Samsung PN50C540G3FXZA 50" Plasma, power cycling, Y-Main problem, Canada
  • bcstedt
    • Jun 2011
    • 59
    Just starting to crack into this one and wanted to get the ball rolling.
    At power on (plug in), power light on, relays click, repeat (sometimes)
    After disconnecting Y-Main from SMPS power stays on and boot up jingle is heard from speakers
    Removed Y-Main for inspection and testing
    This pic from:
    PN50C540G3FXZA Fast Track Troubleshooting Manual - Rev 1/10/12
Name:	Samsung PN50C PCB layout.jpg
  • bcstedt
    • Jun 2011
    • 59
    Y-Main board
    Model No: 50U(F)2P X-MAIN(1LAYER)
    PCB No: LJ41-08457A
    Rev No: R1.2(09/11/18)​
      • 12151
      • U.S.
      Test everything you can on y-main, be sure to check the transistors for shorts, a short will show continuity between any of the 3 pins of the transistor, so if you measure in ohm mode and have close to 000 ohms thats a short.
      • bcstedt
        • Jun 2011
        • 59
        Components I'll be testing shortly from the Y-Main board.
        Results are DCV from DMM diode test.
        SMALL HEATSINK
        Q6000 - SMK1360 MOSFET
        /OL/OL/0.525//OL/OL/0.1+/
        Q5402 - GT30F123 IGBT TOSHIBA
        /0/0/0//0/0/0/ - (shorted)
        Q5401 - GT30F123 IGBT TOSHIBA
        /OL/OL/OL//OL/OL/OL/ - (open)
        D5406 - RF1501 Diode 300V 12A
        /0//0/ - (shorted)
        LARGE HEATSINK
        Q5102 - RJP63F3
        /.017/.017/0// same / - (shorted)
        D5101 - STTH12R06FP Diode 600V 12A
        /0.371//OL/
        Q5403 - GT30F123 IGBT TOSHIBA
        Q5408 - GT30F123 IGBT TOSHIBA
        /.027/.027/0// same / - (shorted)
        D5402 - STTH1004FP
        /0.422//OL/
        Q5303 - 1K31AJ
        /OL/OL/0.503//OL/OL/1.835/
        Q5304 - RJP30E2
        /.011/.011/0// same / - (shorted)
        D5401 - RD2006 Diode 600V 20A
        - 0.389/OL
        • bcstedt
          • Jun 2011
          • 59
          Y-Main
          Small Heatsink
          Large Heatsink
          • bcstedt
            • Jun 2011
            • 59
            With the Y-Main board disconnected, the SMPS test points read:
            Vs = 212VDC (211 on label)
            Va = 54.8VDC (55)
            Not sure where to check Vsc & Ve yet.
            (I need the Y-Main functioning to get these)
            Click image for larger version  Name:	IMG_20231214_184503_DRO~2.jpg Views:	15 Size:	964.4 KB ID:	3164733
              • 12151
              • U.S.
              Yep it's a mess, many just try to get a good replacement board from somewhere because of how hard parts are to find and all the counterfeit components that are being sold.
              • bcstedt
                • Jun 2011
                • 59
                Thanks, I'm beginning to see that. I've got a few other things to check before I order a board but I don't even know if the PDP is functional.
                  • 12151
                  • U.S.
                  Not a fan of plasmas, cons seem to outweigh the pros, too heavy, too hard to repair because of hard to find parts etc, use 3 times as much energy, 1080 max resolution, just to name a few.
                  • bcstedt
                    • Jun 2011
                    • 59
                    I finished testing the Y-Buffer, X-Main and SMPS boards. All diodes and transistors check out but there is some soldering rework needed.
                    I've ordered an X-Main board and hope I'll find an acceptable result soon. Updates to follow.
                    • bcstedt
                      • Jun 2011
                      • 59
                      Did some solder rework on the SMPS and X-Main boards. Inspect & test the "new" Y-Main board, looks good and significantly less heat damage.
                      Installed & test. Was getting some hissing noises from the Y-Buffer and the screen looks like this:
                      Click image for larger versionName:	IMG_20231227_153549_DRO~2.jpgViews:	0Size:	4.63 MBID:	3169007
                      Click image for larger versionName:	IMG_20231227_153603_DRO~2.jpgViews:	0Size:	4.35 MBID:	3169008
                        • 12151
                        • U.S.
                        Make sure y-buffer to y-main connections are as they should be. For testing unhook y-buffer from y-main, because a faulty buffer can kill a y-main and vice versa, maybe test the little mlc caps on y-buffer at least for shorts and retest y-buffer IC's , testing there if needed: https://www.youtube.com/watch?v=5hVi5gd0aec
                        • high-tech
                          Samsung UN55F7050AFXZA ver. TD01 power cycling
                          by high-tech
                          Hello everybody, I could use some help on this one... It's got me guessing...
                          I took pictures of all the boards and the pin out of the connector on the power supply that goes to the main board... I measured all the pins in relation to chassis ground, here are the result.
                          (B13v)1. 12.7 volts cycling (Vamp) 2. 12.7 volts cycling
                          (B13v)3. 12.7 volts cycling (PWM5) 4. 1.0 volts cycling
                          (OD_LE)5. 2.8 volts cycling (PWM4) 6. 0.9 volts cycling
                          (OD_ON)7. 2.8 volts cycling (PWM3) 8. 0.9 volts cycling
                          9. ground (PWM2) 10. 0.9 volts cycling...
                          09-15-2020, 03:39 PM
                        • usbdevice
                          Acer X223HQ (Version Bbd) on/off-power-cycling
                          by usbdevice
                          Hi all
                          There's two other threads about this monitor with seemingly the same problem. The problem was resolved in one case by replacing the entire PSU board and in the second one by replacing an unknown IC.
                          https://www.badcaps.net/forum/showthread.php?t=50657
                          https://www.badcaps.net/forum/showthread.php?t=40512
                          The first one has pictures of the pcbs and I noticed that there's one IC and assorted caps not populated on mine (but the PCB itself looks identical) so I thought that'd warrant a new thread.
                          It's my dad's old monitor. He...
                          08-05-2022, 02:21 AM
                        • dbuergi
                          MacBook A2141 one USB port dead and one power cycling
                          by dbuergi
                          I got a 16inch MacBook Pro showing 5v and 0,3a on the left ports and right side has one power cycling and one showing nothing. The one cycling shows 30c under thermal camera. Surrounding components show no corrosion or any shorts.
                          Any ideas what to check next? The whole board looks clean compared to the other A2141s i saw....
                          04-25-2025, 11:40 AM
                        • mon2
                          A2141 820-01700 Power cycling (DFU worked ok)
                          by mon2
                          Hi. Working on an A2141 that is power cycling. Powers up fine (20V @ 3.1A peak) -> fan spins ok and then at a higher speed (after we removed the trackpad so the sensors are missing) -> chimes ok but after the high fan spin -> power cycles and repeats this loop. We did manage to DFU the unit with revive mode (4/4 steps completed ok) -> resulted in a brief padlock graphic before power cycling. Unable to toggle the keycaps led since the boot does not reach this far of the cycle.
                          Q: Does the DFU process validate that the nand flash is OK ? We do not wish to restore this board...
                          11-24-2023, 12:17 PM
                        • valvashon
                          Samsung UN55FH6030: random power cycling
                          by valvashon
                          Samsung UN55FH6030, perfect size for my office and does OTA well but isn't a smart TV. That's OK because I am a TV station engineer and only need it for OTA monitoring.
                          About a month ago it started power cycling itself once or twice a day and now it's nearly continuous once it's been on for a few minutes. Changing channels would really start it cycling and it would take several minutes to stabilize but now it's just doing it almost non-stop without changing channels.
                          Once I disconnected the antenna I found that I could change channels with no issues. My guess is...
                          10-20-2023, 09:59 AM
