Problem with LG 50uh6535v
  • porfyriadhs
    • Oct 2023
    • 78
    • Greece
    Hello. I have a problem with a lg tv 50uh635 no power no sound red light blinks. Any suggestions. Thanks a lot
  • kasfamily
    • Aug 2014
    • 772
    • Russia
    Hello.How many times does the red light flash?
    • EazyBone
      • Jun 2023
      • 1348
      • United states
      When you hit power, take a flashlight to the screen and see if there is a dim picture. You gave very little data to what happens. Lgs flash 3 times red when you turn them on
      • porfyriadhs
        • Oct 2023
        • 78
        • Greece
        Blink Normal . No sound or anything, I have tried removing mainboard. But nothing happens no backlight. Then I remove the panel and I tried to test all the leds one by one. They look ok. Should I try a replacement led?
        • porfyriadhs
          • Oct 2023
          • 78
          • Greece
          • porfyriadhs
            • Oct 2023
            • 78
            • Greece
            Red led blinks 3 times. In the power board there us a green led that blinks 5 times
            • EazyBone
              • Jun 2023
              • 1348
              • United states
              You did a lot of work lol. I have had similar problems with a model like this. LEDs tested fine, I replaced them like an idiot, they still tested fine. When I turned on the TV though, If I used a flashlight I could see a picture. My issue was the main board
              Take a flashlight to the TV after you hit power does it show a very dim picture? You have to get very close and move the light all around
                • 12206
                • U.S.
                There's your clue, 5 blinks most invariably mainboard issue.
                • porfyriadhs
                  • Oct 2023
                  • 78
                  • Greece
                  Thanks a lot guys . Really apreciate the help . I am happy being helped by the community of the forum .Wish i knew that earlier
                  • multimesut
                    Dell 2007FPB Yellow Light Problem
                    by multimesut
                    Hello friends,
                    A yellow light was flashing on my monitor. It was like it was constantly cutting power. When I opened it up, I saw that the big capacitor in the high voltage line was leaking. I replaced it. When I turned it on for the first time, it had the same problem again. But then, interestingly, it got better. The yellow light was on steady. But the monitor wouldn't turn on. When I examined them with a thermal camera, I saw that the Fli5961-LF reached 50 degrees Celsius and the EM636165TS next to it reached 100 degrees Celsius and was drawing high current on the motherboard....
                    11-13-2024, 07:00 AM
                  • mecha1166
                    XR-77A80K Dead set, red light blinks 8 times. Cannot find error code list.
                    by mecha1166
                    I have a XR-77A80K here. When plug in & press power, white lindicator light flashes on & off. about 30 seconds later, indicator light flashes 8x red. Checked Sony, Power reset = unplug & plug in. Factory reset involves turning it on, then pressing remote buttons when a picture shows. Well, neither of these "resets" are for a dead set like this. Anyone know what 8 blinks indicates, from the schematic? Thanks!
                    07-01-2024, 05:47 PM
                  • Tom_x
                    HP Omen15 dc0001nh keyboard light problem
                    by Tom_x
                    Hi
                    I have this HP laptop, board: DA0G3DMBCE0 rev:E
                    The keyboard light only work, when i connect ac power supply(without battery), until the screen come with cmos checksum error. After this point light can't switch on. The first 5-6 seconds i can switch on/off light with FN+F4. When booing on, i can't switch on.
                    Keyb light controller Y59116, i think working, because receive i2c commands the firsr 5 seconds
                    I know schematic doesn't exist for this board
                    Someone know similar board, that use this rgb keyboard light controller?
                    regards
                    04-05-2023, 10:32 AM
                  • kca
                    Samsung UN60F8000BFXZA ~ No Picture or Sound - 5 Res Light Blinks
                    by kca
                    Hello all ~
                    I’m working on this Samsung 60” LED and purchased a new main board a couple of days ago that did not fix the 5 blink issue. The original main board’s HDMI ports (all 4 of them) failed to work and no amount of reflow remedied that.
                    This 5 red light blink code on the front panel LED is followed (about 15-20 seconds afterward) by an automatic reboot, and results in 5 more red light blinks. Then the entire cycle repeats itself indefinitely.
                    No picture. No sound.
                    I tested all the voltages coming out of the power supply...
                    10-12-2023, 05:23 PM
                  • boyebaran
                    hisense 65k560 back light problem
                    by boyebaran
                    hi to all
                    tv turn on and show logo(backlight on)than backlight turn off than red led in front blinking 7 time. the tv remote control working fine (sound on no picture).backlight changed same problem
                    in 65k560 how to remove protection of backlight? picture of inverter and sockets attached .
                    please advise me tnx
                    05-20-2025, 07:11 AM
