SONY KDL-43W755C | 5 blinks stand-by LED
  • lotas
    • Jan 2016
    • 4455
    • Russia
    Such?
    TV 160 ver. 7 https://aliexpress.com/item/1005005929239263.html
      • 12075
      • U.S.
      Yes, useful tool, another there in chinese, have to wonder why they cost so much: https://www.youtube.com/watch?v=1mwbOWsl-VQ
      • dominik0801
        • Feb 2018
        • 98
        • Hungary
        I found out, that my philips tv has the exact same 51pin cable, so I tried the Sony with that cable. Same exact symptom, so at least we reduced the possibilities to mainboard, tcon, or panel.
        However, without the TCON connected, the tv boots up, and "works" (it has sound, and reacts to everything), so I pretty much would say that the mainboard is also good. Personal opinion only of course, I might be wrong..
        If I can find a TCON for a reasonable price, I'm going to try it with that. If not, I have no better idea, than sell as parts.
        • Diah
          • Feb 2013
          • 6339
          from his video. its android, logo shown at bootloader ..... system media android start too then brick up.... its 100% non T-CON or Panel... forget about 5 blink red....press joystick forward then down..plug it in wall ... release only when the LED change from white to green.... se if the 5 blink exist or not
          easy way
          • dominik0801
            • Feb 2018
            • 98
            • Hungary
            easy way
            Done it a few times already, but didn't fix anything.
            The LED changes to green, then 5 blink starts again.
              • 12075
              • U.S.
              #26
              You think he should try using a mouse or keyboard Diah?
              • Diah
                • Feb 2013
                • 6339
                how long with this rest it take to start 5 blink longer than yours video ?
                • Diah
                  • Feb 2013
                  • 6339
                  we have this issue from user from USA before 4-5 years... he succeed with USB MBR mode formatted Fat32 on it last firmware and the pressing of reset to change LED from white to green.... but only after be sure his LED BL 100 OK
                  • dominik0801
                    • Feb 2018
                    • 98
                    • Hungary
                    #29
                    White changes to green, you can count to ~3 seconds, and it goes to 5 red blinks again.
                    • Diah
                      • Feb 2013
                      • 6339
                      check first yours LED BL
                      • dominik0801
                        • Feb 2018
                        • 98
                        • Hungary
                        #31
                        Another "new info", after every Volume down + power (green led for 3 seconds, then 5 blinks), at the next powering on, the TV stays on longer when the circle things are spinning/loading.
                        It works for like ~8 seconds, before the 5 blinks.
                        Then at the next start it's 3 seconds max. again.
                        Okay, gonna check backlight. In the meantime, I tried to power the tv from my bench psu, no change.
                        • Diah
                          • Feb 2013
                          • 6339
                          if yours BL fine as i read now.. its longer... than yours ISSUE BL or MB my post #24 in place
                          • dominik0801
                            • Feb 2018
                            • 98
                            • Hungary
                            #33
                            Yes, I just checked with tester, both BL lines are good.
                            Also, when I disconnect MB from PSU, backlight is working properly too.
                            ​Out of ideas..
                            Done so far:
                            -android software update thru USB stick (it has LED, it was reading from it, the TV restarted 2 times, and played a music while updating, exactly how I read it should be),
                            -tried another PSU,
                            -tried different LVDS and panel cables,
                            -tried VolDown+power button method,
                            -(cross-)measured and thermal checked every component on the TCON panel, then motherboard found no problems,
                            -and whatever i dont remember atp.
                            Everything seems to be fine, until I connect this tcon. Then it's 5 blinking asap.
                            Could it be, what nomoresonys said in post #11, that the panelid eeprom is corrupt? If yes, am I shot?
                            • Diah
                              • Feb 2013
                              • 6339
                              yours TV Sony..... how it come the BL come on when MB disconnected ```this is only for Samsung !!
                              • dominik0801
                                • Feb 2018
                                • 98
                                • Hungary
                                #35
                                Well, I don't know, but this is how it works. 😧
                                When I disconnect MB from PSU, it's starting BL as soon as it gets power.
                                • lotas
                                  • Jan 2016
                                  • 4455
                                  • Russia
                                  #36
                                  Try to disconnect the lvds cable from the t-con and turn on the TV, and after loading, sharply, without distortions or displacements, insert the cable back, that is, connect it hot, see where it is better to do this on the motherboard side or on the T-con side.
                                    • 12075
                                    • U.S.
                                    #37
                                    Worked on an old sony from 2009, the backlight on it would only come on when mainboard was unhooked from powerboard and would give the solid color red green blue etc, screens, that one just needed a firmware update/pair but did not have a situation like that before or since.
                                    • Diah
                                      • Feb 2013
                                      • 6339
                                      then. disconnect the 2 LVDS and turn on... check if you have 12V on T-con Fuse.... it you have then color pattern show on screen... if no 12V then teed the fuse with it
                                      • dominik0801
                                        • Feb 2018
                                        • 98
                                        • Hungary
                                        #39
                                        Fed the TCON with 12V.
                                        It took 700mA, screen turned on, and played test pattern: different shades of white/gray, then chessboard pattern, then horizontal lines in R, G, B and white, then repeat.
                                        Pattern was fine, screen was fine.
                                        • Diah
                                          • Feb 2013
                                          • 6339
                                          Work on MB reflow it
                                          • thelankanguy
                                            Sony KD-55X9000F TCON Issue
                                            by thelankanguy
                                            The TV shows a black screen with no image.
                                            TCON ribbon connectors were disconnected individually for image and there was no half image even.
                                            Later both ribbons were disconnected and TCON voltages were tested.
                                            12V, 3.3V, 1.8V were seen present but VONE signal reads 0V.
                                            There is also a short to ground in this circled inductor.
                                            Is this a TCON issue or something else ?...
                                            12-13-2024, 12:27 AM
                                          • bbrain
                                            Sony KD-55AG9 TCON?
                                            by bbrain
                                            I have this problem with my Sony 55' AG9.
                                            It flashes 4x.
                                            I have found the service manual, and seems it is the TCON.
                                            Before I buy a TCON can someone check the vid?
                                            Thanks in advance!...
                                            09-19-2024, 10:50 AM
                                          • Seb932
                                            LG 49UB850V not switching on / standby LED off / LD701 blinks 5x
                                            by Seb932
                                            i'would like to fix my not working LG 49UB850V tv.
                                            Symptoms:
                                            -AC plugged in, Standby LED not working
                                            -Switching on, Standby LED blinks 3x. LD2300 on mainbord lights up and after ~30s LD701 on PWS board starts to blink 5x repetetive
                                            Checked already:
                                            -Powersupply Output in Standby => 3.5V ok
                                            -Switching On => PWR_On on P201 goes high and 3.5/12/24V are present on P201
                                            Any suggestions what to check next?
                                            Thanks in advance!
                                            09-14-2023, 06:28 AM
                                          • rabbituk
                                            Sony HCD BX7700dbi CMT flashing standby
                                            by rabbituk
                                            I have got a Sony HCD-BX7700dbi that isn't worth a lot but I'm keen to learn how to repair and would appreciate some help with my train of thought. The protection circuit is kicking in and the standby light is blinking. It goes into protection mode within a second of powering it on.
                                            So far the relay on the power board that enables the main transformer clicks on and then off when powering on the unit. Looking at the schematics, the permanently enabled power rail called 'unreg sub' provides about 13.5VDC. Where the power comes into the main board on connector CN303, there is a diode...
                                            02-11-2025, 05:05 PM
                                          • dumbdd
                                            Sony 75X9400E TV.. 5 Red blinks
                                            by dumbdd
                                            I was using this TV for 5 years before it stopped working. I like this TV and would love to fix it myself.*
                                            When I press the power button, the white led comes on (sony calls the module smart core) and then it switches over to 5 red blinks. No screen, no backlight, no relay click, nothing. I have disassembled the tv and found the service manual for 75x940e online. The manual suggests a faulty power board, TCON or the panel.**
                                            The standby pin is at 3.3V. Fuses on the mainboard and TCON are fine. Caps on TCON also seem to be fine. When I turn on the tv the white led...
                                            07-01-2023, 08:54 PM
