TennRich Ribbon Cable, where to get it?
  • winright007
    • Dec 2013
    Found a bad ribbon cable going to the LED's on my 46" Westinghouse. Does anybody know of a website to order TennRich cables, or a trick to strip the ends to re-use it?
  • Tr0ll
    by Tr0ll
    Original T-con:
    First replacement T-con:
    10-07-2023, 07:48 PM
  • zesko
    xps 9520 ribbon cable
    by zesko
    I have a XPS 9520 with broken daughter board and missing ribbon cable. I can fix the board by replacing the connector, but I can't find the correct ribbon.
    There is 2 models, idk which one is needed on my laptop.
    0xkvng
    00vpr2
    Daughter board is LS H822P. When I check for a palmrest, the board attached to have a 0xkvng ribbon. But when I check for LS h822p, it's 00vpr2 ribbon...
    Someone can help me with that please ? Idk the difference between these 2 ribbon but they definitely doesn't look the same..
    thanks...
    10-23-2025, 05:03 PM
  • lowpost99@gmail.com
    Need a replacement ribbon cable DELL Latitude E5470
    by lowpost99@gmail.com
    Anyone know if the ribbon cables are standard across laptops cases like in a PC, or are they proprietary to each manufacturer? I damaged the one that runs between the MB and the power / HDD / Battery Status Indicator LED Circuit Board. The Dell SKU/DPN: ADM70LED. I just need help finding a replacement. Could I possibly use a similar cable from a donor laptop?
    09-04-2024, 07:42 PM
  • NWArkGuy
    Samsung UN65TU8000 - Panel Issue [ hole in ribbon cable ]
    by NWArkGuy
    Well, I will be the first to admit that I screwed up...
    In attempting to replace the backlight in a UN65TU8000, I made a hole through one of the ribbon cables between the board that runs along the bottom of the back of the TV and the panel. This lead to a between a 1/4 to 1/2 inch vertical stripe running the full height of the image.
    I don't have the experience; personally, to solder a bridging wire for the paths that were cut. So, I have been on the hunt for other Samsung TV's of similar size.
    I have 2 that I have found and have in my possession. ...
    10-12-2023, 10:13 PM
  • alfredomfr1
    HP M32f FDH Monitor: 12v missing after connect the LVDS ribbon cable to the LCD circuit
    by alfredomfr1
    12v pin is shorted to ground in the LCD board (1st picture) if the LVDS cable is disconnected, 12v are OK in the Main Board (2nd Picture)
    06-04-2025, 10:23 AM
