Low Voltage To CCFL Tubes - Sony 55EX500
  • max1636
    • Dec 2013
    • 80
    Im currently waiting on an inverter board for a Sony 55EX500 TV but realized after working on another TV that the problem might actually be that the tubes aren't getting the right voltage. Reading each output to the CCFL tubes I get 175v AC. But on another Sony I was working on which is now functional the tubes are given 230v AC. Im going to open the TV up again tomorrow to see what voltage the PFC board is being given to investigate but I just wanted to know is 175v too low?
    Re: Low Voltage To CCFL Tubes - Sony 55EX500
    If you are using a digital multimeter to measure the tube outputs you've probably just destroyed the meter, as a 55" will drive tubes with about 3000V to start, 2000V to run.
    • max1636
      • Dec 2013
      • 80
      I do it all the time and the multimeter is still fine. I have heard it's not recommended but its not a super expensive one its just a cheap model Fluke. So what you are saying is 175v is too low? The TV turns on for a few seconds and only dimmly shows the Sony logo on screen.
      • Ltank
        • Jun 2013
        • 776
        I just bought a Tenma H.V. Probe 1000:1 ratio can safety measure these voltages without damage to self or your DVM
        • max1636
          • Dec 2013
          • 80
          Thanks I might pick one of those up.
            I would not trust that meter after doing such a measurement. I haven't heard of any commercial portable battery powered meter capable of measuring beyond 1200V? 175V would only cause the ends of the bulbs to glow slightly...
            • selldoor
              Slow Learner
              • Dec 2010
              • 7870
              Hi Tom -I have already told him that!! but even budm didnt pick up on it and neither did the the op.
              I am wondering if we are talking about the same transformers.
              For me an Inverter transformer is the one that connects directly to the
              ccfl socket.
              There are other transformers on the board that supply the inverter transformers
              so if the OP means one of those then 175v would be possible.
              Perhaps the OP can confirm exactly which transformer he is testing.
              • max1636
                • Dec 2013
                • 80
                Sorry guys I understand the reading I'm getting may not be correct but I thought it was weird that on one TV I was getting 230v AC and on another I was getting 175v AC. I was just wondering if that seems unusual? I will open the TV up today to test other voltages. Also the 175v AC and 230v AC reading I am getting from the test points going into the tubes from the inverter board.
                  The AC of output of the inverter transformer can be from 60~100 KHz, the meter will not have the bandwidth to read that high AC frequency. It is also high impedance power source so the probe and the meter can easily load down the power supply.
                  • ttmi100x
                    HANNSG Hi221 -- 2 secs to black feat. CCFL flicker & "burn" marks on power board
                    by ttmi100x
                    Greetings everyone,
                    I have a HANNSG Hi221 monitor that exhibits two seconds to black issues (backlight goes off, display is still on as confirmed by shining a flashlight on it) with some additional oddities...
                    The monitor failed on me with a standard "2 seconds to black" some time ago prompting me to initially replace most of the electrolytic capacitors (some of them were bulging/leaking).
                    Things kinda sorta worked for a night, then the problem returned along with some flickering and "buzzing" noises.
                    Upon closer inspection...
                    07-31-2024, 06:36 PM
                  • Carlos#2003%
                    Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
                    by Carlos#2003%
                    Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
                    02-15-2024, 07:52 PM
                  • caseyjay_48
                    Sony KDL-46BX450 Inverter Troubleshoot Logic
                    by caseyjay_48
                    I am currently on a troubleshoot of 46” Sony KDL-46BX450 tv. I came back from Washington to Texas on medical emergency and had to leave all my tools up there. All I have is a couple of screwdrivers and a dvm. I wish to ask the community a troubleshooting question. Please forgive stupid questions as meds I am taking produce brain fog.
                    I have well maintained Sony KDL-46BX450. It went black one day. After turn-on, I get solid green light and Sony logo in screen center for about 1-2 seconds, then black. No blinking LEDs, no hissing. Flashlight test shows screen characters dimly viewable,...
                    09-23-2022, 08:08 PM
                  • dkneyle
                    Sony KDL-46HX850 Can't upgrade/update firmware
                    by dkneyle
                    Diagnosed this TV as having a failed main board which I've replaced with one from a KDL 55HX850. They are (supposedly) the same board.
                    Being 'Smart TV' it requires a firmware reboot when you swap out boards such as T-Con or main board. It starts with a black screen and flashing yellow and green LEDS, indicating it needs that firmware boot. The procedure described all over the web is to put the software into the root directory of a FAT32 formatted USB drive and it should load that up once plugged into USB1 port. But not for me. I can see the LED on the USB chip flash for about...
                    09-25-2024, 10:44 PM
                    Sony VAIO SVF11N1L2E Hybrid (2-in-1) Fit multi-flip Specification for Upgrade or Repair
                    This specification for the Sony VAIO SVF11N1L2E Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SVF11N1L2E boardview and SVF11N1L2E schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                    09-06-2024, 05:27 AM
