                      • noipi
                        samsung Oled 65 Horizontal Lines and Flicker
                        by noipi
                        I have samsung 65", i bought it last january 2025 2nd hand, and last month got this problem, flickering with horizontal lines. any inputs if this is Motherboard replacement or the LCD tcon, can someone help me what to do, i saw in YT, someone says that to cover the flex connector of the unit. Sorry for my english i am asian. i include the video so someone can help me out. thanks...
                        10-14-2025, 02:11 AM
                      • Ihandyrepair
                        Samsung QN70Q6DTA Ghost or horizontal lines after tape fix horizontal line
                        by Ihandyrepair
                        Hi guys
                        I just started fixing 4k TV few months ago. so I am still learning a lot
                        I got this tv from friend complaint is ghosting or horizontal lines on image.
                        never saw the original symptom but I took the tv back home. the funny part is that after bringing to home, the tv worked fine no issue for 3 weeks.
                        then it started to show the ghosting white image.
                        I started using the tape method, but this tv does not have a T con board and it has only 1 ribbon cable from main board to the tv panel.
                        it has 3 thin small boards at the bottom of the...
                        12-05-2022, 04:18 PM
                      • Rubenlily
                        Samsung QE50Q67TAU - horizontal lines
                        by Rubenlily
                        First of all I'm new here. While looking I found this amazing forum and I'm very happy I did. Now for my problem:
                        I picked up a Samsung UHD QLED QE50Q67TAU from 2021 for $50 knowing it was defective. The seller said it had black lines and that it could get stuck in boot randomly.
                        I've tried a new power cable, hard reset, opening up and jiggling all cables, pressing everywhere to see if I get a reaction but I've gotten nothing. I've tried the tape method but I've only managed to get the lines worse.
                        I'm no expert but I've done the tape...
                        08-16-2023, 01:12 PM
                      • x_orange90_x
                        Samsung UN46C8000XFXZA vertical bars/horizontal lines
                        by x_orange90_x
                        I posted about this previously but didn't get any response, and I have some troubleshooted a bit so I have more info.
                        The screen is full of horizontal "gaps" or lines that distort the picture badly, and after about 10 seconds of powering it on the screen starts to fill with red vertical bars that take on the horizontal pattern. After the screen filled with the red bars, they instantly vanished and then slowly started to reappear. I initially thought it was tab bonding failure, but after getting down to them and pressing each one I find zero change in the picture. I went...
                        09-04-2023, 12:09 PM
                      • arctor
                        samsung 50tu8070u black display with horizontal green lines, sound and backlight ok
                        by arctor
                        hi guy my friend gives me this tv a 50tu8070u that has no picture at all, sound ok, backlights ok. i tought it was a bad panel, but the tv has many horizzontal lines green, i tried with the tape method but nothing change, only the green lines disappear but still no picture. You that have more good than me, do you think it s a panel or can be the main board, because my friend wants buy a new main board....but the tv respond to the remote control, have sound only no picture so i think it s a panel problem that is so broken that i cant fix with tape...or i wrong if someone can help me thanks, i give...
                        04-26-2025, 05:22 AM
