Panasonic TH 42PZ400U
  • Phydoux
    • Aug 2012
    • 83
    Re: Panasonic TH 42PZ400U
    Originally posted by tom66
    My TV (the one in the video) had the problem at the connector end on the bottom board, D board. I had to unplug the TV and wait some time after doing so to let it discharge (safety), then was able to reach down and plug the cable in. This isn't shown in the video. My problem was intermittent too and that TV has been fine for nearly a year now. Good luck.
    2007 and 2008 PDP from Panasonic are similar but 2007 has upper/lower address drives, 2008 has only lower address drives.
    So I should be ok to close up the back and bring it back over to my dad's? Hopefully that wire won't come loose again!!!
      No. You need to reseat that cable both ends. Also I'd put 4 screws in for a first test before full assembly.
      • Phydoux
        • Aug 2012
        • 83
        GRRRRR!!! Back to a split screen. I will try to figure out how to get to the other side of that cable later. Taking a break for now.
          You can take the assembly of input boards off the frame to expose D board underneath.
          • Phydoux
            • Aug 2012
            • 83
            Did that but when I tried pushing the connector back on the D board the connector on the board came loose. It's still connected to the board but now it flops around. I still have the same result of a split screen. Did I damage the board now?
            • vinceroger69
              • Mar 2012
              • 6714
              #26
              depends how bad the damage is you may have to remove the board if needed and take some good pictures for vus to see you may of broke some of the traces off.
              • Phydoux
                • Aug 2012
                • 83
                Can't tell if anything is broken in these photos but it's as close as I can get. Maybe I should just buy a new one. It does look like there is a hinge type system going on here. I'm afraid to move it a lot though. I'm afraid it will break loose permanently.
                  Signal pins are still OK. You can use glue to secure that connector down on each end. Super glue works fine.
                  • Phydoux
                    • Aug 2012
                    • 83
                    Here's another shot from the other side of the connector.
                    • vinceroger69
                      • Mar 2012
                      • 6714
                      #30
                      ive seen worse as tom says super glue should be fine pins look ok.
                        Carefully bend it down and use glue to secure the far ends of the connector and it should be OK.
                        • Phydoux
                          • Aug 2012
                          • 83
                          Bought some LockTite Super Glue. Works with plastic, metal, wood, etc...
                          • Phydoux
                            • Aug 2012
                            • 83
                            Got it back together this morning and I still get the split screen. Is there another cable not attached to the boards I pulled out to get to the D Board (D, H and DG boards were pulled). I also checked to see that all connectors were firmly in place for all of the other visible connectors. I'm at a loss. It worked for 30 minutes and I'm back to square one. Maybe this weekend I'll tear it apart and reassemble everything.
                              Did you manage to get a remote to do those test patterns?
                              • Phydoux
                                • Aug 2012
                                • 83
                                Not yet. Dad is still looking for it. He might have tossed it when he got the universal.
                                • Phydoux
                                  • Aug 2012
                                  • 83
                                  Couldn't find a remote but he said he ordered a new one off eBay. Should be here by next week. I'll put this TV on the back burner until then.
                                  • Phydoux
                                    • Aug 2012
                                    • 83
                                    Bought the remote for this TV. All I can get it to do is turn the TV on and off. Volume doesn't appear to be working anymore using the buttons on the TV or the remote. I've had it unplugged for about a week or so. Do I need to program this remote for this TV?
                                    • armoured_smiler
                                      Panasonic Tx-40cx400b top left half screen not displaying correct
                                      by armoured_smiler
                                      Trying to work out if this is TFT problem or TCon issue.
                                      The TV powers up but the top half of the screen, from the right it is OK, but as you look across to the left halfway across it starts get duller and duller until it is very dark on the lefthand side, currently I trying to clean the remote as it seems to have something film wise on the pads stopping it from registering buttons pressed.
                                      Also when changing the screen size of Windows PC display to say to a smaller pixel sizewindow, the original window displayin the top left stays/takes a few seconds to disappear?...
                                      04-08-2024, 03:40 PM
                                    • BigPete
                                      Panasonic Heatpump Dryer Repair
                                      by BigPete
                                      I picked up a Panasonic NH-P70G2, though it would apply to the NH-P80G2, NH-P70G1 and NH-P80G1 models as well, as maybe some other models. This one was coming up with a H86 error. After lots of testing and googling it was an error with one of the thermistors in the condenser area.
                                      The attached French service manuals is incorrect, TH11 is gray and is a 95k thermistor and TH12 is black and is a 35k thermistor.
                                      In my case TH12 was bad. I was able to get a 35k thermistor on AliExpress. It's 6mm in diameter.
                                      Unfortunately the whole machine has to come apart to fix it.
                                      I have...
                                      11-01-2025, 06:40 PM
                                    • renech
                                      panasonic TH-42PC77U plasma television half screen problem
                                      by renech
                                      hello,
                                      I hope someone on this forum can assist me.
                                      I have a panasonic TH-42PC77U plasma television.
                                      the lower 1/2 of the screen has become flaky....in and out, then finally goes black and you can only see the top portion.
                                      i have performed the reset to default settings quite a few times. Panasonic recommended..did not believe this would help...it didn't.
                                      I have removed the back panel and looked around for something obvious...burn marks in a board, etc....nothing obvious...
                                      I have read some posts that suggest the problem is related to the boards on the left...
                                      12-12-2022, 06:53 PM
                                    • Zelek11
                                      Panasonic Plasma screen interference on left half of screen
                                      by Zelek11
                                      My Panasonic Plasma model P55VT50 has started displaying "interference" on just the left half of the screen only (left when facing the screen). Sometimes it's concentrated in about the first 30 seconds after startup, then disappears. Other times it's fine at startup and then randomly does it later on. When it flashes the interference it's very quick and doesn't stay on the screen unless it flashes repeatedly in a row.
                                      This image is a screen shot from a video I took. This is an example of the interference at its worst. Often the interference is much smaller...
                                      10-14-2022, 04:54 PM
                                    • Andre Gilbert
                                      by Andre Gilbert
                                      Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing here🤔?
                                      Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting 😂.
                                      11-20-2024, 08:52 PM
