Panasonic TX-P42G30E green light blinking, no video, no audio
  • ItepK
    • Dec 2023
    • 16
    • Hungary
    Hey everyone!
    I've gotten this TV for free, neither have it seen a TV repair man, neither have it been opened before.
    This post describes my entire troubleshooting process of this TV.
    When I turn it on using the ON/OFF switch at the side of the TV, the light rapidly flashes green, then it stays on, but it does not react to any of the remote buttons, side buttons, and doesn't play audio.
    I've taken the unit apart, and I've started to check some voltages:
    • On the P11 connector, there is 15V DC only for a brief moment, then it goes back to 0V
    • On the P2 connector, there is 200V DC, then it quickly goes away, like a capacitor discharging
    • At the lower right side of the board, there is 5V DC for standby (I assume this powers the LED)
    I've asked somebody about this, and they've said that in order for these voltages to show up, the P board has to get a signal to send these voltages, but I'm doubtful about this.
    I've also made a video about the sound of the P board when it's turning on, I assume this "oscillating" sound comes from the relay, and I'm not sure if it's normal. (quiet video, please turn the volume up)
    The first and last clicks come from the ON/OF switch, the sound at the middle is the supposed relay sound.
    The first thing I've started testing was the P board. I've tested (soldered in-place, with diode tester function on the multimeter):
    • the fuses
    • every diode (Schottky, Zener, Normal)
    • every transistor
    But they all turned out fine, there were no shorts present.
    I've also tried running it with the right and left boards disconnected, but the only thing changed was the voltage at P2 didn't discharge as quickly as before.
    Next, I've moved on to the VSUS board on the left.
    Using the same procedure, I've tested every:
    • IGBT transistor (had to peel off the heatsinks)
    • MOSFET
    • Diode (Schottky, Zener, Normal)
    But there was no obvious short-circuit.
    One thing I've noticed is that:
    The tracks on that board marked with red are shorted, but I'm not sure if that's normal
    I've repeated the same procedure for the other boards, but I've gotten the same result.
    Every capacitor on the board has no obvious signs of bulging.
    My last suspect is the A board, but I have no sufficent knowledge to test it.
    Since I can't figure out the problem, I'm asking you guys for help. I'll appriciate every useful answer!
    Thank you for reading it!
  • lotas
    • Jan 2016
    • 4684
    • Russia
    Download the service manual for your model and see what error code the LED blinks and what the fault is, in which module....
    • ItepK
      • Dec 2023
      • 16
      • Hungary
      Doesnt't this section only apply to the red blink codes? My TV only blinks green rapidly for some time, then it stays on.
        • 12206
        • U.S.
        Maybe try a simple hairdryer test, heat the electrolytic caps up with hairdryer for a couple minutes then try tv, see if there's a brief change, don't wait for it to cool down, try it while it's still hot. Start with powerboard, no change, move to other boards with electrolytic caps and do the same.
        • ItepK
          • Dec 2023
          • 16
          • Hungary
          The hairdryer test did not work, but thank you for the suggestion!
          • Diah
            • Feb 2013
            • 6403
            if FANs blocked or damage TV will not start.
            • ItepK
              • Dec 2023
              • 16
              • Hungary
              The fan is fine, I've just checked it
                • 12206
                • U.S.
                Post a good picture of the whole back as to see how everything is connected.
                • ItepK
                  • Dec 2023
                  • 16
                  • Hungary
                  Here is the best picture I could take:
                    • 12206
                    • U.S.
                    Check the solder joints on the powerboard if you have not, search bad/cracked/cold solder joint images if needed, first things I suspect with that fluctuation is electrolytic capacitors or voltage regulating diodes, the hairdryer test will only work on a marginal cap if they are too far gone it doesn't work. Remember they don't have to look bad to be bad.
                    • ItepK
                      • Dec 2023
                      • 16
                      • Hungary
                      I've looked, but all the solder joints are perfect. I've even reflowed some which seemed bad.
                      I'll try recapping it after christmas, let's see how it goes...
                      • m1ch43lzm
                        by m1ch43lzm
                        05-12-2025, 08:37 PM
                        by sam_sam_sam
                        After all of...
                        07-13-2024, 08:14 PM
                      • jxrepman
                        Asus X453MA won't turn on and green led light blinking
                        by jxrepman
                        Hi there,
                        I have this ASUS X453MA Laptop that's not turning on. When I plug in the charger, the green light just keeps on blinking and pressing the power button does nothing.
                        I have checked the charger and it is giving 19+ V
                        I have disconnected the battery and pressed power button for 30 seconds.
                        I tried another RAM stick.
                        Tried disconnecting the keyboard and touchpad.
                        Tried disconnecting the HDD and the wifi adapter.
                        The problem persists.
                        Hope you could help me out on this one. Thank you.
                        12-14-2024, 06:40 AM
                      • canadaboy25
                        Panasonic TC-P54VT25 No image. A or D board?
                        by canadaboy25
                        I have a Panasonic TC-P54VT25 that will power on and prime the display but there is no image at all.
                        The panel is primed as there is a slight glow from the entire panel. This means the problem should be logic related. The service manual also confirms this and recommends replacing the A or the D board.
                        I have tried to get the TV to display the test sequence but I have been unable to and I don't even know if this TV has a test sequence or not. I tried following tom66's instructions in post #3 on this thread https://www.badcaps.net/forum/showthread.php?t=26790. There was...
                        01-17-2021, 01:06 AM
                      • howardc64
                        by howardc64
                        Problem
                        08-04-2024, 10:36 PM
