SONY KDL-43W755C | 5 blinks stand-by LED
  • dominik0801
    • Feb 2018
    • 98
    • Hungary
    #41
    Originally posted by Diah
    Work on MB reflow it
    Okay, tomorrow I'll do it. Wanted to do a full reball, but don't want to wait for a stencil.
    • lotas
      • Jan 2016
      • 4876
      • Russia
      #42
      What reball? First, check the I²C bus (SDA, SCL) between the T-CON (eeprom) and the motherboard, what is the resistance on this bus relative to ground, use an oscilloscope to check whether data is being exchanged on it...
      • dominik0801
        • Feb 2018
        • 98
        • Hungary
        #43
        Relative to eachother: 100ohm both.
        Relative to ground: 4.6KOhm both.
        They are not shorted to eachother.
        Unfortunately scoping and BGA has to wait too, I forgot about the holidays and family time.. 😆
        • Diah
          • Feb 2013
          • 6588
          nomoresonny point it to EMMC. but its not... but BGA on vision Chips 100%
          • Diah
            • Feb 2013
            • 6588
            just to add . you need to be sure too of the Opto..C between Hot and Cold area are all fine
            • lotas
              • Jan 2016
              • 4876
              • Russia
              #46
              And also check the area where the eeprom was missing, maybe before you, when the eeprom was dismantled, the resistors were removed or damaged, compare with the original board and use a multimeter to call these lines (sda, scl) from this eeprom chip through the lvds cable to the motherboard to see if they reach.
              • Diah
                • Feb 2013
                • 6588
                Originally posted by dominik0801
                Hello guys.
                Today I got this TV for free, the friend included a "new" (used) TCON with it, since he told me, that doesn't work either.
                With the stock TCON, this TV turns on, stays on, but the screen only has 5 RED vertical lines on it, and that's it.
                Backlight stays on and is fine.
                With the "new" TCON, the TV turns on, shows SONY logo, some spinning circles, then the TV goes blank, and the stand-by LED is blinking 5 times, won't react to anything.
                I have read some forums, where it's been told that the part number is not always enough to be the same, because TCONs might still have different components on them - but they are all the same, triple-checked everything under a microscope.
                I have switched all NAND/SPI chips over, in case they have an identification number in them, but that didn't help either.
                No missing components.
                While the TV is ON (before it turns off with 5 blinks), the picture on the screen is perfect. Not a single bad pixel, line, or whatever.
                Unplugging different sides of the screen won't make a difference either.
                Do you have any ideas?
                hold om.... i just read yours first post..... you need to do all test i wrote before on yours original t-con
                • lotas
                  • Jan 2016
                  • 4876
                  • Russia
                  #48
                  But 100 Ohm between sda and scl seems low to me, check which side (t-con or motherboard), you need to disconnect the lvds cable.
                  • nomoresonys
                    • 12330
                    • U.S.
                    #49
                    Not so sure, I have seen faulty eMMC present in many ways.
                    • nomoresonys
                      • 12330
                      • U.S.
                      #50
                      There's a test to narrow between emmc and "vision chips" anyone know it?
                      • lotas
                        • Jan 2016
                        • 4876
                        • Russia
                        #51
                        "Vision" is a Processor that is installed in Philips TV models.
                        • nomoresonys
                          • 12330
                          • U.S.
                          #52
                          It's a word that Diah used BUT we all know what he meant, the processor of course, get it iotus. or do you want to keep up with the BS nonsense. CLIMB DOWN.
                          • nomoresonys
                            • 12330
                            • U.S.
                            #53
                            Mods, don't you think you need to censor all smartass remarks, not just mine. Don't give a shit regardless.
                            • lotas
                              • Jan 2016
                              • 4876
                              • Russia
                              #54
                              Vision - it gets very hot, which was not even saved by the original radiator and because of this, the BGA balls on which the processor was soldered degraded. After a reboot and installation of a more powerful radiator + installation of a fan, the motherboard continued to live.
                              • nomoresonys
                                • 12330
                                • U.S.
                                #55
                                I also don't care for the new cookie policy, about how this site shares info and also said something about may not even be based in the U.S.A. So where is this site based?? If it is based in the States then why did I read this cookie policy here on this site??
                                • Diah
                                  • Feb 2013
                                  • 6588
                                  exactly... also i can add the poor quality manufacture... when they set the controller camera in wrong way or at more tolerance at time it checking the board after placing the pasta on it... so how it come become this as General issue !!!
                                  • Admin
                                    • Oct 2003
                                    • 5334
                                    #57
                                    Hi nomoresonys, thank you for your contributions to the forum. I see you're very active on here so all your contributions are appreciated. On "censoring smartass comments"... I would say that occasional smartass comments without vulgarity are fine and not an issue. If a member frequently makes them it can lead to a negative environment and that becomes a problem. I want everyone to keep things helpful and positive. I'm new to the forum so I'm not saying this directly to you but just as a general rule. I've not even looked at your post history just generalizing here.
                                    On the cookie policy. The site has servers in Europe and in USA but with such strict privacy laws (especially in Europe) you need to be clear on your policies to cover yourself. We actually don't sell or share user data. We just have a cookie policy, privacy policy, and terms that cover us in all scenarios to avoid frivolous claims.
                                    With user generated content there are some risks you have to negate.
                                    • nomoresonys
                                      • 12330
                                      • U.S.
                                      #58
                                      Welcome and thanks for the non-abusive and detailed response, imo I already think you are the best admin. that I have ever seen here. here is what it says after cookies are erased and the site is brought up fresh: We process personal data about users of our site, through the use of cookies and other technologies, to deliver our services, personalize advertising, and to analyze site activity. We may share certain information about our users with our advertising and analytics partners. For additional details, refer to our Privacy Policy.
                                      By clicking "I AGREE" below, you agree to our Privacy Policy and our personal data processing and cookie practices as described therein. You also acknowledge that this forum may be hosted outside your country and you consent to the collection, storage, and processing of your data in the country where this forum is hosted.
                                      • brithepi2k
                                        Sony KD-65XE8596 no standby light
                                        by brithepi2k
                                        I’ve got a Sony KD-65XE8596 here that has no standby light coming on. I’ve tested the power board with the test meter, the TV needs 3.4 for the standby but only getting 2.4. Anything that I can change/check on the board to get it working? Pictures of the board are included.
                                        cheers...
                                        09-06-2025, 02:22 PM
                                      • iglitare
                                        Sony KD-75XF9005 grey Picture but Sound. TCON or panel?
                                        by iglitare
                                        i want to repair a Sony KD-75XF9005 TV that initially only showed a grey picture.
                                        Backlight seems to work, Sound (Setup menu after reset) works.
                                        If i dissconnect the left FFC cable from TCON to panel i have half a screen on the right. If left cable is connected always only the grey screen.
                                        Interchanged the cables, its always only the right side that is working. Always grey if left side is connected.
                                        With my small knowledge i would think at least the cables are good.
                                        Can this happen because of a bad tcon board?
                                        Or is it always a bad/shorted...
                                        09-04-2025, 07:13 AM
                                      • kca
                                        by kca
                                        Hello all ~
                                        08-31-2025, 06:38 AM
                                      • rimwall
                                        Sony KD-65x7500D - double image - Tcon or Panel?
                                        by rimwall
                                        This TV was showing a fine image and pulsing with a partial double image (offset vertically) every few seconds. I taped 8 clock pins on one ribbon cable from the Tcon to the panel. It stopped the double image, but some pulsing in intensity was still visible. I then taped another 8 clock pins on the same ribbon cable and the image is now ‘fixed’. Although I understand this results in some loss of resolution, presumably because the clock signal degrades as it passes horizontally across the screen.
                                        I am wondering - do these symptoms and ‘fix’ mean that it’s a Tcon fault or...
                                        11-18-2025, 02:09 AM
                                      • thelankanguy
                                        Sony KD-55X9000F TCON Issue
                                        by thelankanguy
                                        The TV shows a black screen with no image.
                                        TCON ribbon connectors were disconnected individually for image and there was no half image even.
                                        Later both ribbons were disconnected and TCON voltages were tested.
                                        12V, 3.3V, 1.8V were seen present but VONE signal reads 0V.
                                        There is also a short to ground in this circled inductor.
                                        Is this a TCON issue or something else ?...
                                        12-13-2024, 12:27 AM
