phillips 42pf7321D -won't come on
  • freekmccoy
    • Oct 2010
    • 12
    I replaced 2 caps back in 2010..and problems begin again
    This time it seems different,no flashing red lights.The screen flickered a couple times then went black.I unplugged it for the night and the next time I plug in,green LED comes on for about 10-15 sec then goes back off.Going to take it apart and see if it is same problem as last time...
    In the meantime,I ran across a craigslist ad for a 51" Samsung plasma that has sound but the screen is cracked.I'm not sure of model# yet,but would this be a possible source for parts for my phillips if my problem isn't bad caps?
    again,Thanks in advance for help
  • freakaftr8
    • Oct 2012
    • 3743
    Re: phillips 42pf7321D -won't come on
    No nothing usable in that 51 inch. Disconnect both upper and lower buffer board and then plug it in. Does it stay on? Of course there will be no picture although.
    • freakaftr8
      • Oct 2012
      • 3743
      This model is known for buffer and y sustain problems.
      • freekmccoy
        • Oct 2010
        • 12
        Thanks for reply.
        I'm not sure what upper and lower buffer boards will look like,I'll take a pic once it get it apart and maybe someone can point them out
        these?
        • freekmccoy
          • Oct 2010
          • 12
          Unplugged upper and lower and it stays on..there's a green light that flashes 3 times on the big board right in middle of tv.
          • freekmccoy
            • Oct 2010
            • 12
            Also tried just unplugging Y sustain(big board) and it stays on.. Sounds like I need to replace all 3?
            • freakaftr8
              • Oct 2012
              • 3743
              No, put one buffer in at a time, start with top. Power up tv.. Does the top half show? Is the picture normal?? If no picture, take top out, put in bottom, do you see any light? Note: if bottom board is in by itself without top buffer, there will be no pic, but you will see the screen glow.
              That light flashing 3 times.. Is that on the main power supply? This is the big board where the mains 120v connect to. If so, is that flashing 3 times without the y sustain plugged in as well? While this is happening do you have a solid green power indicator on the front of the tv?
              • freekmccoy
                • Oct 2010
                • 12
                No it stays lit with y sus board unplugged. Yes the green power light stays on
